Think I found the solution to the dim front turn signals on 18+
Discussion in '2.5 Gen Tundras (2014-2021)' started by thomasbus337, May 16, 2020.
  1. May 17, 2020 at 3:59 PM
    thomasbus337
    thomasbus337 [OP] New Member
    2020 TRD Sport DC
    I am thinking that when they upgraded the LED headlight with the new 7443 turn signal bulb and socket, they overlooked the wiring or thought the new sockets were still of the CK configuration. The signal wire in the first spot and the ground in the middle works fine in the CK socket that was on all the 14-17’s and 18-20’s with the Halogen headlights. The 7443 uses a standard configuration so the wires should have moved to utilize the 28w filament as a directional, but the wires stayed in the same location leaving us with a 8w turn signal
  2. May 17, 2020 at 4:08 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    I won't have a chance to look into it till next weekend, but it's sounding more feasible with every post.
  3. May 17, 2020 at 4:13 PM
    TTund16
    TTund16 New Member
    I wonder if we have a history of what is going on. I recall some threads that people were complaining about turn signal brightness ... I wonder if Toyota fixed the problem at some point and/or overlooked this in certain model years.
    just a reminder to others with older models. Don't go swapping wires. Keep your headlights off. Turn on the parking light and observe ... If your turn signal is brighter than parking lights, you don't have any problem. If you still don't like the brightness then LED may help but switching wires won't help you.
  4. May 17, 2020 at 4:21 PM
    thomasbus337
    2020 TRD Sport DC
    Mine's a 2020 built in 2/20 and was wired dim. I'd bet that its the 18-20 crowd with the LED headlights from the factory. The 14-17 crowd who retrofit these lights either used a signal adapter harness or re-pinned their stock wiring as a work around for the turn signals. The 18+ SR and lower trim SR5's are still using the original 3157CK setup from 14-17 and don't have this issue
    panicman and TTund16[QUOTED] like this.
  5. May 17, 2020 at 4:32 PM
    TTund16
    TTund16 New Member
    I think Toyota may have outsourced their Testing and QA department ... :D
    Maybe it requires more manual labor to make an old design fit ... and they are aware of this but ignored it to save a few bucks.
    Edit:
    Isn't there a NHTSA test that auto makers must pass including the light brightness, etc.? I know for example you can't have any red lights on front. Amber is ok up front.
    did the dim turn signal passed that test?
  6. May 17, 2020 at 6:21 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I checked mine again and the turn signal still looks plenty bright to me next to my LED parking lights.
    FlyingWolfe likes this.
  7. May 18, 2020 at 3:55 PM
    Jman245
    Jman245 Just moving about my way.
    Jay
    R.CUCAMOMGA,CA
    '19 Tundra TRD SPORT, ‘21 Trail Edition
    Trd pro suspension
    How do you move the wire?
  8. May 18, 2020 at 4:37 PM
    thomasbus337
    2020 TRD Sport DC
  9. May 18, 2020 at 4:46 PM
    Jman245
    Jay
    R.CUCAMOMGA,CA
    Trd pro suspension
    I didn't realize the white part was a lock! I was all jamming down on the prong , hahaha
  10. May 21, 2020 at 4:22 PM
    Walkem
    Walkem New Member
    Canada
    2020 TRD Sport Premium CMax
    Worked like a charm on my 2020! Thank you so much because I couldn't find LEDs that would work in the 2020.
    GODZILLA and Jman245 like this.
  11. May 21, 2020 at 5:00 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Plan on doing this, this weekend. Will report back how it goes.
  12. May 21, 2020 at 5:16 PM
    18" TRD Off Road Wheels
    :popcorn:
    If this all pans out without any negative side effects, then this would definitely be a thread worthy of being stickied.
    EDDO and rebmo like this.
  13. May 21, 2020 at 11:35 PM
    Hunterdan
    Hunterdan New Member
    2017 Inferno DC SR5
    OEM TRD led lights, TRD exhaust, s&b intake
    Fwiw, I've been using these LED bulbs for a few months now with no issues. I've been running retro'd led housings in my 17 for over a year now, and did the wire swap when I did the conversion. Even with the brighter filament, the bulbs are still pretty dim when the headlights are on. These bulbs are a massive improvement in brightness, plus there weren't any error messages or hyperflash with these, and no resistors needed Screenshot_20200522-022502_Amazon Shopping.jpg
  14. May 22, 2020 at 5:27 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Well was bound and determined to do this today, pulled things apart and looks like someone was in there before me, both plugs were hacked up, tried to finish anyways, but no luck barely got the plugs back together, will have to order replacements and fix the wiring with new plugs. To be continued.
  15. May 22, 2020 at 8:08 PM
    Walkem
    Walkem New Member
    Canada
    What do you mean? Did you buy used? Pics?
