The Ultimate Headlight H4, Fog Light and Revers Light Upgrade Not LED or HID 1st Gen Tundra Addition
Discussion in '1st Gen Tundras (2000-2006)' started by onesojourner, Dec 31, 2020.
  1. Dec 8, 2021 at 3:41 PM
    #181
    daveeasa
    David
    It's not ideal. See this thread for more detail on that. I would stick to stock wattage with stock wires. A harness is not difficult to install nor overly expensive. Also, some good stock wattage bulbs are still out there.
    Kimosabe[QUOTED] likes this.
  2. Dec 8, 2021 at 4:05 PM
    #182
    Punk1974
    Punk1974 former 2000 owner looking for a fg tunny project
    J.P.
    2019 Silver Limited CM TuRD
    Bak Flip MX4 Tonneau cover, Spray in Bedliner, Tube steps, stubby antenna, red rear sway bar, looking to get back into a first gen tunny
    i’ve done a few incandescent hondas upgrades on 3 vehicles this year.
    the 9005 to 9011hir (highs) and 9006 to 9012hir (lows) and great in reflector houses all are same wattage.
    i’ve done a h11 to h9 in a projector that was 55w to 65w an the light is only slightly better. the housing does get warmer but not melty. thing i’ll try supernovas v4 x which is there newest in that projector next to see how it goes. if its to bright then they might goe in the fog housing which takes the same h11/h8. good to have options..
  3. Dec 9, 2021 at 8:47 AM
    #183
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    06 Tundra DC TRD 4WD
    W.I.P - FOX 2.5 with DSC, SCS F5 wheels with MT Baja ATZ 285s
    Thanks for the quick responses. That's good to keep in mind and continue doing more reading. I remember looking through that thread and it does have good info.
  4. Dec 18, 2021 at 2:03 AM
    #184
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Ordered exactly what @KNABORES ordered and am going to give it a shot. My headlights are garbage at the moment. Between these and the light bar I have to install in the front bumper cutout hopefully I'll be able to see a bit better.
    isomr3b51 and HBTundra like this.
  5. Dec 18, 2021 at 7:40 AM
    #185
    Still happy with my upgrade. Having clear headlight lenses is also important.
    daveeasa likes this.
  6. Dec 18, 2021 at 8:33 PM
    #186
    NickB_01TRD
    Nick
    KY
    I cleaned mine using the Chrisfix method. They aren't perfectly clear but they aren't too bad either.
  7. Dec 20, 2021 at 8:20 PM
    #187
    NickB_01TRD
    Nick
    KY
    Installed headlight harness and new bulbs and 9012's in the fog lights today. Thought having an 01 I wouldn't have any issues but that isn't the case.
    Not sure if you had any issues @KNABORES with your 2000.
    If I turn on headlights and fog lights once I turn on my hi beams they will not turn off without turning my headlights off an on again. Or turning just the fog lights off and on again. If I don't run my fog lights at all then there is no issue. Going to have to get a resistor for the passenger side headlight plug.
    Would like to run the lowest wattage resistor possible but not yet sure what that is.
  8. Dec 20, 2021 at 8:24 PM
    #188
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    any time fog light mod fixes this issue. the problem is how the high beam is wired to the fog light. the fog light switch is powered by the high beam wire when the low beams off. when your highbeam is on, the wire goes to ground which kills the fog lights.
    resistor will work or any time fog light mod.
  9. Dec 20, 2021 at 8:34 PM
    #189
    NickB_01TRD
    Nick
    KY
    Only thing about anytime fog light mod is that I don't want to have to hit my fog light switch every time I turn my lights on or off. Otherwise I'll be driving around in the day time with just my fog lights on (which I understand isn't a big deal I just don't want to mess with it). Guess it could be possible to grab the power from something in the parking light circuit so they would only work if your parking lights or headlights were on.
  10. Dec 20, 2021 at 8:42 PM
    #190
    My lights worked just like they always had after the harness and fog light upgrade. No issues with fog / high beam functions.
    NickB_01TRD[QUOTED] likes this.
  11. Dec 20, 2021 at 9:16 PM
    #191
    DarkMint
    DarkMint just gettin by
    Ben
    2004 Tundra DC SR5 4WD
    I have the same issue as you. Fogs on, high beams will turn on but won't turn off. Only by turning off the fogs do the high beams turn off.
    2004 DC here.
  12. Dec 21, 2021 at 5:16 PM
    #192
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Does anyone know of any company that makes brackets for fitting 3 inch fogs in the round fog holes of 1st gens? The factory fogs aren't great. I would like some brackets if available or I'll probably end up retrofitting some mini projectors inside factory fogs.
  13. Dec 21, 2021 at 5:26 PM
    #193
    daveeasa
    David
    One day perhaps @memario1214 can hook us first gen people up with the oval/round options for mounting brackets.
    Though @Diode Dynamics really could do us a solid directly :)
    memario1214 likes this.
  14. Dec 21, 2021 at 9:39 PM
    #194
    empty_lord
    05 rollover special
    from a cost vs return point of view, i believe it would be a hard sell for as rare as these trucks really are... even though i'd be a buyer
  15. Dec 21, 2021 at 10:43 PM
    #195
    daveeasa
    David
    I'll probably just end up doing a front bumper once I decide. Kinda helps mine is so trashed.
