The Gr8 Punkin
Discussion in 'Other Builds' started by Thegr8punkin, Apr 16, 2017.
  1. Apr 17, 2017 at 6:46 PM
    #61
    Thegr8punkin
    Thegr8punkin [OP] A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Ya for the front the only thing toytec has is drop spindles
    *all they have is all joint spacers or ome torsion bars*
    joonbug likes this.
  2. Apr 18, 2017 at 1:47 AM
    #62
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    37ec40d2071793fc1e79028b9a392ca1_57ac4099cd831580def2d7bc8f95caa48b48478d.jpg7c58734fff0b03dd3c97dc90e84b627d_05be2bbfaa20fbbe84cb51d6f06079b78ca03cb3.jpghad to make sure these were set to the same thing :thumbup: gonna pick up some led bulbs to replace the ones in the back of it then the clusters are getting swapped since I've been sitting on this part for 6 months and I just realized that it is 8 screws to swap
    joonbug likes this.
  3. Apr 18, 2017 at 7:28 AM
    #63
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    Sounds good bud!! I'll give you a little tour while your here!!
  4. Apr 18, 2017 at 2:48 PM
    #64
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    593a43ee680c3f2df4a7b0fd3ee8da38_9c123aaa89251b01282217153d2c9476e9b07f11.jpg got this installed this morning before work. Put some Amber LEDs in instead of the old green back light bulbs. I'll post some pictures of that tonight when I can get some pictures In the dark Also picked up some shock extensions for the front that I might throw on and crank up the torsion bars. Just to try and keep the shocks happy.
    joonbug and BestGen like this.
  5. Apr 18, 2017 at 6:22 PM
    #65
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Same thing happened to me when I put new OME springs... got 5" of lift from what was supposed to be 2". Maybe they'll settle. Hopefully. On the front I put 1.5" ball-joint spacers. Haven't touched the torsion bars yet. When I go to 35s I might. IMG_1170.jpg
  6. Apr 18, 2017 at 6:25 PM
    #66
    BestGen
    BestGen New Member
    Paul
    ColoradoTJ, joonbug and TXMiamiFan like this.
  7. Apr 18, 2017 at 6:38 PM
    #67
    BestGen
    BestGen New Member
    Paul
    How hard was the swap? I've got the SR-5 gauges too but haven't gotten around to installing yet.
  8. Apr 18, 2017 at 8:43 PM
    #68
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Honestly I thought it was a lot harder then it was. I was thinking it was fining to be removing the entire dash, but no it's 9 Phillips head screws, 3 electrical plugs and the speedo cable. Also have to replace the oil pressure switch (for the low oil dummy light) to an oil pressure sensor (it's now an actual gauge) I replaced the oils sensor first then removed the old one and just plugged in the new one and turned my truck on and low and behold it was already wired for a tac
    https://m.youtube.com/watch?v=SzWUDajYXrk
    Was watching this last night and that's what pushed me over the edge into doing it.
    As for your mention on the rear springs, you gotta think that the lift is from stock height, not the sagged height that we were used to.
    joonbug likes this.
  9. Apr 18, 2017 at 8:46 PM
    #69
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    7120b3600f97dae2cd8856874f47dc7a_f14444dc309fb3d6f894f2104a3a027a5918bbd3.jpg supper happy with the new color. 5dbb0dba384725358e10509fddbe8080_c093e4f07b43daa2b71ae4ad765edb519648c8d0.jpg matches pretty good to the radio too :cool: I swear it looks closer in person
    joonbug likes this.
  10. Apr 23, 2017 at 3:45 PM
    #70
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Found out today that the lift has made it 100 times harder to remove the top by my self...
    joonbug, Joeshaker and ColoradoTJ like this.
  11. Apr 23, 2017 at 5:14 PM
    #71
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    When I had a shell on my 97 Chevy. I put 2x4's across the trusses in my garage. I put bolts w eyes ( circles ) in the 2x4's. I'd back the truck into the garage and hook tie downs to the shell w a 2x4 and eye bolts under the shell. Then lift the shell corner by corner by myself until the shell was tucked up tight to the roof trusses.
    I saw a pic on here of someone else doing the sand thing. Worked good, kept the shell out of the way. It took about 1/2 hour to put on/ remove shell.
    Thegr8punkin[OP] likes this.
  12. Apr 23, 2017 at 5:36 PM
    #72
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I'll be doing something like that when I get my house. No garage that I could do that to currently
  13. Apr 24, 2017 at 6:34 PM
    #73
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Well... since @ColoradoTJ had to spoil the surprise.... #ripPunkin
    joonbug likes this.
  14. Apr 24, 2017 at 7:33 PM
    #74
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    ?What happened?
  15. Apr 24, 2017 at 7:49 PM
    #75
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Big discussion over it on a thread called bounce school road
    joonbug likes this.
  16. Apr 24, 2017 at 7:54 PM
    #76
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    I'll take a look
  17. Apr 24, 2017 at 11:57 PM
    #77
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
  18. Apr 24, 2017 at 11:59 PM
    #78
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
  19. Apr 25, 2017 at 8:02 PM
    #79
    Joeshaker
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Get the blue one. You won't have to get new seats. Sunroof to, it'll give you a good view of the road.:eek:
  20. Apr 25, 2017 at 8:50 PM
    #80
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Especially since how I drive
    joonbug likes this.
