The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Jul 17, 2023 at 8:16 PM
    #1261
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Front end was installed this past Friday (mostly) after work, with the help from @KevinK and @BiggHertz, and a special guest appearance from @AT x AT. I’ve still got some tweaking to do, but these things are stout and are awesome off road.
    IMG_0662.jpg IMG_0660.jpg IMG_0666.jpg R6JS0055.jpg trdFuel.jpg IMG_0693.jpg
  2. Jul 17, 2023 at 8:57 PM
    #1262
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Looked like a great time boys!
  3. Jul 18, 2023 at 5:03 AM
    #1263
    1794TX
    Steven
    N.TX
    '20 1794
    Great stuff. But what in the rusty knuckles is going on there?
  4. Jul 18, 2023 at 6:03 AM
    #1264
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    How much does the swamp cooler help? My garage is over 100 during the day.
    TRDFerguson[OP] likes this.
  5. Jul 18, 2023 at 7:25 AM
    #1265
    AZBoatHauler
    So.Arizona
    We don’t do rust in this state but that’s some dust covered grease oozing out of the upper ball joint. 3/4 of my ball joints look the same. Seems very common when these trucks get used off-pavement - living where it’s 125 outside lets it spread once it’s weeping. At least @TRDFerguson has the serviceable joints with his fancy aftermarket UCAs.
    :jellydance:
  6. Jul 18, 2023 at 7:31 AM
    #1266
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    "If it's weeping grease, that means it's still got grease" - Shitbox 3:16
    Also, what @AZBoatHauler said :D
    GODZILLA, RainMan_PNW, Vizsla and 5 others like this.
  7. Jul 18, 2023 at 7:49 AM
    #1267
    1794TX
    Steven
    N.TX
    '20 1794
    It looked like a crack at first - but it looks like weepy grease now...
  8. Jul 18, 2023 at 7:52 AM
    #1268
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, just ball joint boogers.
    GODZILLA and 1794TX[QUOTED] like this.
  9. Jul 18, 2023 at 8:16 AM
    #1269
    e30cabrio
    All of my Trees Bjoints look like that (except the ones Toyota just replaced) I had an extended warranty that ended so I took it to Tempe AutoNation to get anything wrong dealt with, they did both passenger side Bjoints & the driver side cam tower (none of it looked bad to me) I was happy to get 3k of work done for the 200 deductible. They said the grease was not the issue, it was the control arms that needed replacing.
    This tells me the weeping was fine, I'm sure if they could get it past the insco they would have loved to do the driver side.
  10. Jul 18, 2023 at 12:19 PM
    #1270
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Depends on the amount of humidity in your area. The less humidity, the more efficient the swamp cooler is; as the air gets more moisture to it (rain, humidity, etc.) the swamper looses efficiency.
    I ran one on my 300' dog kennel in Vegas... When it was 105-115 outside and dry, it would cool the kennel to high 70s low 80s. Efficiency is also maximized w/good insulation of whatever you're trying to cool, and also know that you'll need to have vents installed or windows cracked for air flow and to help prevent too much moisture from building up. Up ducts work fantastic in that capacity.
    If you ending trying one, consider this style where it has a traditional box fan style set up....
    https://www.homedepot.com/p/MasterC...orative-Cooler-for-2000-sq-ft-MCP59/304156139
    ...much less maintenance and way quieter than the old hard metal, squirrel cage style coolers that also needed belts replaced and were rusting out from the moisture in the unit!
  11. Jul 18, 2023 at 12:53 PM
    #1271
    e30cabrio
    Thanks, no window in my garage. :(
    Here's what I have now.
    coTony and Tripleconpanna like this.
  12. Jul 18, 2023 at 1:07 PM
    #1272
    Tripleconpanna
    That's the reason for the upducts...
    https://www.doitbest.com/shop/heati...UhKsQEvZ2-7ICEEaYDSpoVutl3jR55-oaAokjEALw_wcB
    ... they are designed to vent into the attic or crawl space; thus providing ventilation in the room and it also keeps the air space above the cooled room cooler as well.
    Yeah, that's miserable; once you've got a nice set up, there's times when traditional AC inside the home doesn't feel as nice as standing in front of your swamp cooler fan blowing cool moisture into your face :D
  13. Jul 18, 2023 at 4:17 PM
    #1273
    coTony
    Tony
    Montrose, CO
    I was actually surprised by how good it was doing for me. It worked up to around 15 for the humidity and if I am 4-5 feet away it was actually very cool where I had to turn it away from me. Now with the high humidity and the Monsoon knocking on our door... not so much. I do not run the cooler just the fan now and that helps a lot. Always got to have 2 doors/windows open
  14. Jul 18, 2023 at 8:00 PM
    #1274
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    How the fuck do you manage to get that league of legends all to come install shit on your truck!?
    GODZILLA, reywcms, coTony and 6 others like this.
  15. Jul 18, 2023 at 8:03 PM
    #1275
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Silver bullets
  16. Jul 18, 2023 at 8:04 PM
    #1276
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Two words: astroglide.
  17. Jul 18, 2023 at 8:10 PM
    #1277
    RainMan_PNW
    Casey
    Clark County, WA
    giving them beers and handjobs?
  18. Jul 18, 2023 at 8:12 PM
    #1278
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  19. Jul 18, 2023 at 8:17 PM
    #1279
    FrenchToasty
    Mo
    Bone stock
    Where’s the second word?
  20. Jul 18, 2023 at 8:18 PM
    #1280
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I guess the joke works better when you’re saying it out loud…
  21. Jul 18, 2023 at 8:22 PM
    #1281
    RainMan_PNW
    Casey
    Clark County, WA
    I completely didn't even see the "two words"
  22. Jul 18, 2023 at 8:22 PM
    #1282
    FrenchToasty
    Mo
    Bone stock
    What is that, 3 times today? I’m the worst
  23. Jul 18, 2023 at 8:22 PM
    #1283
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    We take pity on those that undertake such a job during the hottest part of the day during a record heatwave…
    Allows me to work on a vehicle and doesn’t cost me any money…
    Gets us nerds out of the house…and….
    Butt stuff…
  24. Jul 18, 2023 at 8:23 PM
    #1284
    FrenchToasty
    Mo
    Bone stock
    Not even super man is this high
  25. Jul 18, 2023 at 8:24 PM
    #1285
    FrenchToasty
    Mo
    Bone stock
    I’ve been invited but that’s a long drive for butt stuff
  26. Jul 18, 2023 at 8:25 PM
    #1286
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Missing out…
  27. Jul 18, 2023 at 8:26 PM
    #1287
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’m gonna need a bigger garage if everyone starts showing up. And more lube.
  28. Jul 18, 2023 at 8:26 PM
    #1288
    FrenchToasty
    Mo
    Bone stock
    I’ve seen Jake’s garage, I think I am! I bet there’s still some yingyings in his fridge from cinders(octothorpeT2C) that need some attention
  29. Jul 18, 2023 at 8:27 PM
    #1289
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Those didn’t last long lol
  30. Jul 18, 2023 at 8:29 PM
    #1290
    FrenchToasty
    Mo
    Bone stock
    They are, that good!!!
    Mater and TucsonTundra1794 like this.
