The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Oct 5, 2022 at 2:35 PM
    #631
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I’ve already found my sensitive bits… oh wait.
  2. Oct 5, 2022 at 2:45 PM
    #632
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    wrong bits!
  3. Oct 5, 2022 at 6:31 PM
    #633
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I was looking for a “the other sister” gif but apparently that’s tooooo far askew
  4. Oct 5, 2022 at 6:56 PM
    #634
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  5. Oct 5, 2022 at 6:57 PM
    #635
    FrenchToasty
    Mo
    Bone stock
    “Free tids and bits?!” Juliette Lewis movie
  6. Oct 5, 2022 at 7:35 PM
    #636
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Too obscure, even for me lol. I remember seeing that title when I worked at a video store, circa 2001, though.
  7. Oct 5, 2022 at 7:45 PM
    #637
    BrunoTheRescuePup
    BrunoTheRescuePup New Member
    SW Portland Metro
    2021 MGM Limited TRD
    Eibach Pro-Truck 2.0, Coachbuilder +1, Undercover Flex, Tyger Star Armor, TRD Rear Sway Bar, DD SS3 Max, MisoCustoms
    What is a ‘video store’?
  8. Oct 5, 2022 at 7:51 PM
    #638
    FrenchToasty
    Mo
    Bone stock
    It’s a “never go full ret…” type movie, my old lady makes me watch “classics”
  9. Oct 5, 2022 at 7:55 PM
    #639
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    A form of indentured servitude seen in the later parts of the 20th century, selling overpriced candy and containing a “back room” that people rented brown paper bags from.
    RainMan_PNW and AZBoatHauler like this.
  10. Oct 5, 2022 at 7:56 PM
    #640
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That’s the gist I got from the YouTube clip I watched haha
  11. Oct 5, 2022 at 8:07 PM
    #641
    TILLY
    TILLY Gently Used Member
    Massachusetts
    2019 MGM TRD Sport D/C
    Wallygator and TRDFerguson[OP] like this.
  12. Oct 11, 2022 at 10:31 AM
    #642
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Added an SMA connector to the Rago dash plate to connect my handheld Baofeng to the mag mount antenna. I need to get a 12” SMA cable or pick up the stuff to make my own, but I’m also planning to get an actual mobile radio at some point and not sure it’s worth the effort. The SMA fits perfect in a 1/4” hole.
    8DDEA818-B5DA-4E98-9FFF-1DB19EE57DD5.jpg 8B4E8CEB-2C8A-4556-A47D-9E4BB4DAB943.jpg
  13. Oct 13, 2022 at 10:54 AM
    #643
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    How do you like those bumpstops?
  14. Oct 13, 2022 at 11:04 AM
    #644
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    So far so good. I haven't done a lot of off roading since installing them, but overall I feel like the jarring from speed bumps and other terrain is much less.
    helidave[QUOTED] likes this.
  15. Oct 13, 2022 at 11:07 AM
    #645
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    I am of course a Durobumps dealer so take this with a grain of salt but... I love them on my truck. I can definitely tell the difference, especially up front, between the slammed door feeling of an OEM bump vs something with a little bit of sponginess.
  16. Oct 14, 2022 at 12:03 PM
    #646
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I recalibrated my quick deflators today to 20psi instead of the random 11-17psi range that they had turned into… and then function tested the 4-way inflator now that the onboard air setup is done. Got the tires from 20psi to 38 in about 8 minutes. I need to figure out some kind of hanger for the hose since the Flexzilla ends are too big to loop through the hood latch, but other than that we’re good to go.
  17. Oct 14, 2022 at 12:53 PM
    #647
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Thought you were gonna go single headed?
  18. Oct 14, 2022 at 12:58 PM
    #648
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Nah. Four heads more treads.
  19. Oct 14, 2022 at 1:34 PM
    #649
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    I need to go back and re-read your setup. It’s time for me to get a kit put together now that I’ve got my compressor installed.
    I’m still kicking around routing my air compressor output to somewhere external since my compressor is under the drivers seat
  20. Oct 14, 2022 at 1:40 PM
    #650
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    If you do it, I'd recommend going with 1/4" hose instead of the 3/8 I used. It's pretty bulky. And a heads up, the compressor and fittings can get hot as hell, to the point where @BiggHertz and @TundraPHX have melted their rubber hoses and had blowouts while airing up.
  21. Oct 16, 2022 at 2:39 PM
    #651
    TundraPHX
    TundraPHX Ryan started the fire.
    Jared
    Twice ‍♂️
  22. Oct 16, 2022 at 6:44 PM
    #652
    RainMan_PNW
    Casey
    Clark County, WA
    Holy hell. Sounds like a good reason for me to run an external tank.
  23. Oct 17, 2022 at 12:18 PM
    #653
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    external tank is nice if you need the CFMs for say air tools and/or slightly quicker inflation of smaller items. but there are a few ways to dissipate heat so you don't blow a rubber/synthetic hose. ARB has a ton of options available, just be mindful of the connection tips, NPT vs JIC...
    https://arbusa.com/site/wp-content/uploads/Air-Systems_no-map.pdf
    Hose selection out of the catalog...
    Cheers!
    -JS
  24. Oct 17, 2022 at 12:27 PM
    #654
    FrenchToasty
    Mo
    Bone stock
    I used dot air brake lines and fittings, no blow outs yet
    RainMan_PNW likes this.
  25. Oct 17, 2022 at 12:41 PM
    #655
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    lol...we're referring to the fill hose after it comes off the compressor. I was waiting for my stainless hose and relocation kit to show up and decided to run without it and well...pooof!
    that night, my line and relocation kit showed up...
  26. Oct 17, 2022 at 12:45 PM
    #656
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The ARB just wanted to blow some bubbles
  27. Oct 17, 2022 at 12:45 PM
    #657
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    terrible joke
  28. Oct 17, 2022 at 12:45 PM
    #658
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yes, this... ask me how I know.
  29. Oct 17, 2022 at 12:57 PM
    #659
    FrenchToasty
    Mo
    Bone stock
    Again no issues with the brake hose coming right off the manifold at the compressor.
  30. Oct 17, 2022 at 1:02 PM
    #660
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I was thinking about going with DOT lines as well - anything other than rubber air hose should be fine. The DOT nylon stuff should handle the temps just fine.
