The proper way to set the transmission fluid level.
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ruggybuggy, Jul 24, 2021.
  1. Oct 8, 2023 at 10:55 AM
    #61
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    No. The fill plug is a rubber gasket the drain and check plug are a smaller diameter than the differentials.
    Just finished doing mine
    rodm1[QUOTED] likes this.
  2. Oct 15, 2023 at 3:58 AM
    #62
    nobodyintexas
    nobodyintexas What?
    South of Houston
    S/C'd 2020 White 1794 Tundra
    drain & fill this weekend.
    dropped valhalla cat shields...hardest part.
    pinned thermostat
    drained 4 qts
    filled it with 4.5 qts
    warmed it up to 105' (via Scangauge 3)
    while running - open check valve ~1/2 qt came out till trickle.
    put the cat shields back on.
    all is well...
    except....I forgot to unpin the thermostat. not dropping the shields again!.. I guess we run cool for now
    Totmacher, ATV25 and Joe333x like this.
  3. Oct 28, 2023 at 3:02 PM
    #63
    rodm1
    rodm1 New Member
    Did my change today I feared the temp would rise to fast and over shoot the temp. Day high temp whose 50 trans temp started at 75 it took several minutes to reach temp not a big deal easy to hit proper temp.
    Dues the ATF thermal degradation need to be reset? I've read it kind of reboots the trans ECM
    Joe333x likes this.
  4. Dec 3, 2023 at 5:39 PM
    #64
    draker
    draker New Member
    2017 Tundra 1794 Edition (White)
    Just did this service today thanks to this thread and the factory service manual. I'll probably do it again at my next oil change and then call it good. I know the youtube dude said don't do it until it's red, or at each oil change. This may have been the first time it was changed and the truck is at 81k. I bought at 74k. I think once more is probably a good idea. Then every 20k or 6 years after that.
  5. Dec 4, 2023 at 5:46 PM
    #65
    rodm1
    rodm1 New Member
    I did my first change at 60k and there where lots of metal shavings in the oil. Probably should have changed much sooner but under warranty and didn't.
