The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Apr 21, 2022 at 6:51 PM
    #481
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Installed the magic from @memario1214 known as HotTails yesterday. VERY pleased with this kit. Super simple to install and made a helluva difference in the back-end lighting on the truck.
    A8138A2E-732C-4C11-AAD4-A5CAB136CF46.jpg C783355B-8CC3-46ED-81A2-49D2E651D4C0.jpg 8041CF42-5012-4D9C-919C-2B4B2F0D10F4.jpg 8DB31F63-58F2-43CC-AC2A-D80016E40E0A.jpg
  2. Apr 21, 2022 at 7:41 PM
    #482
    Enjoihavok
    Enjoihavok New Member
    Erik
    Chandler,AZ
    My allergies just flared up looking at your driveway.
    but also the tails look good.
  3. Apr 21, 2022 at 7:44 PM
    #483
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    43D52D89-27F0-43D3-9227-3D80B53FF4E5.jpg Please sir, I want some more!
  4. Apr 21, 2022 at 8:03 PM
    #484
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    That’s mostly just sissoo trash, but my neighbors have a palo verde that can go straight to hell. I’m pretty excited the driveway at the new house has zero trees on top of it…
  5. Apr 21, 2022 at 8:04 PM
    #485
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  6. Apr 21, 2022 at 8:57 PM
    #486
    Enjoihavok
    Erik
    Chandler,AZ
    Those are the devils trees. Same though, I’ve got a few neighbors with them, and during these months when we get those strong random winds, my yard gets littered with those stupid yellow flowers.
  7. Apr 22, 2022 at 11:28 AM
    #487
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    MMMM.... YES :bananadance:
    I just cut a set of tails open this morning, and will be knocking out something similar to you. Finally! Might add a couple little bits of "flair" though, because YOLO.
  8. Apr 22, 2022 at 11:31 AM
    #488
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I was thinking about putting my chase lights in the tails where the square reflector is between the upper and lower bowls, but my confidence in getting those sealed up correctly is pretty low. Interested to see what you come up with.
    reywcms likes this.
  9. Apr 22, 2022 at 11:38 AM
    #489
    memario1214
    Colton
    Missoula, MT
    Guess the cat's out of the bag now... You literally read my mind.
  10. Apr 22, 2022 at 11:41 AM
    #490
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  11. May 8, 2022 at 4:15 PM
    #491
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Thought this morning was going to be an easy job of front brakes and an oil change. Nope. My jack somehow got jacked up (pun intended) during the move and decided it didn’t want to jack anymore, so brakes were out. Then what I thought would be a 20 minute oil change job turned into 5 hours after finding the filter housing seized after the last dealer oil change. Had to destroy the OEM plastic housing and drop my engine and cat protection plates to finally get the thing to spin off with some rotational persuasion with a hammer and screw driver.
    bulldog93 and BlueRibbon4x4 like this.
  12. May 8, 2022 at 4:20 PM
    #492
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Holy crap
    Mine was on tight, but I managed to get it free with an air impact after motherfucking it for a while.
    Put the aluminum one back on with a torque wrench…
  13. May 18, 2022 at 7:22 AM
    #493
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Following up after my oil filter housing shenanigans, I decided it was time for fresh hardware on the TRD skid plate. I bought the skid secondhand and it was missing the front two bolts and the shims for the top of the rear crossmember. I Jerry-rigged some various solutions over the last couple of years, but always ended up with creaking after a while. Everything seems tight and solid now, so we’ll see how it holds up.
  14. May 20, 2022 at 6:33 AM
    #494
    thedonn
    thedonn New Member
    Thank you for posting this list. It made it very easy for me to get what I need for my compressor install!
    BlueRibbon4x4 likes this.