  16. May 22, 2020 at 8:33 PM
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Yea, it's a 19 bought it feb 20. Just going to replace the plugs, prob should of just backed off when I saw that, but tried to repin them anyways, I have new plugs ordered, will be a simple fix.
  17. May 23, 2020 at 10:54 AM
    rebmo
    Rural SE Wisconsin
    2020 CM LImited 5.7L V8 4WD
    Moved my pins from center to outside today and it works great. Left the JDMStar LEDs in and nice and bright(er). I’ll try the OEM bulbs sometime but they should be fine now activating the correct brighter signal elements. I hope Toyota reads this thread.
    Flyinryank, panicman and GODZILLA like this.
  18. May 24, 2020 at 7:06 AM
    THP865
    THP865 New Member
    East TN
    2019 Tundra TRD Sport
    Coming soon.
    I did this on my 19 and it works as advertised. There is a plug you will have to remove in the third hole in order to move wire over. I used a straight pick and pushed it out.
    EDDO likes this.
  19. May 24, 2020 at 9:03 AM
    #49
    Firefly
    Firefly New Member
    2019 Quicksand TRD
    I just finished this wire swap too. I read this thread yesterday and decided to try it.
    Big difference! I had been considering the JDMStar LEDs but hadn't ordered them yet. After seeing how bright the higher wattage filament is, I might leave it this way with the stock bulbs.
    The little white locking plug is fragile. I found that pliers were crushing it when I tried to pull it straight out so I pried gently from each end with a narrow knife blade until it started to move. Watch out for that little black plug that seals the unused wire hole. It WILL try to escape, at least from my clumsy fingers. It can be pushed out with a toothpick.
    Thanks thomasbus :)
    7dgoat, rebmo, SLA10 and 1 other person like this.
  20. May 24, 2020 at 2:49 PM
    #50
    SLA10
    SLA10 New Member
    2019 Tundra TRD Pro
    Have oem tow mirrors and replacement plugs coming in, will do the plug fix next weekend with the addition of turn signals on the mirror's I'll be happy with the 28w output.
  21. May 26, 2020 at 7:28 AM
    #51
    Newm
    Newm New Member
    KC
    Great thread! Going to try this next weekend. Thank you @thomasbus337 !
  22. May 27, 2020 at 5:15 AM
    #52
    Tumbler
    Tumbler New Member
    2023 CrewMax Limited HV in MGM
    Did mine yesterday as well. Quite a difference. Thanks @thomasbus337!!!
    I work for Toyota so I am going to see what I can find out with regards to this wiring, why and how it is this way. Doesn't make sense.
    GODZILLA likes this.
  23. May 27, 2020 at 6:17 AM
    #53
    TR15UCK
    TR15UCK New Member
    2020 Cement Limited
    Definitely gonna try this after seeing so many successful attempts! Thanks OP!
  24. May 27, 2020 at 6:35 AM
    #54
    thomasbus337
    2020 TRD Sport DC
    Awesome, again I’m guessing it was an oversight when the turn signal socket changed from a CK to standard configuration on the 18+ LED headlights, if you plugged in the 18+ socket from a SR or base SR5 the light would function as normal with the stock wiring configuration
  25. May 27, 2020 at 6:48 AM
    #55
    Tundyfundy
    Bay Area, CA
    Magnetic Grey DC SR5 4x4 2016
    SUSPENSION: Bilstein 6112 coilover (1.9") w/ Powder Coated Springs and Spring Perch (TRD Red), JBA Upper Control Arms, Bilstein 5160's w/Billet Aluminium Reservoir Brackets, +2 Coachbuilder Shackles, Diff Drop Kit, Carrier Bearing Drop Kit, Brakeline Extensions, ABS Extension, Poly Bushings for Leafs, Coachbuilder Shims (2 Each Side), Coachbuilder Bumpstop Extensions, TRD Rear Sway Bar, TRD Front Sway Bar, Air Lift 5000 airbags w jounce bumpers, Daystar Airbag Cradles WHEELS AND TIRES: BF Goodrich KO2's 275/70/r18, BORA wheel spacers 1.25", TRD Wheel Caps,TRD Valve Stem Caps, Spare Tire Lock PERFORMANCE: Bullydog GT Tuner(Performance Tune), TRD Intake, TRD Dual Exhaust (with Modified Exhaust Hangers for Levelling Tail Pipe),TRD Brake Pads, TRD Oil Cap (US), TRD Radiator Cap, TRD Oil Filter, Optima Yellow Top Battery,GP Battery Distribution Blocks, StopTech Slotted Cryo Treated Rotors, Goodridge G-Stop Steel Braided Brake Line Kit PROTECTION: PNP Engineering Type 