The S.S. TRDFerguson: Captain’s Log
Discussion in '2.5 Gen Builds (2014-2021)' started by TRDFerguson, Mar 25, 2021.
  1. Apr 9, 2022 at 6:14 PM
    #451
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Great cooler tie down idea. Which d rings are these?
  2. Apr 9, 2022 at 6:29 PM
    #452
    TRDFerguson
    TRDFerguson [OP] SSEM #99/RGBA #8-ish?/It’s a funny name.
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Thanks! I used these off Amazon:
    JCHL Cargo Tie-Down Anchors, 10PCS V-Ring 2" Diameter Steel V-Ring Bolt On Trailer Anchor for Cargo on Trucks Pickups Trailers Flush Mount TieDown Anchor https://www.amazon.com/dp/B07MB985GW
    I knocked the washers off the bolts by putting the bolt head into a 1.5” pipe and hitting the end with a 3lb hammer. It’ll roll the retaining ridge on the bolts and you can sandwich the D-rings between the washer and bolt.
    Dantdodge likes this.
  3. Apr 9, 2022 at 6:35 PM
    #453
    SpooledReel
    RickyP
    Spanish Fort, AL
    Perfect, thanks!
  4. Apr 9, 2022 at 8:39 PM
    #454
    Dantdodge
    Dantdodge New Member
    Danny
    Tampa
    2018 tundra sr5 crewmax trd 4x4
    Stock trd off road
    Lol fellow IT guy here. Build looks great so far tagging along!
    FrenchToasty and TRDFerguson[OP] like this.
  5. Apr 10, 2022 at 9:20 AM
    #455
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Very nice! :headbang:
    Where are you mounting that sucker? SwitchPro or rear window switch.. decisions decisions :notsure:
  6. Apr 10, 2022 at 9:24 AM
    #456
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Unfortunately the rear window switch is going back to its home. I am planning on adding an autoloc on it though, so hopefully auto-up/down will make me forget the pain…
    The SP is going in the SDHQ card mount in that spot.
  7. Apr 10, 2022 at 9:27 AM
    #457
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    This is right down the street from me. Let me know if you want me to pick it up and ship it out..
    https://offerup.com/item/detail/1359328067?q=sdhq
  8. Apr 10, 2022 at 9:28 AM
    #458
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ve already got the stuff for mine, but that’s a pretty sweet deal.
    Mater[QUOTED] likes this.
  9. Apr 10, 2022 at 10:51 AM
    #459
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Have you considered putting it up by the overhead console? That’s where I’m putting mine.
  10. Apr 10, 2022 at 10:57 AM
    #460
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Yep, your post about it on your build thread had me considering it. I went back and forth a bit, but by the shifter ended up winning out. I’m keeping the cable extension for the rear window switch and the 3 switch panel on hand, just in case I decide to redo it later.
  11. Apr 10, 2022 at 11:02 AM
    #461
    1794TX
    Steven
    N.TX
    '20 1794
    I had seen in someone's thread, and had considered putting the rear window switch on the vertical surface just under the console lid. It would cost quite a bit of reconstruction and loss of space in the console, and I have a safe with supports that get in the way of any of that, but it's a possibility. Wouldn't work so much for switches you actually need to look at to coordinate punching them; but the rear window isn't that.
  12. Apr 10, 2022 at 11:16 AM
    #462
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I looked into this as well. Like you said, there's a lot that would need to go into retrofitting to that spot. I'm still toying with the idea, most likely seeing if I could make it work to the right of the card holder spot behind the cup holder, in the same orientation as it is with the 3-switch panel.
    BlueRibbon4x4 likes this.
  13. Apr 10, 2022 at 11:28 AM
    #463
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    I think the SP right where your cell phone mount is would be perfect. But that’s just my $.02. Might be a little “too in your face”
    TRDFerguson[OP] likes this.
  14. Apr 10, 2022 at 12:39 PM
    #464
    1794TX
    Steven
    N.TX
    '20 1794
    This is likely your switch plate candidate. Looks tight. Not sure how it would look or work mechanically to cut that plate so it only fit one switch, and turn it sideways. Spitballing, but I wonder how tight the fit is down in the channel to the right of the cup holder? Might have to go back to its original home after all...
