The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Sep 6, 2022 at 3:00 PM
    #601
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    thank you!
  2. Sep 9, 2022 at 12:04 PM
    #602
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Third time’s the charm getting everything aligned with the new control arms. The first shop I used tried twice: first time ended up with the steering wheel clocked to the left and a good pull to the right. Second drove straight but they took out ALL the caster from the control arms and I was now rubbing the cab mount at 3/4 lock.
    28522C75-A603-4748-A870-01CBCC2755AF.jpg 7F9D8F71-E63E-4829-BD47-E62D50660D3C.jpg
    Took it to another shop that seems to do a little better with off road setups (although the first might be fine now that I know what numbers I want) and now we’re dialed in.
  3. Sep 12, 2022 at 5:43 PM
    #603
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Knocked out a couple quick ones today - first was adding a rocker switch to the brake light interrupt signal for my whip module. I thought this might be useful if I’m doing some low speed whippin’ and don’t want the red light flashing over and over. Didn’t take pics of the wiring, but I can if anyone requests it.
    Then I threw in some VLED footwell lights. These things are sweet. It’ll be nice to have the low-level ambient lighting at night, and the LEDs are much better than the cheap light ribbons I had before.
  4. Sep 12, 2022 at 5:47 PM
    #604
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I like the new thread title
  5. Sep 12, 2022 at 5:49 PM
    #605
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Had to question skipper Jake the context of said title...to which he pointed back to the AZ BS thread...nice...
  6. Sep 12, 2022 at 5:51 PM
    #606
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    turned out nicely, if only i didn't have a zone per position, I might consider it...
  7. Sep 12, 2022 at 5:54 PM
    #607
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’d post the reference, but I like inside jokes.
    AZBoatHauler, Azblue and FrenchToasty like this.
  8. Sep 12, 2022 at 5:54 PM
    #608
    FrenchToasty
    Mo
    Bone stock
    Are you saying you grew tired of my red whip on Mt Lemmon?
    I was thinking of doing the same thing, but it’s also a nice signal for others behind you if caution needs to be heeded
  9. Sep 12, 2022 at 6:00 PM
    #609
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Didn’t get tired of it at all. I think it’s great for off road use. But if I’m chauffeuring for Christmas light events… I don’t think others would be impressed.
    AZBoatHauler likes this.
  10. Sep 12, 2022 at 6:00 PM
    #610
    FrenchToasty
    Mo
    Bone stock
    True
  11. Sep 12, 2022 at 8:02 PM
    #611
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Here, done. Hope you’re happy.
  12. Sep 12, 2022 at 8:06 PM
    #612
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Neva!
  13. Sep 12, 2022 at 8:06 PM
    #613
    Azblue
    The Dirty T ( ^_^)_且
    When are you adding the seats and livewell so we can go sand trout fishing on the Santa Cruz river?
  14. Sep 12, 2022 at 8:08 PM
    #614
    FrenchToasty
    Mo
    Bone stock
    You could go to miracle mile for that!
  15. Sep 12, 2022 at 8:09 PM
    #615
    Azblue
    :eek:
  16. Sep 19, 2022 at 4:32 PM
    #616
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Every vessel needs a proper flag for its mast. That came over the weekend, courtesy of BezosMart
    aUIdwcu63uw2SMXEANpl892iRHlmWFPeDKO3sb6m_27719b3f44e053bcabf4dc59eb434b014b4a61e7.jpg
    My DT mounting clips also got here this weekend, so got those connections tidied up a bit.
    gBkR0XrU2jK7ovDz0xgFetsNBxg585uib-kolEPn_5169722541b39d6a60a36b10c5bc66b7a1e9dbe8.jpg
  17. Oct 3, 2022 at 9:01 AM
    #617
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Had to do an expensive mod with little bling factor this weekend… X2 AGM is in place. That thing is freakin heavy. And now I’ll be researching better hold down solutions. I need a better bracket for sure, but the tray and j rods could use some reworking as well. GM diode should be delivered by Amazon today to get that part up to snuff.
  18. Oct 3, 2022 at 2:19 PM
    #618
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Diode showed up and was an easy install - just had to cut the tab off one side to match the other, install it in place of the 5A ALT-S fuse, then flip it from all the instructions I found online lol. Not sure if the 2018 fuse box is laid out that much differently but this isn’t the first time polarity has been revered from older models. Running right around 13.9V now
    4CA3E105-E097-411D-A16A-AA4C1E4A8AAD.jpg 6EA81525-63F1-4BC7-88F9-21306F6BFD85.jpg 8007A499-BA0D-4487-8567-10377AF41A00.jpg
  19. Oct 4, 2022 at 6:56 PM
    #619
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Finished up my onboard air mod with my Viair 400p. I picked up the mount from Bannock Built. That thing is a bitch to install but it’s nice and solid once in. I drilled 3 new holes for the Viair brackets, and rotated the brackets on the pump itself 90°. The air coupler was stolen off my Viair hose and I put a male fitting on that to standardize the fittings a bit more like a normal air compressor. Power is supplied by my SP9100 for now, but may just get hard wired since the switch is on the side of the body.
    CFCEC73A-347F-48D8-8956-C1A1BA064B42.jpg 620BCC83-061F-4476-8683-5463914FF20E.jpg 9BF99281-B1C7-421E-B2D5-E5DC0A96B89A.jpg
  20. Oct 4, 2022 at 8:27 PM
    #620
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Which diode is that?
  21. Oct 4, 2022 at 8:29 PM
    #621
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  22. Oct 4, 2022 at 8:30 PM
    #622
    FrenchToasty
    Mo
    Bone stock
    The GM diode, I jammed one in today too
  23. Oct 4, 2022 at 8:36 PM
    #623
    e30cabrio
    Thanks
    FrenchToasty likes this.
  24. Oct 4, 2022 at 9:08 PM
    #624
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Guess I'll jam one in, too. Ordered
    Kinda enjoyed pulling out the NoCo every few weeks for a top-up.
    Closest thing I'll ever get to a block heater. May or may not pretend it's a 5.9 12v with the p-pump.
    I have an interesting imagination :rolleyes:
  25. Oct 5, 2022 at 12:50 PM
    #625
    e30cabrio
    Holy Amazon Prime next day service! I literally ordered the diode after Jake posted the link & just got it. I had the 50.00 one from Holland or wherever & only got 13.6.
  26. Oct 5, 2022 at 1:44 PM
    #626
    FrenchToasty
    Mo
    Bone stock
    Maybe my battery needed some juice, but this morning it got up to 14.8
  27. Oct 5, 2022 at 1:46 PM
    #627
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    So is there a point where the alternator puts out too much voltage? Or any concerns around frying the alternator from this?
    Mater likes this.
  28. Oct 5, 2022 at 1:48 PM
    #628
    FrenchToasty
    Mo
    Bone stock
    Hahah I guess I’ll find out, luckily I’m a worry some Walter, and replaced mine, so I have the spare in storage with @AT x AT hoard
  29. Oct 5, 2022 at 1:50 PM
    #629
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    FTFY
  30. Oct 5, 2022 at 2:32 PM
    #630
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Alternator will be fine, something else on the truck….eh you’ll find out the sensitive bits. But overall you’re gonna be a ok!
