The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Feb 24, 2023 at 8:58 PM
    #991
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’d order it now and maybe you’ll have it by the time you do your radio, haha
    bulldog93, Mater, Vizsla and 2 others like this.
  2. Feb 25, 2023 at 6:53 PM
    #992
    Vizsla
    Vizsla 2 = 2.5
    Dope! Waiting on the slow boat now…:thumbsup:
  3. Feb 28, 2023 at 6:23 PM
    #993
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    Fun fact:
    Toyo Race MT 39s are lighter than Toyo DOT MT 37s.
    Don’t @ me bro.
    whatever that means
  4. Feb 28, 2023 at 6:25 PM
    #994
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Thank you @JevinJ
    FrenchToasty and KevinK[QUOTED] like this.
  5. Mar 4, 2023 at 5:47 PM
    #995
    KevinK
    Tundras to Sedona
    :rofl::rofl:
  6. Mar 5, 2023 at 8:18 PM
    #996
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Swapped out my old dashcam to a Thinkware F200 Pro. Hoping this thing has some better image quality and can double as a trail camera.
    AB591923-6AC6-4F59-8C20-918915BAA447.jpg B73BA5D2-CC7E-44B4-B806-C51BA067698E.jpg
  7. Mar 7, 2023 at 7:27 PM
    #997
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Moved the main camera over a bit - the spot I originally used completely blocked the auto dimming sensor on the mirror, and also got it a little more centered this way. All functions tested good and the video quality is pretty nice. It’s not cinema quality, but should be good enough for accident insurance, and also action shots/stills on the trails.
    CD87F8C8-421D-469F-99A8-463157685CB5.jpg EBC88051-C61D-43C0-B0B0-1FE4AFB5ECC9.jpg 79A58E36-4266-411F-ADD0-71842FABECE2.jpg
  8. Mar 8, 2023 at 5:41 AM
    #998
    1794TX
    Steven
    N.TX
    '20 1794
    Now I have a new brand to consider against BlackVue when I pull the trigger. I wish someone made dash cams with remote storage. I'd like to use SSD and mount it in the console safe.
  9. Mar 8, 2023 at 5:57 AM
    #999
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Don't quote me but I believe the ring cam does cloud storage.
  10. Mar 8, 2023 at 6:15 AM
    #1000
    1794TX
    Steven
    N.TX
    '20 1794
    Interesting - - hadn't heard of that before. Looks like it needs more development, but it looks promising.
    TRDFerguson[OP] likes this.
  11. Mar 8, 2023 at 6:17 AM
    #1001
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    They at least do for home systems. And it's a sub service.
    TRDFerguson[OP] and 1794TX like this.
  12. Mar 8, 2023 at 6:23 AM
    #1002
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I had the opportunity to beta test the Ring car cam… I’d suggest avoiding that one. I’m sure they’ve worked out some of the software bugs, but my biggest gripe is the placement at the bottom of the windshield. It’s annoying to look at, but the bigger problem is the camera getting roasted when putting a sunshade up in the summer.
  13. Mar 8, 2023 at 6:23 AM
    #1003
    1794TX
    Steven
    N.TX
    '20 1794
    I have a Ring doorbell and another cam in the garage, and they're great. Side advice, don't keep your garage clicker in your truck if you park it outside, and don't hook up Homelink or whatever unless it requires the ignition to be on. I had my best-gen broken into 7 or 8 years ago, and the thief got into the garage. Stole some running shoes and rifled through my wife's 4R; but by sheer luck and possibly one glass of whisky, he lived through it.
  14. Mar 8, 2023 at 6:24 AM
    #1004
    1794TX
    Steven
    N.TX
    '20 1794
    I can imagine the angle isn't optimal either.
  15. Mar 8, 2023 at 6:25 AM
    #1005
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep. Hope you like lots of hood, because Ring delivers that much.
    1794TX[QUOTED] likes this.
  16. Mar 8, 2023 at 6:35 AM
    #1006
    memario1214
    Colton
    Missoula, MT
    Never thought about that, but I can't seem to get my Tundra to sync up with my garage door anyway... :bananadead:
  17. Mar 8, 2023 at 6:46 AM
    #1007
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I had forgotten about this. I don’t park outside too often, but that’s definitely a concern when I do. I’ve had the diagram for the mirror harness pulled up for other projects, so I’ll find that and see how easy it is to repin that connector, using a jumper to provide ign power to the constant one.
  18. Mar 8, 2023 at 6:54 AM
    #1008
    1794TX
    Steven
    N.TX
    '20 1794
    I remember someone's post a year or more ago doing just that. Not sure why car makers wouldn't do it that way to begin with...
    [Edit] - maybe this one:
    Homelink Mirror Power Only With Ignition On | Toyota Tundra Forum (tundras.com)
  19. Mar 8, 2023 at 8:47 AM
    #1009
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I’m working on figuring out a re-pin that will make the power to the mirror ignition-sourced
    Edit: maybe I should finish reading before replying
  20. Mar 8, 2023 at 8:48 AM
    #1010
    RainMan_PNW
    Casey
    Clark County, WA
  21. Mar 8, 2023 at 8:53 AM
    #1011
    RainMan_PNW
    Casey
    Clark County, WA
  22. Mar 8, 2023 at 11:17 AM
    #1012
    1794TX
    Steven
    N.TX
    '20 1794
    This would be perfect.
  23. Mar 8, 2023 at 4:51 PM
    #1013
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Pulled off the rear mudflaps and pushed the fender liner brackets back a little to avoid what looked like some potential rub points at full stuff. It may have been a non-issue but I feel better now
    After:
    Before:
    Also installed a cheap trash bin on the bed rails. I just need to find a small bungee cord to run over the top to keep the (soda) cans in while romping in the desert.
  24. Mar 10, 2023 at 1:41 PM
    #1014
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  25. Mar 10, 2023 at 1:53 PM
    #1015
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Don’t leaf them outside
  26. Mar 10, 2023 at 1:56 PM
    #1016
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I made sure to spring them in as quickly as possible... meh. that didn't work as well.
  27. Mar 10, 2023 at 1:56 PM
    #1017
    FrenchToasty
    Mo
    Bone stock
    Pack them in
  28. Mar 10, 2023 at 2:03 PM
    #1018
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    boo
    Vizsla likes this.
  29. Mar 10, 2023 at 2:04 PM
    #1019
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  30. Mar 10, 2023 at 3:19 PM
    #1020
    FrenchToasty
    Mo
    Bone stock
    coTony, RainMan_PNW, RegGex and 4 others like this.