  15. Apr 10, 2022 at 5:39 PM
    #465
    RainMan_PNW
    Casey
    Clark County, WA
    That part holds three switches. I have one in my parts box from my 2008.
    Doing a single switch blank is probably gonna have to be something custom.
  16. Apr 10, 2022 at 7:44 PM
    #466
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I’ve found a few options for single switch housings, but not for the Toyota size in our trucks. It’ll definitely be a custom project if I end up going that route.
    BlueRibbon4x4 and 1794TX like this.
  17. Apr 10, 2022 at 10:00 PM
    #467
    helidave
    helidave Hellacopter
    flagstaff
    2015 DC 4x4
    If you find the .stl file for one you like, I can 3d print it and bring it to t2s if you want.
  18. Apr 11, 2022 at 6:34 AM
    #468
    RainMan_PNW
    Casey
    Clark County, WA
    I’ve got an STL of the socket for a single switch, but it would need to be then designed into an actual housing.
    My concern with printing anything with a “flange” is that the print lines lack a lot of structural strength at the connection
    TRDFerguson[OP] and 1794TX like this.
  19. Apr 11, 2022 at 8:31 AM
    #469
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I'd probably just two piece it and epoxy the flange to the top of the housing. Still not sure it's even worth it to go that route, but it's a fun exercise to thing about.
    RainMan_PNW[QUOTED] likes this.
  20. Apr 11, 2022 at 7:54 PM
    #470
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Had some multitasking time while working today, so did some of the prep work for the SP9100 install. I should have the wiring for the lights in a good enough spot that splicing all those in should be pretty straightforward. As long as the wife isn’t cracking the whip on getting the house packed, I think I can get it knocked out while on calls tomorrow.
    01348094-A681-4B29-A665-F85D9D9E8846.jpg 9D5B153A-8FB2-40D7-898E-438D047798EB.jpg 2F7A3CD2-735A-4356-AEDA-D100A6CF4C64.jpg 2E5C565D-BA9A-4A4E-BF8B-B14C003B2785.jpg
  21. Apr 11, 2022 at 8:30 PM
    #471
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Has that Microsoft keyboard crapped out on you? I had 2 go south before I switched back to Logitech
    SP looks good!
  22. Apr 11, 2022 at 8:34 PM
    #472
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It’s been holding up pretty well. I had an issue where the space bar was a little flaky, but there ended up being some crumbs or dirt underneath, so popping that off and cleaning it solved that problem. I think I’ve had it for around 6 or 7 years now…
  23. Apr 12, 2022 at 5:51 AM
    #473
    1794TX
    Steven
    N.TX
    '20 1794
    Too bad there isn't a relay available for the SP that could replace the rear window switch. Might take up two of the buttons...
    vanthesupreme likes this.
  24. Apr 12, 2022 at 8:48 AM
    #474
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    So I had considered this as well, but thought running wires just for that would be a PITA... but I'll have the harness wires from my existing switches sooooo might steal those...
  25. Apr 15, 2022 at 1:15 PM
    #475
    TRDFerguson
    Jake
    2018 MGM CrüeMax
  26. Apr 15, 2022 at 1:51 PM
    #476
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
  27. Apr 15, 2022 at 1:58 PM
    #477
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    :rofl:I've got a light bar sitting in my garage that I need to find a spot for. Next one will probably be an S8 in the hood bulge or some rear bumper lights.
  28. Apr 15, 2022 at 7:16 PM
    #478
    RainMan_PNW
    Casey
    Clark County, WA
  29. Apr 15, 2022 at 7:22 PM
    #479
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    It was surprisingly faster than I thought it would be. But I also had all my devices prepped ahead of time.
  30. Apr 19, 2022 at 10:51 AM
    #480
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Picked up a souvenir from Box Canyon this weekend - I heard a rock rattling and scraping inside the brake dust shield after going through a wash. I was hoping it would eject on its own, but after 20 or so miles of driving it was still there. Took about 20 minutes to pull the rotor and get it out.
    4E3D66BF-E605-4741-85E0-B4B0B04AD352.jpg 302520DA-C3CB-40FE-A020-1B22CFCCD55A.jpg
