The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Aug 7, 2022 at 10:15 AM
    #571
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Yup, eats my applicators every time I apply it. Looks good through.
  2. Aug 8, 2022 at 1:24 PM
    #572
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    I have a bunch of old sponges I used for tile projects that get cut up for tire dressing applicators. Not sure if is the most effective, but the price is right.
    Wallygator likes this.
  3. Aug 8, 2022 at 1:26 PM
    #573
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Fixed my bouncy light bar brackets. Not my best work, but it’s nice and solid now and I didn’t have to pull the bumper caps and valence off
    5594C11A-A4E2-4EEB-BD90-697F908853DA.jpg BB626BCD-2DA4-4F04-8160-CB41849FC19D.jpg
  4. Aug 8, 2022 at 1:55 PM
    #574
    TucsonTundra1794
    Anthony
    Tucson, AZ
    Which brackets are those?
  5. Aug 8, 2022 at 2:00 PM
    #575
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The main brackets that are on the bumper fasteners are Diode Dynamics that came with my 42" light bar kit. The smaller ones that I used for support are from my cheap 30" Amazon bar.
  6. Aug 9, 2022 at 7:15 PM
    #576
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Decided to go ahead and wire in the brake light trigger for the whip module. I forgot to grab pics, but at the back of the rear driver side door under the scuff plate, one of the smaller red wires is the lead for the 3rd brake light. I tapped it with a posi-tap and spliced it to the whip controller lead. Pretty nice feature to have.
    https://youtu.be/hMvMVJqZVjY
  7. Aug 9, 2022 at 7:17 PM
    #577
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    Oh damn, I like this one. :thumbsup:
  8. Aug 9, 2022 at 7:20 PM
    #578
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Blue!!! :cool:
    BlueRibbon4x4[QUOTED] likes this.
  9. Aug 11, 2022 at 6:25 PM
    #579
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Took some inspiration from @memario1214 painting wrapping his grille garnish and decided to paint mine today. I went with a satin black to match the grille and think this looks great now. The 3D printing material used faded over the last few years of desert sun, but roughing it up with a scotchbrite pad and hitting it with a few coats of Krylon prime and paint worked well.
    From before:
  10. Aug 20, 2022 at 1:38 PM
    #580
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  11. Sep 1, 2022 at 8:45 PM
    #581
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Picked up some used SPC UCAs for a deal. They were a little dirty but in good shape
    Removing the through bolt was a bitch and a half. I finally got the nuts loose using the two-wrench cheater method, but it was sketchy as hell.
    I’m picking up one of these next time I have a high-torque spec bolt on the docket
    Mueller-Kueps 745 100 Wrench Extender https://www.amazon.com/dp/B013SXTH04
    New arms went in pretty easy, then off to the shop for an alignment and fluid changes on the front and rear diffs and the transfer case
    The alignment ended up decent, but the steering wheel is off a few degrees to the left and there feels like a slight pull. I’ll probably take it back next week after “trail tuning” it this weekend…
  12. Sep 1, 2022 at 8:48 PM
    #582
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ve had random bursts of interference out on the trails with my Baofeng and pretty sure it’s something in the truck. Picked up this magnetic mount antenna to run on the hood and see if my reception is any better.
  13. Sep 1, 2022 at 8:53 PM
    #583
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Ever since installing my SP9100 I’ve missed having my rear window switch available behind the shifter. And since I already had the SDHQ card holder mount, I decided to use that and hack up the overhead console instead of spending another $170 on their 3D printed offering.
    And @abomb’s switch plate with rear window switch back where it should be. Switch blanks are on order… I’ve only lost one screw down those holes so far :mad:
  14. Sep 1, 2022 at 10:18 PM
    #584
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    That looks like the same antenna I have. Worked great at T2S. Much better range than the handheld antenna.
  15. Sep 1, 2022 at 10:30 PM
    #585
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
  16. Sep 2, 2022 at 9:21 AM
    #586
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Those are SPC ball joints, but I have never seen SPC arms that look like that. Those have gotta be pre-2015 at least! That's when I installed my first set on a tundra and there was zero smooth piping on them at all.
  17. Sep 2, 2022 at 9:37 AM
    #587
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Wonder if I got scammed with some Mevotech arms... Definitely see the difference now that you point that out.
  18. Sep 2, 2022 at 9:48 AM
    #588
    memario1214
    Colton
    Missoula, MT
    I didn't want to say that because I figured there was a chance that there was a previous design before my time. The bushings did look curiously fresh to me though.
  19. Sep 2, 2022 at 9:56 AM
    #589
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    For what I paid, I'm fine if that's what happened, but kinda sucks at the same time. Is there a part number stamped anywhere that I can look for?
  20. Sep 2, 2022 at 10:25 AM
    #590
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Punisher29073 likes this.
  21. Sep 6, 2022 at 11:24 AM
    #591
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Had some custom DT extension cables whipped up to let me move my chase lights between the front and rear stake pockets. The cables are 5.5 feet and are perfect for what I was wanting to do. I'll probably keep them mounted toward the cab most of the time, but I like the option of putting them near the back end for visibility, especially if we're doing a trail with elevation changes, where the cab-mounted lights can be hidden from view. The zip ties holding the connectors to the bed rails are temporary until I get the mounting clips for the female plugs.
    IMG_7134.jpg IMG_7267.HEIC.jpg IMG_7268.HEIC.jpg IMG_7269.HEIC.jpg IMG_7246.HEIC.jpg
  22. Sep 6, 2022 at 11:26 AM
    #592
    TucsonTundra1794
    Anthony
    Tucson, AZ
    I'm gonna steal this.
  23. Sep 6, 2022 at 11:33 AM
    #593
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    How long does the swap take? Do the stake pockets just pop out? Would there be a way to install a rivnut or something so it’s an unbolt/unplug scenario
  24. Sep 6, 2022 at 12:07 PM
    #594
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It's real quick and easy to swap out one bolt from the stake pocket tie downs:
    One will keep the assembly in place, and then the bolt through the light mount bracket gets it all back to normal.
    BlueRibbon4x4 and Mater[QUOTED] like this.
  25. Sep 6, 2022 at 12:53 PM
    #595
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Please for the love of all that is holy...use snap in grommets... :boink::boink::boink:
    300BLK and TucsonTundra1794 like this.
  26. Sep 6, 2022 at 12:57 PM
    #596
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    You mean bed liner isn't sufficient??
    Lol, they're on order and I have some wire loom acting as a grommet in the interim. I used up all my existing stock on some other stuff.
  27. Sep 6, 2022 at 12:59 PM
    #597
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    shopper's....
  28. Sep 6, 2022 at 12:59 PM
    #598
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    So far away... :boink:
  29. Sep 6, 2022 at 1:00 PM
    #599
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    yes you are.
  30. Sep 6, 2022 at 2:56 PM
    #600
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    That whole setup is fucking sexy.
