The Stereo Slow-Build Begins
Discussion in 'Audio & Video' started by Danimal86, Oct 12, 2017.
  1. Apr 1, 2020 at 12:01 PM
    #181
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    For some reason your new posts I can't see the pictures. I see a sign that looks like the "Do not enter" round sign with white middle across.
  2. Apr 1, 2020 at 12:38 PM
    #182
    Danimal86
    Danimal86 [OP] Looks clean even when its dirty!
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    hmm....not really sure why they would do that. I usually just copy over from my google photos drive and it works fine.
    Anyone else having that problem?
  3. Apr 1, 2020 at 12:53 PM
    #183
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    not to hijack danimal's thread but, i'm running 125 to each door. running new speaker wire really wasn't that difficult. compared to everything else, it's the easiest part. you'll need to drill a hole below the factory harness for the rear doors. start small and gradually go larger. keep an eye on the wire loom that runs down the pillar as you're making the hole. fish the wire through and seal it up with some silicone.
  4. Apr 1, 2020 at 12:53 PM
    #184
    Beerdude77
    To top it off, I'm using a chromebook lol
  5. Apr 1, 2020 at 12:54 PM
    #185
    smslavin
    smslavin New Member
    Hudson Valley
    Some stuff
    i can't see them either. might be a permission issue on the google side.
  6. Apr 1, 2020 at 1:07 PM
    #186
    Danimal86
    Daniel
    Sacramento, CA
    i'll go in and re-post the pictures...
    edit:
    let me know if you can see them now
  7. Apr 1, 2020 at 3:32 PM
    #187
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    Fixed!
    Thanks Danimal86
    :cheers:
  8. Apr 1, 2020 at 3:33 PM
    #188
    Danimal86
    Daniel
    Sacramento, CA
    you got it:fistbump:
  9. Apr 1, 2020 at 6:28 PM
    #189
    Beerdude77
    So, after the door snafu what have you decided sounded better, AF's or C5? I am considering making some changes to my system myself...
  10. Apr 23, 2020 at 7:24 PM
    #190
    Danimal86
    Daniel
    Sacramento, CA
    Some changes in the bass department.
    Today I sold the JL Stealthbox and placed an order with james for two 10tw3's (same model speaker as the Stealthbox) in a ported enclosure. I felt like I just wanted a little more and after talking with James, he said they sound a lot better in a ported enclosure. I could have pulled the speakers out of the Stealthbox, but that would be a shame to waste that fiberglass box.
    On the ride home I missed them so much.
    It was a good run:
    Cfincke likes this.
  11. Apr 23, 2020 at 8:09 PM
    #191
    Cfincke
    San Antonio
    Didn't james build a box recently that holds 3 of those subs for a 3rd gen crew max?
  12. Apr 23, 2020 at 8:10 PM
    #192
    Danimal86
    Daniel
    Sacramento, CA
    dont think so, i asked him about 3 and he said no-go.
    edit: that could have been when i was asking him about the 13.5tw5's...i just emailed him about it.
    editX2: just heard back. He said he did make one on a sealed box, but he said it was a pain in the ass and 2 in a ported was louder.
  13. Apr 23, 2020 at 8:22 PM
    #193
    Cfincke
    San Antonio
    Ok, good to know. What did he say about 2 of the 13.5 in a ported box? Is their not enough volume?
  14. Apr 23, 2020 at 8:30 PM
    #194
    Danimal86
    Daniel
    Sacramento, CA
    He said there isnt enough air volume to put three of the tw3 in a ported.
    when i was spitballing with him about replacing the stealthbox, i asked him about the two of the 13.5s and he said he thought they sounded like crap and he liked the tw3s in a ported box better
  15. Apr 29, 2020 at 1:17 PM
    #195
    Danimal86
    Daniel
    Sacramento, CA
    The 10tw3's and box should be here tomorrow. I bought a 10sqft box of sound deadening and it was enough to cover most of the back. The subs are ready to go in!
  16. Apr 29, 2020 at 6:53 PM
    #196
    Sleeper16plat
    Near Vancouver
    this is the dual 12" box that James built for me!
  17. Apr 29, 2020 at 8:32 PM
    #197
    Mgmtundra
    Mgmtundra MGM Crew
    Also interested in your thoughts on the Audio Frogs.
  18. May 1, 2020 at 6:49 AM
    #198
    Danimal86
    Daniel
    Sacramento, CA
    When fed ex delivered mine yesterday, i was shocked with how small the box was.....for a split second, i thought "do i have to assemble this mf'er?"
    Did you just run a wire around the back of the box to connect the two together?
  19. May 1, 2020 at 6:54 AM
    #199
    Danimal86
    Daniel
    Sacramento, CA
    I really like the audiofrog's. They are butter smooth sounding! dollar-for-dollar i would go for the audio frog over the C5's. C5's highs are extremely sharp and the audio frogs are warm (best way i can describe it)
  20. May 1, 2020 at 6:59 AM
    #200
    Danimal86
    Daniel
    Sacramento, CA
    I got the delivery of the new box and subs yesterday. Got it all unboxed and assembled yesterday.
    These are dual 8-ohm speakers, so i wired them up to be 2-ohm
    After a little bit of adjusting the box left to right to make sure it was centered.....she's home!
    I took it for a little bit of a drive yesterday and tested them out. The box really livened these things up. Its almost violent! My rear view mirror and radar detector were dancing all over the place. The stealthbox definitely had a more crisp and refined sound, but was lacking a bit of punch when it came to heavy bass songs. This thing is a monster!
    AZBoatHauler and Mgmtundra like this.
  21. May 1, 2020 at 7:09 PM
    #201
    Sleeper16plat
    Near Vancouver
    I drilled a hole through baffle in the middle and connected them internally.
  22. May 1, 2020 at 7:31 PM
    #202
    Danimal86
    Daniel
    Sacramento, CA
    I thought about doing this too. I figured if he wanted it that way he would have pre drilled a hole.
  23. May 1, 2020 at 7:43 PM
    #203
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    I did too...
  24. Jul 15, 2020 at 8:46 PM
    #204
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    How much did you pay for sail panels?
  25. Jul 15, 2020 at 8:52 PM
    #205
    Danimal86
    Daniel
    Sacramento, CA
    Toyota of cool springs
    619Tundra[QUOTED] likes this.
  26. Jul 15, 2020 at 8:52 PM
    #206
    619Tundra
    Awesome. Thanks
  27. Jul 15, 2020 at 8:53 PM
    #207
    Danimal86
    Daniel
    Sacramento, CA
    :cheers:
  28. Jul 15, 2020 at 9:04 PM
    #208
    619Tundra
    Do you know if this knob will work with Alpine amps?
  29. Jul 15, 2020 at 9:05 PM
    #209
    Danimal86
    Daniel
    Sacramento, CA
    Doubt it.
  30. Jul 15, 2020 at 9:11 PM
    #210
    619Tundra
    I think it will. They all have the same cable connectors.
