The official "What maintenance schedule are you following" for all things NOT oil related thread
Discussion in '3rd Gen Tundras (2022+)' started by Eurodriver, Sep 18, 2023.
  1. Sep 18, 2023 at 7:34 AM
    Eurodriver
    Eurodriver [OP] New Member
    I have been searching and I cannot find a consolidated answer. So far, the only rigid schedule I have followed is that I changed the spark plugs at 40k and 80k. The owners manual is very vague on a lot of critical items. Lots of "Inspect", but I just noticed that based on a severe driving schedule (I think I qualify) I should have changed the diff and transfer case fluid every 30k miles. Whoops. But it doesn't make a whole lot of sense. For example, why does driving on a dusty road change the differential fluid interval from infinity to 30k per the manual?
    Also, why are guys changing their engine oil so frequently but not other fluids? A transfer case isn't cheap... and the transmission - never change. Really? Really? That seems insane.
    @ryanwgregg
    ryanwgregg and ColoradoTJ like this.
  2. Sep 18, 2023 at 7:46 AM
    I agree. Never changing the transmission fluid is crazy. My truck specs the fluid should be changed out at 90k miles. I have done it 3 times already or about every 1.5 years.
    We don't see it often here, but the old 6 speed can run you 6-8k for a new unit. The 10 speed is surely more expensive.
    For the transfer case and differential question:
    -dusty/dirty roads you are more likely working the truck.
    -there is a breather on top of the axle. Not really a "sealed" unit.
    -towing you are heat cycling. Towing 10k with your 2023 truck...be interested in knowing the casing temp.
    ryanwgregg likes this.
  3. Sep 18, 2023 at 9:09 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    I'll admit, I'm guilty of more frequent than recommended oil changes, but have mostly neglected the diff, trans, and t-case fluids on my previous 2008 and 2015 Tundras until they were north of 100K miles. I also live 7 miles from the nearest paved roads, and our dirt county roads get very dusty and muddy at times. It never caused any problems, but I plan to be more vigilant with maintenance on my 2023.
    Can anyone tell me what a Toyota service center typically charges to replace the diff, trans, and t-case fluids on these new trucks?
  4. Sep 18, 2023 at 11:10 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    I'm going to follow the severe driving schedule. I have short commutes (15 miles) one way and theyre mostly on broken down asphalt. 2wd here so my maintenance is cheaper than you 4wd folk
  5. Sep 18, 2023 at 5:00 PM
    machd08
    machd08 New Member
    CLARENCE
    Sumter, South Carolina
    2025 Land Cruiser/Land Cruiser
    I made this excel spread sheet, from the service required in one of the books that came with the truck. Hope this helps out.
