The Great Tow Hooks Conspiracy Thread
Discussion in '3rd Gen Tundras (2022+)' started by FO LO, Sep 22, 2021.
Tow Hooks?
  1. Yay!
    130 vote(s)
    47.6%
  2. Nay!
    4 vote(s)
    1.5%
  3. Who cares?
    91 vote(s)
    33.3%
  4. Outbound is a smug arsehole.
    28 vote(s)
    10.3%
  5. Hoser eh?
    20 vote(s)
    7.3%
  1. Jan 21, 2022 at 12:46 PM
    #631
    Ohannon7
    Ohannon7 New Member
    Central Fl
    2013 5.7 4WD CM Bench-Seat Silver
    6” Pro Comp 37’s Custom audio and interior Off road capability is current focus
    2022 will have paved roads everywhere so the idea of needing off road capabilities is so old fashioned
  2. Jan 21, 2022 at 2:13 PM
    #632
    OnThaLake
    OnThaLake New Member
    This made me laugh a little, as "world class city" Seattle actually has gravel roads in the SODO area. It's really weird
    Mattedfred likes this.
  3. Jan 21, 2022 at 3:34 PM
    #633
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Because the twin turbo will put truck into limp mode and just be easier to pull it home:boink:
  4. Jan 22, 2022 at 2:56 AM
    #634
    Ohannon7
    Ohannon7 New Member
    Central Fl
    what if I see a Prius or Echo that slide off of the side of said unpaved road?
    if I don’t have front hooks to pull them out maybe I just keep driving??
    Acedude and Mattedfred[QUOTED] like this.
  5. Jan 22, 2022 at 4:48 AM
    #635
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Didn't we decide it's hard on your truck to pull from the front when pulling someone out?
  6. Jan 22, 2022 at 4:51 AM
    #636
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    I didn't. In all seriousness, it is my preferred method (winch and no winch config).
    Acedude likes this.
  7. Jan 22, 2022 at 5:09 AM
    #637
    Ohannon7
    Ohannon7 New Member
    Central Fl
    oh maybe it is best practice, I’m not sure really
    but I just mean sometimes the environment dictates what the best way to pull someone out is.
    I don’t wanna get in the muck while pulling someone out of a ditch bc then I might lose traction
    Point is there have been times I can’t safely get my rear end in a position to help someone
    we have an illegal u-turn that people do by my house and the FWD cars get stuck a lot bc they don’t realize once they go off the asphalt even a couple inches it turns into nasty nasty mud
  8. Jan 22, 2022 at 12:22 PM
    #638
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Well damn, that front diff pic shows what I think is the same ridiculous 10mm Allen drain plug. I hate them so much. However, Lexus has 24mm drain and fill plugs that are a direct swap. Work fine on older Toyota front diffs and hopefully work on the new Gen.
  9. Jan 24, 2022 at 5:16 AM
    #639
    nuclear
    nuclear New Member
    The cheaper models don't come with them, however you can add them. Toyota doesn't even give you the option, on any model.
    Acedude and OnThaLake like this.
  10. Jan 24, 2022 at 9:56 AM
    #640
    winchester44
    winchester44 New Member
    2016 1794 4WD
    Exactly! Hopefully Skid plates are a different story on the TRD Pro at least.
    Standard TRD Off-Road package includes a locking diff, mild shock upgrade and an extra button to select MTS/Crawl Control. Oh and a bunch of stickers....and for that they are asking $3,100. Most will be better off just skipping it and putting that towards aftermarket.
    Locking Diff is nice. I have had one, but it that would be way down my priority list vs. skid plates and recovery hooks.
    Ohannon7[QUOTED] likes this.
  11. Jan 24, 2022 at 9:58 AM
    #641
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    I have a theory that you’re supposed to remove the whole cab if you get stuck, that way you have unfettered access to the frame to attach recovery gear to.
    That ole’ Mike Sweerg is a genius!
  12. Jan 24, 2022 at 11:33 AM
    #642
    Ohannon7
    Ohannon7 New Member
    Central Fl
    I hope there’s a quick-release option
    1UP likes this.
  13. Jan 24, 2022 at 11:43 AM
    #643
    1UP
    1UP Truck Gang
    What are the odds the Sequoia has tow hooks.
  14. Jan 24, 2022 at 12:02 PM
    #644
    Coal Dragger
    Kung Fu Dick
    That would be delicious. The salty tears of rage would cause major flooding.
  15. Jan 25, 2022 at 11:15 AM
    #645
    1UP
    1UP Truck Gang
    No tow hooks on the Sequoia either from what I can see. No V8 either.
    Ohannon7 and Acedude like this.
  16. Jan 25, 2022 at 12:03 PM
    #646
    nuclear
    nuclear New Member
  17. Jan 25, 2022 at 2:37 PM
    #647
    Dav123
    Dav123 New Member
    David
    Im sure once more of these are sold, we'll start seeing pics of folks stuck in some way and needing pulled out from the front, and how they got it done. My bet is the guy that rides his hard in those videos will be the first in that predicament. lol
  18. Jan 26, 2022 at 11:26 AM
    #648
    Ohannon7
    Ohannon7 New Member
    Central Fl
    OT but that new sequoia is beautiful to me
    DeesCrewMax likes this.
  19. Jan 26, 2022 at 1:49 PM
    #649
    AustinTexas
    AustinTexas New Member
    I didn't have time to read 23 pages of comments but
    is anyone using this as a substitute?
    jewsNbrews and ErikTRDTUNDRA like this.
  20. Jan 26, 2022 at 2:00 PM
    #650
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    I don't think any year Tundra comes with a front mounted tow hitch.
  21. Jan 26, 2022 at 2:53 PM
    #651
    OnThaLake
    Wonder if that caribiner is "45000 pounds" also.
    Not sure I've ever seen a receiver rated as high.
    No doubt the Chinesium alloy is definitely safe at 45,000 pounds
    Cpl_Punishment likes this.
  22. Jan 27, 2022 at 7:38 PM
    #652
    Dav123
    Dav123 New Member
    David
  23. Jan 27, 2022 at 7:39 PM
    #653
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Please don't buy anything remotely related to safety from china.
    YeeYeeTundra and Cpl_Punishment like this.
  24. Jan 27, 2022 at 7:54 PM
    #654
    Coal Dragger
    Kung Fu Dick
    I took the liberty of fixing your quote....
  25. Jan 27, 2022 at 9:37 PM
    #655
    MadMaxCanon
    Thank you for that, don't know where my minds gone.
  26. Jan 27, 2022 at 9:39 PM
    #656
    Coal Dragger
    Kung Fu Dick
    It’s OK my friend, if we don’t look out for each other who will?
    MadMaxCanon likes this.
  27. Jan 27, 2022 at 9:42 PM
    #657
    MadMaxCanon
    Truth
  28. Jan 30, 2022 at 5:24 AM
    #658
    1UP
    1UP Truck Gang
    Mattedfred and RavingOx like this.
  29. Jan 30, 2022 at 12:42 PM
    #659
    stevj
    stevj New Member
    On a clear day, I can see Seattle from my house.
    Current RAM 1500 owner waiting for the new Tundra "hybrid."
    Frame-mounted recovery hooks for 2022 Tundra may require relocation of the fog lights so the recovery hardware can come through those holes.
    Or maybe someone will make a retrofit kit that includes 3D-printed trim surrounds for holes that must be made in a different location in the front bumper cover.
  30. Jan 30, 2022 at 6:13 PM
    #660
    Dav123
    Dav123 New Member
    David