  21. Apr 25, 2017 at 8:52 PM
    #81
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    But I don't trust that blue one. There is no way that has 6 inch shackles.
  22. Apr 30, 2017 at 2:55 PM
    #82
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Well... Today was a pretty crappy day... Been working out a deal with a friend of mine for one of his pick ups since mid February. Finally when I flipped the runner I said I was ready to pick it up. So I drove down to the spring bright and early only to find out that the trucks frame had been heavily (and cheaply) modified in the rear to accommodate a flat bed in the rear, and that in the modifications done to it, they left Lots of spots on the frame Unprotected... Thus leaving multiple sections of foot long frame holes. My buddy had said the frame was good but sadly I was lied to... My goal was to have this one up and running with the swapped parts from punkin by next weekend for the meet and greet... That's not happening... Looks I'm back to driving my screwed up tundra... Damn...
    Because of this whole deal, I think I'm going to be holding off on another 4x4 for awhile... As much as I love wheeling and putting punkin to the test, I think getting another truck right now would fell almost disrespectful to punkin. Call me stupid for thinking I can disrespect a car, but honestly, punkin was very much a healing factor for me over the past 8 months. Every change I did to her was trying to change something about my self and try and rebuild myself from what I had lost. Hell the reasons I painted her orange was because I was tired of looking at the old faded paint and I wanted somethings that looked fresh and new. And now that she is gone, I feel weird just trying to replace her. I'm going to head to the shop that she's at and tarp her up and set her in the backyard that way she isn't taking up my buddies shop space.
    I do think I'm going to be looking for another vehicle to accompany the tundy. Something good on gas. Every time I fill up I miss my metro... Could fill up for half what I'm spending on the tundra and it would last 2x as long.... I should probably give the tundra a formal name here soon... Maybe Linus... Hang a blanket like a flag on the back.... Hmm maybe.
    Anywhore, this was actually the weekend after I got the rear elocker installed, and literally the day after I got done painting her. It's also a down side Of going with well built rigs. You just have to know if your half built rig can do what theirs can do. Ok tangents over. Enjoy. https://m.youtube.com/watch?v=9CrTY0EpVzY&feature=youtu.be
    P.s. Pardon my dads crappy filming
  23. Apr 30, 2017 at 3:39 PM
    #83
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Not stupid for feeling respect for something you poured sweat, tears and blood (literally).
    Also, sounds like you need better friends. The ones you have trash your truck or lie to you. What's up with that?
  24. Apr 30, 2017 at 3:49 PM
    #84
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    The dude that trashed my truck is one thing.
    I don't know if it was really lieing to me, he lives in wy for the past few years and haven't seen the truck since he moved up there. He's a good guy normally, shirt off his back kinda guy. When a mutual friend of ours wrecked her 4Runner he chopped off the front of one his and gave it to her. He also offered todo the same for mine as well as a chop off a roof for me to put back on mine. I declined doing that. Not worth the headache.
    But bad friends seem to be a dime a dozen for me. Though, I have a couple now that would have my back with out a doubt. Just have to disregard the 50 that I tried to make and got fucked over by.
    You know you got a friend when you get a text from your ex and that pisses them off lol
    joonbug and TXMiamiFan[QUOTED] like this.
  25. Apr 30, 2017 at 3:55 PM
    #85
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    It's a kick in the nuts when you bust your ass on something then it goes to shit. More things than a truck.
    I've found if you're hunting for something, you're disappointed and don't get what you're looking for. However, once you stop looking, something sweet drops into your lap. And if you're not focused and hunting, you're aware enough to realize a new opportunity.
    Don't be in a rush.
    Besides, let that gash and the bruises heal before you start wrenching away on something else.
    Heck, Take a sawzall to that thing, make it a convertible, then you don't have to worry about storing the shell. You could even sell the shell, I'm sure it would go quick.
    Just make sure you build a roll cage into it.
    Hell do a full length roll cage and put an overland tent on the back, flip up windshield like a jeep, bikini top over the cab.
    Just a thought.
    Joeshaker and Thegr8punkin[OP] like this.
  26. Apr 30, 2017 at 4:12 PM
    #86
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    Stitches come out Monday(Tomorrow) and the bruises are pretty much gone. Still have color, but no pain.
    I debated about that but it's more that the alinement and the entire front suspension is busted, the rad is cracked, pretty much all parts that I DONT have laying around....
    joonbug and Joeshaker like this.
  27. Apr 30, 2017 at 4:14 PM
    #87
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    And wrenching one some thing else is the best therapy... Lol speaking of, I sould go swap wheels on Linus...
  28. Apr 30, 2017 at 4:40 PM
    #88
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    Haha. I've got a copper radiator that fits a 95. It's yours if you can use it. Let me know, I'll even ship it.
  29. Apr 30, 2017 at 4:43 PM
    #89
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    95 runner or pickup? Regardless I'll have my local parts department cross check part numbers and I'll let you know.
  30. Apr 30, 2017 at 5:46 PM
    #90
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    95 4Runner 3.0. It's yours if you can/want to use it. Frankenstein that thing.
    (Sorry, can't pass this up)
    It'll match the scar.
