The Wallygator Chronicles
Discussion in '2.5 Gen Builds (2014-2021)' started by Wallygator, Apr 11, 2020.
  1. Jan 15, 2023 at 7:13 PM
    #181
    2mchfun
    Haven't done my homework on the subject, but depending on the situation you might get by fine with an electric blanket. Just throwing an option your way.
  2. Jan 16, 2023 at 7:06 AM
    #182
    Wallygator
    Wallygator [OP] Well Zippedy Da Do!
    Already have one and that is what I have used til now. It works good. This is just a little project to see if it will improve comfort on very cold nights.
    2mchfun[QUOTED] and Mater like this.
  3. Jan 24, 2023 at 1:00 PM
    #183
    Wallygator
    Switched out one of the 12V plugs in the back of the bed platform for a 4.8V dual USB plug. Now don't have to climb all the way into the topper to charge devices at camp.
    Then realized I could be locked inside the topper if the handle fell down or if someone pushed it down. Thank goodness this hasn't happened. Anyway made a block to hopefully prevent this.
    Warreng, Black Wolf, Mater and 3 others like this.
  4. Jan 24, 2023 at 1:09 PM
    #184
    2mchfun
    Maybe you can add some magnets to the latch block, I'd drill em to diameter and epoxy em in I think. Just a quick thought.
  5. Jan 24, 2023 at 1:25 PM
    #185
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Have to say this is one of the better builds!! Heck of a rig!:)
  6. Jan 24, 2023 at 1:49 PM
    #186
    Wallygator
    Great idea! Only way the block can pop out now is if someone messes with it. I would hope I would wake but cannot rely on that. An too late if they get it out before I do wake up. Thanks for the great idea!
    Thank you! :cheers:
    Black Wolf and 2mchfun[QUOTED] like this.
  7. Jan 24, 2023 at 2:25 PM
    #187
    Wallygator
    Took a rare earth magnet to the area and no joy, not one thing in that lock mechanism is steel. So gonna try this little piece of industrial strength Velcro. Thanks again for the idea @2mchfun. :cheers:
    2mchfun, Mater and Black Wolf like this.
  8. Jan 24, 2023 at 2:50 PM
    #188
    2mchfun
    Always happy to share ideas! Just hard to believe that it didn't fly. Next idea, could you maybe make an emergency tool out of steel banding or something similar to open it up from the inside? Thinking thin somewhat stiff material here. Thinking you could get some practice in and be able to mark the exact alignment spots on both the tool and the seem maybe with a punch. That way you would be able to line it up just right to function the same each time. Wouldn't add weight or take much space and could be extremely helpful! Just another quick thought and happy to throw it your way! As always, good luck!
    Wallygator[QUOTED][OP] and Mater like this.
  9. Jan 24, 2023 at 2:55 PM
    #189
    2mchfun
    Another quick one for you, don't exactly know what the back or inside looks like, but maybe you can cut an access hole with a hole saw and make yourself a simple key to rotate the thing. You would also need a tiny hole that you could plug with a grommet to push out the t handle before turning.
    Wallygator[OP] likes this.
  10. Jan 24, 2023 at 2:58 PM
    #190
    Wallygator
    Yeah back up is tools. Can disassemble the lock from the inside. All good my friend. Thanks again for helping me see all the angles. :cheers:
    Mater and 2mchfun[QUOTED] like this.
  11. Feb 9, 2023 at 3:02 PM
    #191
    Wallygator
    Installed a console vault. It came damaged but decided to install anyway since everything worked.
    Also this week with 30336 miles...
    -engine oil and filter
    -front and rear diff oil change with new washers on all the plugs
    -drain and fill power steering fluid
    -retorqued lug nuts
    -new air filter
    -new cabin filter
    -since the front skid was off, washed the engine bay and under the front of the truck to get all the salt off.
    Have one issue. Found some pretty significant pieces of metal on the rear diff drain plug. Thankful it's magnetic. Saved these pieces and may take them into the dealer to get their opinion. Hopefully these are just from manufacturing. I probably should have changed the fluid earlier than 30k.
    Kind of hard to see with them in a plastic bag...probably 7 or so pieces.
  12. Feb 9, 2023 at 4:00 PM
    #192
    2mchfun
    Don't be overly concerned. Generally speaking it takes a lot to destroy a differential.
    Mater and Wallygator[QUOTED][OP] like this.
  13. Feb 9, 2023 at 5:09 PM
    #193
    cs808
    cs808 New Member
    Utah
    2021 Sr5 crewmax, grey
    Nfab Rdms front bumper OME BP51 suspension and heavy duty leaf springs RCI engine and mid plates CBI rock sliders Method wheels/BF Goodrich T/A Ko2’s TRD pro grille, hood bulge, and sensor
    Is the rear diff work recommended at 30k or you were just being proactive?
