The issues I am noticing at 74k mile mark.
Discussion in '2nd Gen Tundras (2007-2013)' started by hmadd, Dec 2, 2019.
  1. Dec 2, 2019 at 6:50 AM
    hmadd
    hmadd [OP] New Member
    2010 Black Tundra TRD
    Rough Country 3" Leveling Kit, longitudinal assist springs for towing. LT275/70 LRE Gen Grabber ATX's
    These are the issues that I am noticing.
    The radio is cutting in and out completely or I loose a function.
    Howl coming from the front end, particularly when cold.
    Transmission shifts are all over the place.
    This truck was used as a tow rig by the previous owners. Supposedly an older couple that towed a camper from Maine to Florida every year.
    OR18TRD and Rex Kramer like this.
  2. Dec 2, 2019 at 6:59 AM
    Stock stereos are horrible and notorious for issues.
    Front end- when’s the last time anything was serviced?
    Black Wolf likes this.
  3. Dec 2, 2019 at 7:15 AM
    hmadd
    I had it serviced by the dealer a week and half ago. I wasn't worried about the radio, but wanted the dealer to look into the transmission and front end noise. Dealer said they didn't find anything.
  4. Dec 2, 2019 at 7:18 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Welcome to the forum.
  5. Dec 2, 2019 at 7:34 AM
    koditten
    Kirk
    Midland of the Mitten
    This a 4 wheel drive truck? That front end noise may be the needle berring in the front differential. Put the truck in 4 wheel drive and note if the sound goes away. This is a common issue and causes no differential failure. It's just annoying.
    TacomaTundra likes this.
  6. Dec 2, 2019 at 7:42 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Welcome!
    The howling sound may be the fan, they make a loud roaring sound at start up when cold.
    The 3 previous owners of my 2007 used the truck to haul & tow heavy loads, and it had some interesting transmission shifting episodes when I purchased it with 270,000 miles. I had the dealer drain down & fill the trans fluid (not the power flush), and then I added a DAP tune. These two things smoothed the transmission out, and I am about to crest 290,000 miles without issue.
    Stereo cutting out... my solution
    Black Wolf and T-Rex266 like this.
  7. Dec 2, 2019 at 9:48 AM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I chased a front end howl/growl, womp-womp-womp noise on mine for quite a while (even changed the needle bearing previously mentioned). Turned out to be my tires wearing unevenly. Check your tires and alignment.
    koditten likes this.