4 Rock Sliders (With Full Dimple Plate) ,ADD Stealth Fighter Rear Bumper w Red/Blk Shackles and Custom Stomp Pad, TRD Skid Plate with ReadyLift Spacer Kit, Victory 4x4 LCA Skid Plates, JOMAX ABS Sensor Armor, Rear Diff Breather Mod, ARK splash guards INTERIOR: Husky Liners X-Act (Front and Full Coverage Rear and Front Weather Beater Trans Hump), Interior LED Bulbs, WheelSkins Genuine Leather Steering Wheel Cover(EuroPerf), Clazzio Genuine Leather Seat Covers(BLK/DRK GRYwith custom stitching and embroidered headrests), Clazzio Seat Heaters (Front and Rear), Entune Startup Screen MOD, Entune Off Screen Mod, Tinted Windows with Windshield Visor, AJT Key Fobs,Eagle Claws Floor Mat Clips, Bodyglove Visor Organizer,Custom Door Cup Inserts, Glass Break Sensor,AJT Radio Knobs, Custom Dior Cup Inserts EXTERIOR: Full Debadge, LED Brake Light Bulbs, LED Rear Turns, LED Reverse, LED Plate Lights, LED Cargo Lights, LED Third Brake Lights, LED Front Marker Lights, LED Fog Light Bulbs, Lamin-X Fog Light Covers (Amber),2018 OEM LED Headlights, iHacker harness, VLED Universal Puddle Lights, VLED Interior Footwell Lighting (Front and Rear),VLED Extreme Amber Fornt Turns, NSV Knight Rider Light bar, Baja Designs Sport Squadron Pods in Rear Bumper (Driving/wide), Painted Red Tow-hooks, Bed Rail System, Blind Spot Mirrors, Hitch-safe, Tail-gate lock, EAG Raptor Grille, Custom Grille Badge,Full Vinyl Wrap (Matte Black/Matte Pine Green Mettalic), Charvonia Designs Tie Bed Tie-Downs, Bull Ring Bed Rail Anchors, Line-X, Tundra Bed Mat, Bakflip F1 Bed Cover SOUND: Noico 80Mil Sound Deadening and Noico 170 Mil Thermal Insulation (All 4 Doors, Roof, Floors, Rear Panel, Dash). Hertz Uno K170's Component Speakers (Front Doors with Upgraded Sail Panels), Hertz Uno K170 Coaxial Speakers (Rear Doors), JBL C1-075ct Tweeters (Total 4) in Side Dash and Center Speaker, JBL Stadium 5 Amp w/Remote Bass Adjustment Knob and Amp Rack, 12" Infinity Reference Subwoofer in Custom Enclosure w/ “TUNDRA” Logo, Fast Rings Foam Speaker Rings System(4 Doors), Fix 86 DSP
    I have the lef OEM headlights and I replaced the turn signals with the vled triton bulbs. Will this do anything for me? Will they still dim?
  26. May 27, 2020 at 7:04 AM
    #56
    thomasbus337
    2020 TRD Sport DC
    Nope, for some reason or another, the Tritons fix this issue. I tried swapping the pins back to stock with the V6’s and it made no difference
    Tundyfundy[QUOTED] likes this.
  27. May 27, 2020 at 7:09 AM
    #57
    Tundyfundy
    Bay Area, CA
    Word. I love that they are so bright you can see the light pattern on the ground. Kinda makes up for no side view of the blinker. Now people can see my signal light pattern from the side. Good job OP
  28. May 27, 2020 at 7:37 AM
    #58
    Tumbler
    Tumbler New Member
    So just out of curiosity I did a comparison to my 2017 Sienna front turn signals and guess what?!?....same bulb and connector as the Tundra but wired so the 28W filament is used (same as suggested by @thomasbus337 ), not the 8W! Also on the Sienna the LED DRL turns off when the signal is activated. So it does not make any sense that the Tundra is wired the way it is...lower power bulb with DRL on.
  29. May 27, 2020 at 2:55 PM
    #59
    TTund16
    TTund16 New Member
    This seems to be a problem with certain model years (headlight upgrade?) until Toyota figured out what was going on ... and it's not a universal problem.
    My '16 has the bright turn signal (28W) and when turn signals are off, the same 28W is used as DRL. The 8W filament of the same bulb is used for Parking lights.
    I just wonder how these certain models with dim turn signals passed the brightness tests (NHTSB or other tests). Maybe even the dim turn signal was still within the limits. or maybe the tests are based on honor system.
  30. May 27, 2020 at 3:02 PM
    #60
    thomasbus337
    2020 TRD Sport DC
    This issue appears to be 18+ and only on models with the LED headlights. The group that retrofit these lights onto the 14-17 either used a wiring adapter or re pinned the plug as mentioned in the install instructions on many websites offering the upgrade harness
    Turtle and TTund16[QUOTED] like this.
