The low tire presure sensor light is blinking?
Discussion in '2nd Gen Tundras (2007-2013)' started by 29hudson, Sep 27, 2021.
  1. Sep 27, 2021 at 2:13 PM
    29hudson
    29hudson [OP] New Member
    The low tire presure sensor light is blinking on my 2007 Tundra? I checked the presure and all 5 tires are good.
    The owners manuel only says to take to the dealer.
  2. Sep 27, 2021 at 2:14 PM
    Most likely the batteries in the sensors. They average around 10 years of life.
    jhardy1979 and (deleted member) like this.
  3. Sep 27, 2021 at 2:18 PM
    29hudson
    Thanks!
  4. Oct 2, 2021 at 10:54 AM
    LittleTundra
    LittleTundra New Member
    Oregon
    yeah, I agree to the previous post on the batteries in the TPMS. If you do end up needing new ones, I got Discount Tires to price match the Amazon ones for $20 each. However, that is usually when I got a new set of wheels and tires with them, but it's worth a try to ask.
  5. Oct 2, 2021 at 10:13 PM
    Rph74
    Rph74 New Member
    Springfield,MO
    2007 Tundra Crewmax Limited Silver/Redrock
    https://www.tpms.com/Toyota-Tundra-OEM-TRW-TPMS-Sensor-p/t4701-toyota-tundra.htm
    1 or more of your TPMS sensors are bad. You can go to any tire shop and they’ll replace the sensor(s) that are bad. Probably $75-$100 each out the door. Or if you’re due for new tires soon you can just put black tape over that light and replace the sensors at that time.
    I just bought these for my 07 a couple of weeks ago. They’re made by TRW, the OEM maker of our tpms sensors. If you look up OEM Toyota sensors, TRW is printed on them. $39 each and Sam’s club was able to install and program them. Fwiw, I had bought Denso Tpms sensors for my 06 Prius, and neither Sam’s nor a local tire shop could program them. The Dealer ended up having to do it, and even then it was tricky for them. Knowing this, I asked for recommendations on which sensors to buy for my Tundra. They said they’ve always been able to program OEM with no issues, other aftermarket brands are hit or miss for some reason.
    Rodtheviking likes this.
  6. Nov 25, 2021 at 3:16 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I joined to see what is possible
    costco is/was $65 each tpms installed. cheapest i found calling around. I still had the flash after i replaced all my tpms on the tires.
    theres also a tpms signal sender under your headliner part is 89760-0c010 or 89760-0c020. They are super expensive but turns out you can get one from 2011-2015 sienna. 89760-08020 you just swap out the electronics in the box with your factory box and reinstall it. takes two torx screws to open it up. super easy and found one on ebay for $30 shipped.
  7. Feb 20, 2022 at 12:11 PM
    Bgkahuna11325
    Bgkahuna11325 New Member
    Gene
    2011 Toyota Tundra SR5 Crewmax
    Can the TPMS batteries be replaced? Does anyone have a picture of the TPMS unit used in the 2011 Tundra Crewmax 5.7?
  8. Feb 20, 2022 at 1:29 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    i believe they are sealed units.
    bfunke likes this.
  9. Feb 20, 2022 at 2:09 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    The batteries cannot be replaced
  10. Feb 20, 2022 at 3:08 PM
    Kurt7700
    Kurt7700 New Member
    Kurt
    Ocala, FL
    2009 Tundra DC V6
    A little piece of black tape to cover that light works wonders! That whole system is a scam.
  11. Feb 20, 2022 at 8:51 PM
    TunaDr
    TunaDr New Member
    2007 Tundra
    I think between replacing the tpms and the receiver it will fix over 98% of the people who ever got a tire pressure light. swapping out the receiver was only figured out in the last year on a different forum and i shared it on here.
  12. Feb 22, 2022 at 1:40 PM
    Jeff_5_7
    Jeff_5_7 New Member
    Jeff
    Houston Tx Area
    shared it where? I would like to read more about this swapping out the receiver. Do you have the original post from who figured it out?
  13. Mar 1, 2022 at 12:15 AM
    TunaDr
    TunaDr New Member
    2007 Tundra
    pnw tall trees likes this.
  14. Mar 1, 2022 at 6:45 AM
    dels67malibu
    dels67malibu New Member
    Mine is doing the same thing, I am just waiting until I replace the tires and I am going to put new sensors on all four tires.
  15. Mar 1, 2022 at 9:06 AM
    pnw tall trees
    pnw tall trees New Member
    Pacific Northwest
    07 Limited Crewmax
  16. Mar 3, 2022 at 7:51 AM
    dels67malibu
    Since it has been warmer for the last two days, my light has gone off. Seems like the colder weather was affecting it.
  17. Mar 13, 2022 at 11:29 AM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    That’s strange that weather seemed to affect it in that manner.
    I had similar in my daily a Kia Sportage and the dealer just had to reset the system
  18. Mar 13, 2022 at 6:30 PM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Mine will start blinking from time to time. Always when single digits, but not consistently, and for a few minutes at a time.
    I figure the battery in one of the pressure sensors is iffy and drops below the threshold for the indicator light when really cold.
    Plan is to replace them all when I get my tires replaced. I'll just have to remember to have the spare done
