Thieves
Discussion in 'General Tundra Discussion' started by JRPro, Jun 9, 2018.
  1. Jun 9, 2018 at 4:54 PM
    JRPro
    JRPro [OP] Snappin’ necks & cashin’ checks
    Rich
    Austin, TX
    17 TRD Pro CM Cement
    Just got some ditch lights installed and I’m getting more and more anxious about someone taking them right off my truck, especially in some areas I work in. What have you guys done to armor your investments?
    TXRailRoadBandit73 likes this.
  2. Jun 9, 2018 at 5:11 PM
    TundraRunner481
    TundraRunner481 Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    I electrified my truck. High voltage, low amperage. All jokes aside, if they really want it, they will get it unfortunately.
    geno0506, dcsleeper408, T500 and 3 others like this.
  3. Jun 9, 2018 at 5:21 PM
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    loctite, a locking washer, and a nylon nut. They may get em, but it's not gonna be easy. They may have to steal the entire hood unless they brought a sawzall
    myt1 and TXRailRoadBandit73 like this.
  4. Jun 9, 2018 at 5:47 PM
    TundraRunner481
    SB
    So. Oregon
    That's a good idea. The only problem is that they usually fuck up your shit before they realize it's too difficult and move on. It's sad that you can't have anything nice in this world without worrying about someone taking it.
    Prostar 190 and Help[QUOTED] like this.
  5. Jun 9, 2018 at 7:22 PM
    Spolar
    Spolar Going broke
    Zac
    Seal Beach CA
    2016 sr5
    I didn't do anything for any of my lights or accessories. If it happens it happens but I try not to leave my truck anywhere shady
  6. Jun 9, 2018 at 7:30 PM
    Outbound
    Outbound SSEM #2.5, Token AmeriCanadian
    Aaron
    Northern Alberta
    Around here, LED light bars are common targets for theft. Alot of guys have taken to tack welding the nuts so you have to cut them off.
  7. Jun 9, 2018 at 7:34 PM
    RonW
    RonW New Member
  8. Jun 9, 2018 at 7:44 PM
    JRPro
    Rich
    Austin, TX
  9. Jun 9, 2018 at 8:43 PM
    15whtrd
    15whtrd Mr. Blonde
    How about a little tack weld on that nut.
    TXRailRoadBandit73 and JRPro[OP] like this.
  10. Jun 11, 2018 at 9:40 AM
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    We've had a few customers replace the standard 3/8" mounting bolt with a 3/8" torx head bolt.
    Install the 3/8" bolt (torx) and stainless mounting bracket onto the Ditch Light Bracket first. From there, install the light onto the mounting bracket using the BD security hardware.
    It will be impossible to get a torx bit onto the bolt head without removing the light housing first. And with the BD security hardware you won't be able to remove the light housing from the mounting bracket. Make sense?
    Thanks for running Baja Designs (BD) products!
    -Bailey, Baja Designs
    www.bajadesigns.com
  11. Jun 11, 2018 at 9:57 AM
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    usually, the harder you make it to take...the more damage they do....
    T500 likes this.
  12. Jun 11, 2018 at 10:05 AM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Dont put them on untill you go offroading. I'm sure you dont need them driving around town.....
    PermaFrostTRD likes this.
  13. Jun 11, 2018 at 2:18 PM
    DustinP5
    DustinP5 New Member
    Austin, TX
    2015 Magnetic Grey SR5 Crewcab
    Retrofit Headlights, Heated/Cooled leather seats, Leveled, Pro Grille, Wireless counsel charger, TRD Shif Knob
    Some asshat will probably get pissed and jack with them more and do more damage if they really want them
  14. Jun 11, 2018 at 2:20 PM
    Thinking same
    15whtrd[QUOTED] likes this.
  15. Jun 11, 2018 at 2:23 PM
    T500
    T500 # The Dark Side
    Alfie
    Neptune, NJ
    2020 Black
    Set up cameras. Catch the mofos, then do what any decent Arab would do and chop their hands off
    lionix, D1227 and DustinP5 like this.
  16. Jun 11, 2018 at 2:24 PM
    :eek: :devil:
    T500[QUOTED] likes this.
  17. Jun 11, 2018 at 2:27 PM
    DustinP5
    DustinP5 New Member
    Austin, TX
    He’s on to something...
  18. Jun 20, 2018 at 11:14 AM
    Baja Designs
    Bill
    San Marcos, CA
    Just wanted to give an update, BD has decided to offer security nuts for the 3/8" mounting bolt
    https://www.tundras.com/threads/protect-your-lights-with-baja-designs-security-hardware.27501/
    www.bajadesigns.com
