The EXPO TRON Build
Discussion in '2.5 Gen Builds (2014-2021)' started by TRON, Feb 26, 2016.
  1. Feb 17, 2018 at 10:14 PM
    #511
    dcsleeper408
    dcsleeper408 BASTRDS
    mark
    San Jose CA
    2015 TRD PRO
    Right. With longer shackles, i see them push the pack down which compromises arch and flattens them quickly. I am no engineer but I’m on the same boat as you.
    With your #’s probably a better idea for me to keep the rxt packs on 1st option. Just have to compromise my load out.
    Have you ever thought about doing a bed cage? Yield more travel? I’ve seen some nice cages keeping the bed a bed. Only thing is $$
    Did Rinzler have a bed cage?
    TRON[QUOTED][OP] likes this.
  2. Feb 17, 2018 at 10:21 PM
    #512
    TRON
    TRON [OP] Is LIVE on the GRID.
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    DUROBUMPS Use TRON10 for 10% Off & Free Shipping
    Rinzler did have an epic bed cage....
    Prostar 190, TheBeast, blue16 and 2 others like this.
  3. Feb 17, 2018 at 10:59 PM
    #513
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    But to answer your question no, I have no plans to cut into the bed for a cage in TRON
    dcsleeper408 likes this.
  4. Feb 17, 2018 at 11:06 PM
    #514
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    For now.. :boink:
    Watt maker likes this.
  5. Feb 18, 2018 at 12:11 AM
    #515
    zackbremer
    zackbremer New Member
    Da Z
    ugh i need to get to valley spring
    also that camburg kit down travel;);) and still a lil more togo
    TheBeast, blue16, Tacotundra and 3 others like this.
  6. Feb 18, 2018 at 12:14 AM
    #516
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    How has that kit worked for you? Do you know your overall gains before and after?
    831Tun likes this.
  7. Feb 18, 2018 at 2:26 AM
    #517
    zackbremer
    Da Z
    before what ever stock was..now with deavers and the kit 14inches of travel droop to bump...im strapped at 13inches with a 11in long limit strap..fab guy says allow for 1inch of stretch for every 10in of limitstrap once it heats up. i think going SUA with this kit you could get close to 16in under the bed, the deaver SOA leaf pack is atleast 2inches thick so you would gain that in uptravel. but you would most likely need bed sides..def with 37s, maybe with 35s...wont know until you try ;)
    the only thing ill say about the kit when you order your bypass have them clock the bypass tubes to the front instead of out the side..my tire(18mm offset wheels) rubs slightly at full compression and its a bitch to adjust the bypass tubes with the wheel on, i can move the wrench in 1/8in increments to loosen the lock nuts on the tubes
  8. Feb 18, 2018 at 9:15 AM
    #518
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Solid #’s !!
    Can you share some pictures of your lower shock mount.
  9. Feb 18, 2018 at 10:38 PM
    #519
    zackbremer
    Da Z
    the camburg kit comes with upper and lowers, the lowers require cutting of old shock mounts and welding, the uppers require cutting the old mounts off and are bolt on through the frame
  10. Feb 18, 2018 at 10:46 PM
    #520
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Did you cycle through the suspension to figure where the lower needed to be placed?
  11. Feb 18, 2018 at 11:02 PM
    #521
    zackbremer
    Da Z
    yup deavers stripped to main leaf , you can cheat and use the main leaf from your stock pack so u dont have to strip the deavers, then bypass mocked up and axle cycled up and down to figure out where the mounts needed to go
  12. Feb 20, 2018 at 11:07 AM
    #522
    tundraoverland1
    tundraoverland1 New Member
    Las Vegas
    2015 White Tundra crewmax TRD 4x4
    IG: sfarrisjr88
    ill be out there saturday in Spec 2 with the wife and kids. im also taking my son to tech on friday.
    any plans for meet ups yet?
  13. Feb 20, 2018 at 11:21 AM
    #523
    TheBeast The Beach
    safe to assume you are not running any sway bars ? :)
  14. Feb 20, 2018 at 8:43 PM
    #524
    zackbremer
    Da Z
    correct no sway bars front or rear
  15. Feb 21, 2018 at 9:16 AM
    #525
    n2deep
    n2deep Pavement Princess
    I disagree with this to a degree - If the shackles are too long and allow the springs to go negative that is a bad thing. My CB+3 allow my Deavers to go negative and now they need to be re-arched again, but if I don't change shackles to correct size then it will just happen again and again. Key words as you stated "Properly designed shackles" I added them to solve a problem but created a different problem. Now i have decided to rip all of it out and start with something totally different.
    TRON[OP], KevinK, zackbremer and 2 others like this.
