The Pigeon Pad - Squatting Pigeon's Build Thread and B.S. Hangout Spot
Discussion in '2.5 Gen Builds (2014-2021)' started by Squatting Pigeon, May 5, 2019.
  1. Aug 22, 2020 at 9:01 PM
    #451
    Squatting Pigeon
    Squatting Pigeon [OP] Squattingpigeon.com Staff Member
    Holden
    North Texas
    4Runner | GR Corolla
    Thanks!
    Yes I had the suspension all done by the time I put the wheels and tires on. I dont think you'd be able to fit this setup on a stock suspension, it'll be too close.
    T-Rex266 likes this.
  2. Sep 15, 2020 at 4:22 PM
    #452
    KENNY
    KENNY New Member
  3. Sep 15, 2020 at 4:41 PM
    #453
    Squatting Pigeon
    Holden
    North Texas
    :anonymous:
  4. Oct 4, 2020 at 4:07 PM
    #454
    Squatting Pigeon
    Holden
    North Texas
    Small mod Sunday!
    @ICS FAB rear AMPS panel installed for the kiddo.
  5. Oct 4, 2020 at 4:17 PM
    #455
    Squatting Pigeon
    Holden
    North Texas
    Mini write up on the rear AMPS panel:
    ICS’ instructions:
    Using a panel popper, remove the rear center console trim by pulling back on the bottom right corner. Once you unclip the right and left sides and work your way up, slightly left up on the rear cover as the top top clips snap in at an angle.
    Then just lay the cover down on the floor as you don’t need to remove the cig lighter connector
    Assemble the mount, the two side tabs go inside the top piece, not on the outside.
    Now, the side pieces are cut to fit the angle on the rear or the center console.
    Place the mount about an inch high from the top of the center console making sure the lid opens properly, mark your holes
    Drill the four holes and bolt it in
    Snap the rear center console cover back in place
    Step one, pop the panel off using a plastic panel removal tool.
    Step two, assemble the AMPS panel and figure out where you want it to sit. Use some masking tape to hold it in place and mock up the final position. I ended up going with 1-3/4” up from the flat piece of plastic where the front panel sits flush with:
    Turns out that was a little tight, but it worked out just fine.
    Step three, mark your holes and drill:
    12C36D87-9510-49AD-89E1-85563442A831.jpg 3CF43FEA-C381-45F9-BDFB-E900BB1E678E.jpg
    Step four, bolt that sucker in:
    51FCC73F-8C20-4B78-870C-56D49E4C2190.jpg AD021C8B-E2BE-4D1E-841C-CAEF44AD5BC1.jpg
    You’ll see that I sliced a little off the bottom washer. This is because I mounted everything a touch lower than I should have. Nothing some tin snips couldn’t take care of :sawzall:
    Step five, reassemble the rear face of the console, attach your RAM mounts and enjoy!
    0E729153-B08C-4B11-B5F9-3D4AE67A8601.jpg 11F1069A-6E8E-4342-B66B-6F1967A4C724.jpg 382A56E4-AB3F-416C-B22B-A21BFDF56B36.jpg
  6. Nov 12, 2020 at 3:07 PM
    #456
    Pangaea
    Pangaea New Member
    BC
    2021 Cement Tundra CM TRD Off Road Premium
    Nice! I'm doing this next! Love your build. It's causing me to spend way too much money...
    About 10 minutes ago I just ordered the Cali Raised side Molle panels. :spending:
  7. Nov 13, 2020 at 5:33 AM
    #457
    Squatting Pigeon
    Holden
    North Texas
    That’s what it’s all about!
    Glad to hear I inspired you :D
    WillTunBlack20 likes this.
  8. Nov 13, 2020 at 5:35 AM
    #458
    War Machine
    War Machine SSEM # 5 3MW
    Looks like I’ve missed a lot in this thread.
  9. Nov 13, 2020 at 5:57 AM
    #459
    Squatting Pigeon
    Holden
    North Texas
    Took her out to the Ouachita National Forest in Arkansas last weekend.
    DC379A11-7439-4669-888E-D7BC85B040F0.jpg EAE86C10-B43C-4E87-9A3E-B568E4D39014.jpg 2BCA3346-BE3A-4B16-B72D-B8607381DA83.jpg B913C12D-F4B3-4670-985F-B8AEE200ED9E.jpg 8AA2C5D4-17DE-4BCB-95AF-1528CB45C508.jpg 8F6DC923-CFE8-4C46-8283-CE945BB2DD0B.jpg 14F9D846-174B-4066-8D25-A65ECD72E4F2.jpg EE183CEC-9CD4-4624-B2F3-4AFED0F499E4.jpg 0DD92E49-14E5-4E9B-B5F4-A4673C2667BF.jpg 3FF68819-1A6E-4741-9919-AA680CB60446.jpg E21EBBBA-4240-42DE-8683-169B3F6A4D6B.jpg 571CB91B-F01C-4E9B-BB8D-368C032F9A9B.jpg
  10. Nov 13, 2020 at 5:58 AM
    #460
    Squatting Pigeon
    Holden
    North Texas
    You’ve been missed!
