The Great HU Install of 2023
Discussion in 'Audio & Video' started by RainMan_PNW, Aug 19, 2023.
Did you get in on the recent Best Buy clearance frenzy? What did you get?
  1. Alpine ILX-F511
    35 vote(s)
    26.9%
  2. Alpine ILX-F509
    4 vote(s)
    3.1%
  3. Alpine ILX-F507
    0 vote(s)
    0.0%
  4. Kenwood DMX-1037S
    16 vote(s)
    12.3%
  5. Something else (let us know in the thread)
    4 vote(s)
    3.1%
  6. I bought enough to start my own car stereo franchise
    2 vote(s)
    1.5%
  7. No - I was late to the party
    54 vote(s)
    41.5%
  8. No - I didn't need a new head unit
    19 vote(s)
    14.6%
Multiple votes are allowed.
  1. Aug 28, 2023 at 8:27 PM
    #211
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    If you don't read the instructions you just wonder why you have those left over.
  2. Aug 28, 2023 at 8:30 PM
    #212
    run4fun
    run4fun New Member
    2018 sr5 trd
    I have mine mounted in the same spot. I did a test call to my wife and she said the same thing, that she is getting an echo of her voice. Has anyone had success with the mic in a different location?
    Also any tips for an affordable front camera that works with the kenwood?
  3. Aug 28, 2023 at 8:32 PM
    #213
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    I ran mine up the A pillar and stuck it next to the visor. I asked a couple of people how it sounded and they both said better than it usually does. I need to pull a bit more slack so the wire is not as noticable.
  4. Aug 28, 2023 at 8:33 PM
    #214
    RainMan_PNW
    RainMan_PNW [OP] "Oz" SSEM #82 RGBA #4 Unofficial Forum Treasurer Vendor?
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Get the Natika front camera off scamazon - pick your flavor, there’s a couple options.
  5. Aug 29, 2023 at 8:34 AM
    #215
    run4fun
    run4fun New Member
    2018 sr5 trd
    Thanks I will look at that one. I actually have an old camera installed from the anyTimeBackUpCamera that I did. I would like to just retain that camera if possible. I cut the camera end off the existing harness and it exposed 3 wires which I presume is +,-,and signal. I have an RCA plug from the kit but it only has two available wires. Anyone smarter than me know how I would go about wiring this camera up? maybe just buy a RCA end with 3 wires. Or would it just be best to buy the Natika.
  6. Aug 29, 2023 at 8:36 AM
    #216
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Wire the+ and signal together and link that to the one available non-RCA. If that doesn't work, then you'll probably need another camera, but it'll likely work.
    bulldog93 likes this.
  7. Aug 29, 2023 at 8:50 AM
    #217
    RainMan_PNW
    Casey
    Clark County, WA
    I guess I’m not entirely following what wires you cut. The HU should have a female RCA for camera input, and the old anytime camera (which may be a Natika depending on the kit you r originally bought) should have had a male RCA plus a trigger wire.
  8. Aug 29, 2023 at 8:55 AM
    #218
    run4fun
    run4fun New Member
    2018 sr5 trd
    It was not directly to an RCA. The camera came to a split. One wire went to a relay the other went to an RCA end. Which is why I cut the 3 way part out and was just going to solder in a single RCA connector. I think I will probably just end up buying a new camera. I appreciate the replies though!
  9. Aug 29, 2023 at 8:57 AM
    #219
    RainMan_PNW
    Casey
    Clark County, WA
    the single wire going to the relay was likely the trigger wire to send power to the camera.
    TaquitoBandito and bulldog93 like this.
  10. Aug 29, 2023 at 9:56 AM
    #220
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    I just installed a Natika to my Kenwood Excelon DMX709S yesterday. Installation couldn’t have been any easier. Power, ground, and RCA input to the head unit. You’ll have to set it up in the head unit after installation. And for some reason the Maestro RR allows programming one of the steering wheel controls to display the front camera, but once hooked up it doesn’t seem to actually work. (The camera works, but the steering wheel control won’t activate the camera.)
    My only complaint, if you could call it that, is that the power and ground leads are configured so it was much easier to wire them into the underhood fuse box rather than under the dash. I used a fuse tap to the USB fuse, and increased the fuse from 7.5 to 10 amps, but mainly because I also added a QC3.0 port at the same time.
    I also used this mount from Yota LEDs to mount the camera to the grill. It’s a little pricey for what it is, but it was worth it to avoid drilling a hole in my grill.
  11. Aug 29, 2023 at 3:54 PM
    #221
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    Do I need RCA cables for Kenwood/Maestro to factory JBL amp?
  12. Aug 29, 2023 at 4:48 PM
    #222
    RainMan_PNW
    Casey
    Clark County, WA
    No.
    The factory JBL amp has nowhere to plug RCA cables into.
  13. Aug 29, 2023 at 5:32 PM
    #223
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Got the knob installed this evening. Relocated the microphone into the cubby but still has an echo. None of the settings seem to do much. But I am done tinkering and will never open that dash again until I rip it out to sell / trade the truck.
  14. Aug 29, 2023 at 5:39 PM
    #224
    Azblue
    The Dirty T ( ^_^)_且
    ToyoMafia, bulldog93, Mater and 2 others like this.
