The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Feb 6, 2023 at 2:38 PM
    #871
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Updated some SwitchPros legends, replacing the ripped “air” sticker and using some better descriptors for the others. These are from the HLK-12 kit.
  2. Feb 6, 2023 at 3:08 PM
    #872
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Your new legends come with “solar power” one? Sure would be nice to have :rolleyes::D
  3. Feb 6, 2023 at 3:51 PM
    #873
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It does! I won’t be using it so can shoot it your way if you want
  4. Feb 6, 2023 at 4:18 PM
    #874
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
  5. Feb 13, 2023 at 6:53 PM
    #875
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Added an NSP-100 external speaker under the center channel speaker grille. This is showing the final setup, with the full case installed around the speaker and L brackets to mount it to the factory holes. I had originally opened the case and used zip ties to hold it in place.
    Full mobile radio setup:
    New Mob Armor discs for mounting the handset and handheld Baofeng:
    https://smile.amazon.com/dp/B0816F2R56
    https://www.amazon.com/dp/B01BINVXB2
  6. Feb 13, 2023 at 6:55 PM
    #876
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Spruced up my farter deflators with some quick disconnect chucks. I’ll probably check these in the driveway before running them off road so I make sure they seal and latch correctly.
  7. Feb 13, 2023 at 8:05 PM
    #877
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    lookin good…
  8. Feb 13, 2023 at 8:05 PM
    #878
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    sometimes i wonder where you get such crazy ideas of laziness/convenience from…
  9. Feb 13, 2023 at 8:32 PM
    #879
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    These are going on my list. Very nice.
  10. Feb 13, 2023 at 8:52 PM
    #880
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I finally got some lol need to adjust them and those fittings I guess lol
  11. Feb 13, 2023 at 9:03 PM
    #881
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    More shit I need to buy
  12. Feb 13, 2023 at 9:04 PM
    #882
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Share the Amazon link when you find it ahah
  13. Feb 13, 2023 at 9:21 PM
    #883
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
  14. Feb 13, 2023 at 9:28 PM
    #884
    RainMan_PNW
    Casey
    Clark County, WA
    TRDFerguson[OP] likes this.
  15. Feb 13, 2023 at 9:49 PM
    #885
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    Wallygator and TRDFerguson[OP] like this.
  16. Feb 13, 2023 at 9:49 PM
    #886
    RainMan_PNW
    Casey
    Clark County, WA
  17. Feb 14, 2023 at 5:28 AM
    #887
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :spy:
    I know a few smart, but lazy people, and then an ad on IG reminded me about it lol
    BiggHertz[QUOTED] likes this.
  18. Feb 14, 2023 at 5:32 AM
    #888
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    coTony, Wallygator, BiggHertz and 2 others like this.
  19. Feb 16, 2023 at 2:56 PM
    #889
    nakota
    nakota New Member
    Phoenix
    Hi! I’ve got the same cat plate, but I’m struggling to get the front bolts off with the TRD skid plate. Any advice or recommendations for cat plate removal?
  20. Feb 16, 2023 at 3:07 PM
    #890
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You need someone with skinny wrists and forearms to get a 15mm wrench on the top of the crossmember... It's a pain in the ass, but I've done it a few times. Not sure if that's what you were asking about but let me know if there's more you need
    FrenchToasty likes this.
  21. Feb 16, 2023 at 3:24 PM
    #891
    nakota
    nakota New Member
    Phoenix
    thank you!
  22. Feb 16, 2023 at 3:25 PM
    #892
    nakota
    nakota New Member
    Phoenix
    this type of wrench was recommended. Can I only loosen it from above the cross member?
  23. Feb 16, 2023 at 3:29 PM
    #893
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yeah that wrench is your best bet. You’ll need to have a socket on the bottom as well, and once you’ve loosened the top you can use the socket at the bottom to finish pulling them. The cat plate should be slotted, so you don’t have to remove the bolts completely, unless you’re taking off the engine skid as well.
  24. Feb 16, 2023 at 3:37 PM
    #894
    nakota
    nakota New Member
    Phoenix
    I would love your opinion on this:
    I’m planning on installing the auto tailgate lock this weekend, but now I’m wondering if it’s even worth it. In order to get to the passenger side grommet I’ll have to get this plate off. What do you think?
  25. Feb 16, 2023 at 3:42 PM
    #895
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Let me look at where I entered the cab with mine. I love having the tailgate lock, especially in the Phoenix area where they get jacked all the time.
    nakota[QUOTED] likes this.
  26. Feb 16, 2023 at 5:12 PM
    #896
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    @nakota you could look into getting a nut plate. It sits in a crevice on top of the cross member. Nice part about it is that one bolt will hold the plate and allow you to loose the other. Can easily slide your cat plate in/out from underneath the skid plate. Hope that makes sense
  27. Feb 16, 2023 at 5:14 PM
    #897
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Just checked and you’d definitely need to drop the cat plate to get into the same grommet. There are others further back that would get you into the cab though.
  28. Feb 16, 2023 at 5:18 PM
    #898
    nakota
    nakota New Member
    Phoenix
    Yes that makes sense. Thank you! Any recommendations on where to purchase? Sorry for hijacking your thread @TRDFerguson It’s laughable all the things we have to do to keep our trucks protected from theft.
  29. Feb 16, 2023 at 5:38 PM
    #899
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I followed this DIY and used the generic actuator mentioned in the first post: https://www.tundras.com/threads/diy-pop-and-lock-for-a-fraction-of-the-cost.28693/
    But if I were to do it over, I’d just buy the full kit from Pop & Lock, since fabbing the bracket and all the connectors was a bitch and a half. This way you won’t have to use wire taps or anything sketchy.
    https://www.amazon.com/dp/B08T5HSW9Z
  30. Feb 16, 2023 at 5:58 PM
    #900
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