  16. Dec 22, 2021 at 2:58 AM
    #196
    artsr2002
    'Yonder
    I wish there were some drop in LED projector fogs for us. I think I'm gonna order a set of mini bi-led projectors from the slow boat in Ghina and retrofit some cheap stock fog replacements. Not sure how long it'll take but I don't want to just throw LED bulbs in the stock fogs. I don't want to create too much glare. I like sharp cut-offs and I can even wire the bi-led for a nice quad high beam with my main D2S 5.0 projectors.
  17. Dec 22, 2021 at 4:37 AM
    #197
    Projectors in your fogs? Fog lights were meant to be just that. Low shining lights that illuminate the road lines and the area immediately in front of the vehicle below the fog layer to increase visibility when your normal head lights would reflect off of the fog layer. We don’t get a lot of fog where I live (ironically foggy this morning) so I mostly like the look of fogs, but they do fill in the area immediately in front of the truck with light and give a little bit of ditch illumination.
  18. Dec 22, 2021 at 6:15 AM
    #198
    artsr2002
    'Yonder
    Yeah not much fog in my neck of the woods either. The main projectors give off plenty of light for me.
  19. Dec 23, 2021 at 11:34 AM
    #199
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    I'll say the Baja Designs Squadron DAT lights work great for fog lights. I have the amber ones and they are amazing for fog and snow.
  20. Feb 13, 2022 at 11:31 AM
    #200
    tdrich7
    tdrich7 New Member
    2006 Tundra DC 4wd SR5
    Anyone have a suggestion for a resistor to order for installing the upgraded harness in a DC? The link in the OP doesn't go anywhere anymore.
    Also, any thoughts on this price for a new pair of OEM headlights? Seems like a decent deal, as most of what I've seen quoted here has been $400+. Thinking even if I go the restore route for now it wouldn't hurt to have the new pair on hand for when I decide to replace. Seems a lot of people who restore end up wanting to replace in the end anyways.
  21. Jul 27, 2022 at 11:51 AM
    #201
    tokolosh
    tokolosh Serial procrastinator
    J
    SF Bay Area
    05 AC V8 SR5 Phantom Grey
    new driver
    Not sure if a resistor is needed for an 05 Access cab..?
    But if so anyone have an answer to his query? I'm not very electrically inclined so I have no idea what to look for and as mentioned link in OP no worky
  22. Jul 27, 2022 at 11:53 AM
    #202
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    What specifically are you trying to do? Just replace headlights with oem replacements?
  23. Jul 27, 2022 at 12:01 PM
    #203
    tokolosh
    J
    SF Bay Area
    new driver
    The headlight upgrade mentioned in the OP?
    I'm ordering the harness that is linked
    I'm ordering the bulbs that are linked
    I don't know if resistors are needed(?) but if they are the link in OP doesn't work so I don't know what to get
  24. Jul 27, 2022 at 12:43 PM
    #204
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    Gotcha. Careful, don't quote me on this, but I don't think you need resistors with the harness upgrade unless you do the LED bulbs. I think that's the purpose of the harness and relays. Let's see if someone else chimes in to verify my statement.
    I used the harness upgrade from headlight services. It's super well-made and the guy was great to work with. After reading the reviews on the Amazon harness linked above, I didn't want to risk a fire with that one.
    This one http://www.headlightservices.com/Wiring.html
    w666 likes this.
  25. Jul 27, 2022 at 1:12 PM
    #205
    tokolosh
    J
    SF Bay Area
    new driver
    Well crap, already ordered the Amzn one lol. I didn't see any reviews talking about stuff melting/burning, did I miss it? I don't plan on LED's so will hold of on resistors for now.
    Thanks!
  26. Jul 27, 2022 at 8:16 PM
    #206
    Kimosabe
    Kimosabe Slacker
    Sun Valley, Idaho
    uh, check the reviews on Amazon. I saw some that referenced wiring being too small. Luckily, Amazon accepts returns.
  27. Jul 29, 2022 at 2:30 AM
    #207
    tdrich7
    tdrich7 New Member
    This is what worked for me. I only needed one, which I'm seeing now is available on there as well but is advertised for a motorcycle. Appears to be the same thing.
    https://www.superbrightleds.com/mor...oad-resistor-kit-h4-led-headlight-bulbs/2179/
    https://www.superbrightleds.com/mor...ht-load-resistor-h4-led-headlight-bulbs/2932/
    tokolosh[QUOTED] likes this.
  28. Jul 29, 2022 at 2:41 AM
    #208
    tdrich7
    tdrich7 New Member
    From page 5 of this thread on the need for the resistor:
  29. Jul 29, 2022 at 7:08 AM
    #209
    empty_lord
    05 rollover special
    Wiring the fog light switch to ignition solved all the problems without any resistors
    tdrich7[QUOTED] likes this.
  30. Jul 29, 2022 at 8:11 AM
    #210
    tokolosh
    J
    SF Bay Area
    new driver