  15. May 20, 2022 at 10:04 AM
    #495
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Sucks, sorry. I had the same issue on my first OC on the Sequoia. Crappy aftermarket plastic housing that had no center support doo hickey, I had to buy a full OEM although I had a metal housing I never used on the Tundra (it already had it) but you can't get the long doo hickey on it's own. :(
  16. May 20, 2022 at 10:13 AM
    #496
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Luckily I already had the metal housing on hand and ready to go, and the center support survived my Hulk Smash fit of rage. The metal housing I got came with the shorter support for the 3.5L, so I’m guessing you’d have to buy the Tundra plastic housing to get that, right?
    Wallygator likes this.
  17. May 20, 2022 at 10:15 AM
    #497
    e30cabrio
    Yup, that's what I did. Now I have a plastic housing I will never use.
  18. Jun 6, 2022 at 7:10 AM
    #498
    thedonn
    thedonn New Member
    Thank you for posting this list. i just put mine together and this was a big help! out of curiosity what are you using to air down?
  19. Jun 6, 2022 at 7:48 AM
    #499
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’m using some cheapy automatic deflators. They work pretty well in my experience but I’ve heard they can be inconsistent or hard to get dialed in. Right now I’m running them at 15 psi but need to bump that up since I usually end up doing some higher speed stuff at some point during a trail run.
    Boulder Tools Tire Deflators and 80 PSI Tire Pressure Gauge - Adjustable, Automatic for car, Truck, Motorcycle https://www.amazon.com/dp/B01M0L7JS2
  20. Jun 13, 2022 at 3:31 PM
    #500
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    On top of the brake job I still haven’t gotten to since moving to the new house, I now have two other projects to knock out some time soon when the weather cools off a bit - Durobumps for the front end and Rago dash plate for inside
  21. Jun 13, 2022 at 3:35 PM
    #501
    memario1214
    Colton
    Missoula, MT
    You didn't buy your Durobumps from me!? WHY I OUGHTA! :p
    TRDFerguson[OP] likes this.
  22. Jun 13, 2022 at 3:36 PM
    #502
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I didn’t know you had them!! Shit, I should have checked. My bad :oops:
  23. Jun 13, 2022 at 3:37 PM
    #503
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    To use a support plate or to not? :monocle:
  24. Jun 13, 2022 at 3:39 PM
    #504
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ll be getting the rear bump stops soon, definitely going through you on those. And still need to order UCAs, but that’s moved down on the list for a little while.
  25. Jun 13, 2022 at 3:40 PM
    #505
    memario1214
    Colton
    Missoula, MT
    I'm just playin'! We do stock them now though. Relatively new addition to the line card.
  26. Jun 13, 2022 at 3:40 PM
    #506
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ve heard fender washers do just fine, so that’s my plan for now. I’m not mounting tablets or anything, so that should do just fine for my use case.
  27. Jun 14, 2022 at 6:50 PM
    #507
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Started to pull apart the front end to do brakes this morning but decided it was too damn hot out. Settled on getting the Durobumps on for today. My quick test drive over the speed bumps on my street have me happy with the results.
    45197240-1961-4AFA-8D0E-E8332EF78736.jpg FCA5DC8F-BB6C-44E6-A9EE-CE1CD5FB7BAB.jpg 18F1D999-C64A-4C74-8BDA-2ACBEDA40986.jpg
    bulldog93, Wallygator, Gfgneo and 7 others like this.
  28. Jun 15, 2022 at 8:15 PM
    #508
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Since my kid decided he needed to brave the heat and play basketball in the driveway, I figured I could knock out the Rago plate install. Pretty easy mod and should allow me to spend way more money than I want on Ram mounts and other shit…
    3535AA13-CDF4-4157-8336-28D90B4C47EC.jpg F5AF9B60-B368-4D47-B835-000C0FCC901F.jpg
  29. Jun 15, 2022 at 8:21 PM
    #509
    AZTundra
    Paul
    Phoenix, AZ
    There are some mounts available for the Baofeng also.
  30. Jun 15, 2022 at 8:23 PM
    #510
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Oh, I know… seems like they have mounts for just about everything lol
    :spending:
    AZTundra[QUOTED] likes this.