    War Machine[QUOTED] and BTBAKER like this.
  11. Nov 13, 2020 at 6:28 AM
    #461
    Wallygator
    Subscribed!:thumbsup:
    Squatting Pigeon[OP] likes this.
  12. Nov 13, 2020 at 6:50 AM
    #462
    Squatting Pigeon
    Holden
    North Texas
    :wave:
    Wallygator[QUOTED] likes this.
  13. Nov 16, 2020 at 7:16 AM
    #463
    War Machine
    My homeland!
    https://youtu.be/ZlOE_DMTlFs
  14. Dec 27, 2020 at 1:44 AM
    #464
    JoshR324
    JoshR324 New Member
    North TX
    How do you like those trail series sliders as far as using them for a step and door ding protection? I’m debating on the trail version vs step currently. Mainly need the step for the wife and kids and it would be nice if the trail version does a good enough job of it along with door ding protection.
  15. Dec 27, 2020 at 6:06 AM
    #465
    Squatting Pigeon
    Holden
    North Texas
    They’re great! My 6 year old has no issue using them as a step, and come to think of it I haven’t had any door dings since they got installed. I was t-boned a couple months ago and the sliders saved me from needing rocker panels. If you want even more of a stepping surface they have the ‘step’ version which sticks out another couple inches.
    These things are beefy too. When I got hit, I needed $3k in repairs and they didn’t even have to touch the sliders. Plus I had the full weight of the truck on them going over some rocks in Colorado back in August.
    For the money, I don’t know why anyone buys steps instead of these :thumbsup:
  16. Dec 27, 2020 at 12:41 PM
    #466
    JoshR324
    JoshR324 New Member
    North TX
    Thanks for the reply. I think that seals the deal for me. Hopefully they run a sale soon so I can grab a set for local pick up.
  17. Mar 3, 2021 at 5:08 PM
    #467
    RobertD
    Robert
    DFW, Texas
  18. Mar 4, 2021 at 3:15 AM
    #468
    Squatting Pigeon
    Holden
    North Texas
    :spy:
    RobertD[QUOTED] likes this.
  19. Mar 4, 2021 at 3:45 AM
    #469
    Zero One Actual
    Does this thread have pelican cases?
  20. Mar 4, 2021 at 5:04 AM
    #470
    Squatting Pigeon
    Holden
    North Texas
    Why? You looking for one?
    I might know a guy.
  21. Mar 7, 2021 at 6:09 AM
    #471
    Squatting Pigeon
    Holden
    North Texas
    @Caliraisedled roof rack went on Thursday, and I torture tested it a bit yesterday :mudding:
    FE98EA05-CB2D-4849-838C-A409E0E2521E.jpg 2906D131-8975-4D5A-AB1B-F8A2FE479A41.jpg 1D06BFAE-01BA-46CF-9EDC-33CB7999AB92.jpg 687238CE-4FE8-4478-8573-3D981962E987.jpg EB9EF160-EF79-454B-A874-3BCAF8DCCE46.jpg 0D6C2EF6-DA88-46F5-9922-4B2D5C40BCF0.jpg
    A65C65C6-5E7F-4B6E-B707-1AA593449A4E.jpg F816602C-3D40-4459-9DD7-DF5FB1BCC721.jpg
  22. Mar 8, 2021 at 3:45 PM
    #472
    Squatting Pigeon
    Holden
    North Texas
    Couple glamor shots from the weekend courtesy of @Caliraisedled. More to come!
    32BB74AE-8347-4F9B-AEDC-26F5C7D54348.jpg 116FBC70-44BA-4F00-8B5A-EF29C0084606.jpg
  23. Mar 8, 2021 at 3:53 PM
    #473
    Squatting Pigeon
    Holden
    North Texas
    And a teaser video while I get stuff off the GoPro
  24. Mar 8, 2021 at 4:13 PM
    #474
    Outbound
    Aaron
    Northern Alberta
    Sick bro.
  25. Mar 8, 2021 at 4:15 PM
    #475
    Squatting Pigeon
    Holden
    North Texas
    Thank you sir :fistbump:
    Outbound[QUOTED] likes this.
  26. Mar 8, 2021 at 4:23 PM
    #476
    Black Radness
  27. Mar 8, 2021 at 4:32 PM
    #477
    Squatting Pigeon
    Holden
    North Texas
    Gotta represent:cool:
  28. Mar 8, 2021 at 4:36 PM
    #478
    War Machine
  29. Mar 8, 2021 at 4:37 PM
    #479
    Squatting Pigeon
    Holden
    North Texas
    jewsNbrews and Black Wolf like this.
  30. Mar 8, 2021 at 6:33 PM
    #480
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Squatting Pimp!