  14. Feb 9, 2023 at 6:39 PM
    #194
    Wallygator
    Pretty sure it was due under the special condition parameters which my truck definitely falls under. But I may be mistaken? I have to recheck for you when I get back to the manual.
    Either way I'm glad I did it.
    2mchfun, Mater and cs808[QUOTED] like this.
  15. Feb 9, 2023 at 6:42 PM
    #195
    cs808
    cs808 New Member
    Utah
    No worries, I’ll take a look at it
  16. Mar 17, 2023 at 6:33 AM
    #196
    Wallygator
    Got the transfer case oil changed. 31503 miles. This is a way easier way to do it than laying on the ground.
    Also built the drawer and tested it. Other than still figuring out how to organize things in it, it's working great. Decided not to use drawer slides and just stuck some of those furniture felt slides on the bottom of the drawer. They work well. An a lot cheaper than drawer slides.
    Burnt in a little design. Tried to line up the fire with the grain in the wood. I think it turned out ok for an amateur.
    Warreng, Punisher29073, Mater and 2 others like this.
  17. Mar 17, 2023 at 6:37 AM
    #197
    Wallygator
    This has been one of my better purchases here recently. With the price of bottled water going insane this will pay for itself quickly. Battery powered pump is push button on/off and works great. It's about $2.50 to fill this 5 gallon bottle at the grocery store.
    Mater and TRDFerguson like this.
  18. Mar 17, 2023 at 8:12 AM
    #198
    2mchfun
    Nice job on the art!
  19. Mar 17, 2023 at 8:32 AM
    #199
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Is that your lift?! Man, I’d kill for one of those or a shop that big:drool:
  20. Mar 18, 2023 at 10:51 AM
    #200
    Wallygator
    I wish!!! No it's a friend of mines lift. He lives 600 miles away from me:D. Everytime I visit him I use it. Would love to have one!
    2mchfun and Mater[QUOTED] like this.
  21. Mar 18, 2023 at 10:52 AM
    #201
    Wallygator
    Thanks!:thumbsup:
  22. Nov 7, 2023 at 1:15 PM
    #202
    Wallygator
    Started the rear seat platform project today. This is how far I got before calling it for the day. Made a few mistakes that don’t really matter. Need to get more supplies. An actually vacuumed it out for the first time in 3 years. :D
    2mchfun and Mater like this.
  23. Nov 8, 2023 at 3:22 PM
    #203
    Wallygator
    Found a decent deal on a one side finished 3/4” piece of plywood. The blade I used didn’t agree with the finished side. The finished side is also quite slippery. Will have to figure something out about that. Other than those issues I feel the platform turned out well enough for my needs.
    Was able to get the fridge mounts in place before dark. May add Velcro to the bottom of it to prevent movement. Now need to figure out the back wall. So far into it about $180 after the $30 piano hinge purchase:rolleyes:. May go with 3/8” plywood for the back wall to keep the weight and cost down. Not sure yet.
  24. Dec 5, 2023 at 2:49 PM
    #204
    Wallygator
    IMG_4627.jpg Took a trip to the land of cotton. Some friends of mine like to hunt. I just camped. Had a blast!IMG_4650.jpg
  25. Dec 5, 2023 at 2:54 PM
    #205
    Wallygator
    Thought about it:D
    biebs96, RobertD, 2mchfun and 4 others like this.
  26. Dec 5, 2023 at 2:59 PM
    #206
    Wallygator
    Processed some wood when I got there. Enough for four nights:thumbsup:
    Warreng, RobertD, 2mchfun and 5 others like this.
  27. Dec 5, 2023 at 4:26 PM
    #207
    I have that same axe. Bad ass and very sharp!
  28. Dec 5, 2023 at 4:48 PM
    #208
    2mchfun
    X2
  29. Dec 6, 2023 at 11:07 AM
    #209
    Wallygator
    I love the thing. Thought about getting the longer one also but this one has worked so well it's not necessary at this time.
    2mchfun, Black Wolf[QUOTED] and Mater like this.
  30. Dec 6, 2023 at 11:19 AM
    #210
    Warreng
    Warreng New Member
    i also have the same axe and decided to make it extra sharp…., then I bumped my knuckle with it ever so gently while cutting kindling and cut a tendon. I may or may not have consumed some funky mushrooms prior to this… it was an experience not worth experiencing. Waited until morning so our heads were clear to go to the hospital.
    I now have a dull fiskar axe that cuts just as well and hold the kindling with a stick insead of my hand.
    fantistic axe though haha!