  16. Feb 21, 2018 at 9:20 AM
    #526
    TheBeast The Beach
    Deaver recommends the TC size shackles which are 3/4" longer so that's probably as far as you can go. CB +3 are a lot longer I believe.
    MCM shackles are good size too.
    dcsleeper408 and Tacotundra like this.
  17. Feb 21, 2018 at 9:21 AM
    #527
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    Right, I think with the longer shackle, it pushes the back portion of the leaf pack down that causes the "flatness". With time and some wheeling they will start going negative. +3 shackles on my stock packs went bad fast. Heavy load and wheeling helped them go negative fairly quick.
    At least this is my thought on all this.
    UTTundra and TheBeast like this.
  18. Feb 21, 2018 at 9:25 AM
    #528
    TheBeast The Beach
    especially since you guys are really loading your truck beds and the load is on all the time.
  19. Feb 21, 2018 at 10:41 AM
    #529
    n2deep
    Well I don't run a standard Deaver pack nor do i run a normal bump - it was all experimental. LOL But I also don't load my truck all the time - my weight fluctuates by 500-600lbs sometimes. Doesn't matter at this point cause its all getting pulled out and starting from scratch with a new experimental setup.
  20. Feb 21, 2018 at 10:48 AM
    #530
    TheBeast The Beach
    sounds like a plan. post a thread with your build so we can see whats up and not hijack @TRON lol. thx
  21. Feb 21, 2018 at 4:44 PM
    #531
    Grendel
    Grendel New Member
    2016 Quicksand TRD PRO
    DCSSleeper408 & Tron Thanks for the info and help. you have awesome rigs
  22. Feb 21, 2018 at 5:11 PM
    #532
    n2deep
    Not quite a hijack - we were discussing shackles and leafs. Something Stefen was specifically talking about. And him addressing his rear setup.
    TRON[OP] and dcsleeper408 like this.
  23. Feb 22, 2018 at 12:02 AM
    #533
    zackbremer
    Da Z
    you hijacking son of a bitch
    TRON[OP], 831Tun, TheBeast and 2 others like this.
  24. Feb 22, 2018 at 6:48 AM
    #534
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Keep the leaf spring talk a goin! I'm still torn on what to do haha
    14burrito, TRON[OP] and dcsleeper408 like this.
  25. Feb 22, 2018 at 10:24 AM
    #535
    dcsleeper408
    mark
    San Jose CA
    2015 TRD PRO
    I agree with you. I have left a constant load with the bed rack and tent sitting on there for a good minute.
    They would've gone flat regardless. I just think they went flat prematurely.
    I am now on the Icon RXT packs, with just the tent and the rack, I can see them sag already. Going to the Option #2 the RXT pack offers is probably what I have to go to. My shocks is the factor, as they won't keep up. I will loose a good amount of down travel and unloaded I would ride ass up.
    Only time can tell. I really want to see @TRON setup in the long run. So far it's been holding up. Even just moving all his stuff @ that X amount of weight that pack is holding up.
    Watt maker, 831Tun and zackbremer like this.
  26. Feb 22, 2018 at 9:59 PM
    #536
    zackbremer
    Da Z
    i wanna hear about this icon rxt pack
  27. Feb 25, 2018 at 10:43 PM
    #537
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    No hijack here, I welcome the conversation. It does help to learn what setups work and what can be done to improve :cheers: I recently took 2 more loads to storage and officially moved out of our house in Tucson! I was alittle too busy and overwhelmed to stop and take pics but damn I am impressed with how well my leafs supported the weight of not only a full bed, but a full trailer. Once the dust settles I'll get back under the truck and see how the leafs are doing and if I lost any arch or lift
    KevinK, Watt maker and dcsleeper408 like this.
  28. Feb 25, 2018 at 11:26 PM
    #538
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    Crown King - February 10, 2018
    Here we go again! Last minute trip planned and we headed out early on a cool Saturday morning :cool: This would be my second time running the Back way to Crown King Trail. We had a good group of trucks, but I was a solo Tundra on this run with @PLC721 riding shotgun.
    Don't mind the perfect photo op :rofl: @PLC721
    Get Flexy.
    AZ XPO TRIPS :cheers:
    1rufftrdpro, JC303, KevinK and 13 others like this.
  29. Feb 26, 2018 at 7:04 AM
    #539
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    IG: PLC721
    Lmao that pic of me!!:laughing:
    TRON[OP] likes this.
  30. Feb 27, 2018 at 9:56 AM
    #540
    TRON
    Stefen
    Gilbert, Arizona
    IG: @ST3F3NS
    Well shit, time to fork out the money for my rear setup finally.... Not bad TRD Pro Bilsteins it was a fun 57K miles:cheers:7BB5501F-3451-4E79-BD35-B5621AD60D67.jpg
    JC303, JH5370, KevinK and 9 others like this.
