The old front leveling kit works on the 2022 Tundra!
Discussion in '3rd Gen Tundras (2022+)' started by brichoux, Dec 16, 2021.
  1. Dec 18, 2021 at 6:36 PM
    Diablo169
    Diablo169 ROKRAPR
    Max
    Santa Cruz
    06 Double Cab 360k+
    2” Lift, Bilstein 5100’s and 885’s second notch, Rear 5100’s Icon 3 Leaf Pack and Firestone Air Bags w/Daystar Cradles. Spider Trax 1.25” Wheel Spacers, 4Runner Pro Wheels, Falken AT3W 285/75r17 (34x11).
    Too funny. Fully new platform, and has the same coilover mounts. I guess if it ain’t broke don’t fix it.
  2. Dec 18, 2021 at 7:29 PM
    PayItOff428
    PayItOff428 New Member
    Jake
    The United State of Texas
    2012 SR5 Double Cab 4X4
    Because it has a 100k miles on it without a single geometrical issue you dumb fuck. Get it now?
  3. Dec 18, 2021 at 7:39 PM
    PayItOff428
    Jake
    And yes I married both brands because I replaced the Procomp front spacer and stock coilover with a full Rough Country coilover at 96k miles. So next time stay quiet or remove all doubt you jackass.
  4. Dec 18, 2021 at 7:44 PM
    twintundra31719
    twintundra31719 New Member
    NV
  5. Dec 18, 2021 at 7:45 PM
    Cummins3500
    Cummins3500 Never finishes.....
    Logan
  6. Dec 18, 2021 at 7:55 PM
    PayItOff428
    Jake
    I didn’t mean to high-jack the thread guys. I’m gonna lay low now and let the thread get back on track! Much love to those who know spacer lifts are no big deal!
    brichoux[OP] likes this.
  7. Dec 18, 2021 at 7:56 PM
    twintundra31719
    NV
    If it’s used for on road purposes only spacer lifts usually are just fine
    MrDirtjumper and DexterL like this.
  8. Dec 18, 2021 at 8:51 PM
    brichoux
    brichoux [OP] New Member
    My bad! You are right. It was my 285/65/20s that were 34.8” x 11.5”. Not the 285/60/20s.
    joonbug[QUOTED] likes this.
  9. Dec 18, 2021 at 9:12 PM
    sn_85
    sn_85 New Member
    Boise
    2006 DC Tundra 4WD, 2013 Land Cruiser, 2022 RAM 2500 Bighorn
    I’ll put it this simply for you in more civil terms. Running a spacer lift doesn’t matter to you because you clearly don’t off road your truck. The most wheeling you might encounter is a curb at starbucks. Spacers are fine for a pavement pounder although I bet your ride quality is compromised and worse than stock. A 6” spacer block however is a huge detriment to anyone who off-roads. Putting that much lift on severely increases your CV angles, throws suspension geometry off, and you’ve essentially maxed out your down travel before any off camber or flexing situations. Every washboard bump is probably slamming your arms on the bump stop. Very few people that use their trucks for off-road use go above a 3” lift even with aftermarket suspension.
    If your goal is a redneck lift or the hawaii bruh look then a 6” spacer lift is fine but there are zero tangible benefits. On road and off road ride quality suffers in every way. So please tell me what benefits or improvements your 6” spacer lift provides? The answer is none other than vanity. Point being, you’re the last person that should be giving out suspension advice and what is within acceptable tolerances.
  10. Dec 19, 2021 at 7:12 AM
    PayItOff428
    Jake
    @sn_85 I was an asshole last night for no reason other than too much Scotch! My apologies for the harsh words and being someone I try and not be on forums. Much love and Merry Christmas to you and your family.
  11. Dec 19, 2021 at 7:24 AM
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    Was it at least good scotch?
    JLS in WA likes this.
  12. Dec 19, 2021 at 7:30 AM
    PayItOff428
    Jake
    It sure seemed like it!
  13. Dec 19, 2021 at 9:19 PM
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
  14. Dec 24, 2021 at 8:24 AM
    brichoux
  15. Feb 15, 2022 at 7:00 AM
    QUINTAR864
    QUINTAR864 New Member
    What spacer kit was installed?
    The Rough country kit is back ordered and the date keeps moving forward. We brought in a fabtech kit for the 2021 tundra, but there is a crazy angle on the top of the spacer and my techs feel that it is too much.
    typically we always installed the 3"f 2" rear readylift kit, so my techs are very weary about the extreme angle on the top of the spacer.
    Do you recall if there was an angle on your kit and what brand it was?
  16. Feb 15, 2022 at 2:56 PM
    brichoux
    I don’t recall the brand of mine, but it is exactly like this one. There was no angle on my kit, it was flat/even on the top and bottom. Westcott Designs made a front and rear kit after I put this one on. Their kit looks great. Check out their site. I ordered the rear only from them since I already have the front done and am waiting on it to get here.
    https://westcottdesigns.net/product/2022-toyota-tundra-preload-collar-lift-kit-new/
  17. Feb 15, 2022 at 3:00 PM
    brichoux
    Here is a pic of the front spacer installed.
  18. Feb 16, 2022 at 1:56 PM
    KroppDuster
    KroppDuster A normal guy trying to survive this crazy world
    Here. There. Everywhere.
    2021 SR5 TRD Off Road - Cavalry Blue
    Bilstein 5100s
    I called a pivot and decided to go with the Dynofit 2" leveling kit instead of the Rough Country. The more I thought about it, I like the one-piece design better than the welded design of the RC.
    Plus, I'm 99% sure, with the 2" spacer I don't have to cut the top strut bolts so I can go back to stock if needed. Can anyone confirm that?