  15. Aug 29, 2023 at 5:41 PM
    #225
    TaquitoBandito
    Joel (AKA Bif)
  16. Aug 29, 2023 at 7:47 PM
    #226
    RainMan_PNW
    Casey
    Clark County, WA
    How’s the knob function?
    I’m not a big fan of it sticking off the side, but I think it can be mounted anywhere, right?
  17. Aug 29, 2023 at 8:31 PM
    #227
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    Thought my stereo was possessed today.
    The other day the screen started flashing between map and car play screen. I reset my phone and drove the couple of mins home no issue.
    Today was a couple hour drive and it starts doing it again. Reset. Still doing it. Disconnect the phone and the radio stations start changing.
    I have a Ram mag charger on a ram mount next to the screen. When the phone is on and charging it freaks out the screen. Holding the phone next to the screen no issue. With the phone off and charging no issue. Phone on and charging it goes nuts. I moved the mount a couple inches away from the screen and it’s fine now. Except I can’t get to settings. Which it did the after the first time it happened but I didn’t relate the issue. So I have to pull the unit out again. Disconnect and reconnect the bypass and keep the charger and phone away from the screen.
    Or maybe it is possessed and just tricking me to pull it apart again.
    ToyoMafia and Mater like this.
  18. Aug 29, 2023 at 10:48 PM
    #228
    shawn474
    MoCo, Maryland
    it’s actually not bad; once you tap it it will pair in a few seconds. You can mount it anywhere - I just chose to the bracket it came with. I may eventually relocate it but happy with it for now
  19. Aug 30, 2023 at 6:08 PM
    #229
    meagain
    meagain New Member
    Is your screen sitting up high enough to access the pocket? And if so, do you or anyone know why mine isn’t accessible? Mine is covering the pocket
  20. Aug 30, 2023 at 6:15 PM
    #230
    meagain
    meagain New Member
    I have a strange question. After the install, done by the Best Buy experts, my auto dim headlights don’t work. I noticed it when at night my dash wasn’t lit up. I have to manually switch them. Any ideas?
    I have another, much less strange question that I just thought of. Is there a way to make my tire pressures show up? They currently just say N/A. I have the Alpine Halo 11, and I should point out the truck is a 17 Platinum, and it was originally out of Canada. That may or may not mean anything, but they’re not entirely identical to the American ones (ie, Entune and the features that come with are similar but not identical)
  21. Aug 30, 2023 at 6:18 PM
    #231
    MedCityMoto
    I can answer the TPMS question! Our systems don't report the individual wheels, it's purely an on-off switch.
  22. Aug 30, 2023 at 6:25 PM
    #232
    meagain
    meagain New Member
    Booooooo. But thnx!
  23. Aug 30, 2023 at 6:32 PM
    #233
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Pop your center speaker grille off and make sure they plugged your light sensor back in
  24. Aug 30, 2023 at 10:45 PM
    #234
    meagain
    meagain New Member
    Thnx! I’ll try that for sure
  25. Aug 31, 2023 at 7:23 AM
    #235
    run4fun
    run4fun New Member
    2018 sr5 trd
    Ok I got my kenwood installed a few days ago and so far it’s been pretty good with one exception. My wireless CarPlay is week. My music gets glitchy and I have even had CarPlay completely freeze up a few times, and maps lag. Happens almost every time so it’s frustrating for sure. Any ideas how to get wireless carplay more stable? I have tried putting my phone in different positions. I don’t have any magnetic phone mounts just simply keep my phone in my pocket or the cup holder.
  26. Aug 31, 2023 at 7:51 AM
    #236
    shawn474
    MoCo, Maryland
    have you tried checking to see if there a firmware update for the head unit?
    TaquitoBandito and JohnnyMoxon69 like this.
  27. Aug 31, 2023 at 8:04 AM
    #237
    JohnnyMoxon69
    JohnnyMoxon69 New Member
    2011 Tundra Limited Crewmax
    Have you tried updating the firmware to the headunit? I have a 907s that had similar issues, after I updated the firmware they went away.
    https://www.kenwood.com/cs/ce/mm/firmware/2020/2020g/eng.html
  28. Aug 31, 2023 at 2:36 PM
    #238
    Azblue
    Questions for those who have done this install.
    1. I assume that I connect these speed sensors wires.
    2. Where the hell does the blue wire on the antenna adapter go?
    3. The instructions from the AX-TRIG1 say to connect both the green and yellow wires but post #8 here says just the green one? Also, I found the short amp turn on wire, but am lost trying to locate the others.
    20230831_142735.jpg 20230831_142755.jpg 20230831_142744.jpg 20230831_142803.jpg
  29. Aug 31, 2023 at 3:17 PM
    #239
    RainMan_PNW
    Casey
    Clark County, WA
    Question #3 - the “foot brake” wire doesn’t exist in this newest generation of Alpine radios, so there’s nothing to connect the yellow wire to.
  30. Aug 31, 2023 at 3:22 PM
    #240
    run4fun
    run4fun New Member
    2018 sr5 trd
    wow yeah I'm way behind... currently running 1.4 and looks like the lates is 1.7. Not sure why I did not think to update firmware from the get go.
