The Cream Pie - A 2005 4wd/LS/5-Speed/SAS Conversion
Discussion in '1st Gen Builds (2000-2006)' started by the_white_shadow, Aug 8, 2019.
  1. Jan 14, 2020 at 6:47 AM
    #91
    the_white_shadow
    the_white_shadow [OP] New Member
    A few parts came in over the weekend. Ruffstuff always has the beef heim joints. My new unit bearings also came in. Waiting on my Artec stuff to ship.
    r8JtyNy0fznbMcTy2mZ2vR-t8w2R5WtlVQMdCHiN_73656ff043f7f8cbde1a1a45c7601e6459277b3d.jpg
  2. Jan 21, 2020 at 4:58 AM
    #92
    the_white_shadow
    Shits about to get real. All of my brackets, links, steering, and truss came in from Artec. Hope to get it a roller by the end of the week.
    VRZbDYReg0ZlcVgX5xhCSKwY1InpXP7pcpGAyTfV_470944c5ecc9b33d97a96821653b13020703feb6.jpg
  3. Jan 21, 2020 at 5:02 AM
    #93
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Looking forward to seeing more progress, brotatoe chip.
  4. Jan 21, 2020 at 5:03 AM
    #94
    the_white_shadow
    I Still have that 4.0.....:thumbsup:
  5. Jan 21, 2020 at 5:17 AM
    #95
    Scuba
    Scuba Sober member
    Austin, Tx.
    HA! Thanks for mentioning it but I blew my Christmas bonus on a tube bender and toys for my daughter. I almost didn’t make the mortgage this month. Aside from that I blew the rear ring and pinion a couple weeks back. 2 steps forward, 1 step back. :rolleyes:
  6. Jan 21, 2020 at 1:07 PM
    #96
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Awesome! I need to make an appointment to come to your shop in February. I can't wait to see it in person.
  7. Jan 22, 2020 at 7:01 AM
    #97
    the_white_shadow
    Started to put it all together. I welded up the artec 3-link brackets and did a mockup of the passenger side lower. Some clearance was needed so i notched out where the lower links is going to go. Links are going to be around 40" long. Going to plate the thin frame before i weld everything up.
    These are full bump. I think i can shove my axle forward 1" more to get an additional 1" of uptravel. Going to have to see what the tire looks like in reference to the headlight.
    xe2KFH4FIBoZvG9FKlqAjKlMNBZmdqcGjG6baEfn_18641a2beaee863bdf53ccc061d9e00f0e489209.jpg
    Z7IVZQ9QXDN1lh5r_gQ5ZYzELoVpSbGZytVM6WxD_bb18da3a90954aa28b2f1beab4b686daf6536dd7.jpg
    ii_pmLr9JOUdKF0i4XfDLkvZbAmN754JNzWmyj0B_1fe81b96635caa731f1650bb2a98978eb6c281e4.jpg
    Ride Height: Shooting for 4-5" of uptravel.
    sFp_MfY-1UAXFzoB-oBC6wuWgTAB_z_gO_wxSItG_90570eee13d35076e596503fd9feb5c76ce7a727.jpg
  8. Jan 22, 2020 at 7:11 AM
    #98
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    EFF YES!!! I see welding and grind marks. BUILDING STUFF!!!!
  9. Jan 27, 2020 at 10:52 AM
    #99
    the_white_shadow
    Starting to take some shape. The tundra is now 3-linked. Still need to install the panhard.
    Upper link.
    bLlnuF0R7mv3SxHCnf-p92jqlEvkOHJCQl2FBpS0_9b0e3ce25b42d69217499e07866082c309eeb913.jpg
    Artec weld on crossover steering arms tacked on the knuckles. Tie-rod made.
    1HmHQ5s9ZaLOdBdeQipBdlOUvMCzlefEioIJO3VH_f54e1dc2250cf0f5de381ec400462cdf3ac8eb55.jpg
    QuCehy4LtVX06S5kj9VJR3PHOUlY14aCeYfz5BPS_419a9c3448b37cdd6b69fa39b41d4075c40cfb2e.jpg
    Now for the upper link. I ran into a slight problem. At full bump (actually 2.5-3" into the uptravel), the upper link hits the motor mount tube. Going to have to raise it up some with a bend, but shouldnt be too bad. Its getting closer to being a roller.
  10. Jan 28, 2020 at 5:20 AM
    #100
    the_white_shadow
    Panhard tacked in and checked at full bump. I cut off the passenger motor mount and raised it up to clear the link. Panhard is just lightly tacked in at the moment as i wait on my new flat steering arms to come in from Sky's Offroad. Once its in, i will set the angles of the drag link to match the panhard to eliminate bump steer. Steering clears the bracket on the axle lock to lock. Also have plenty of room for the hydro assist ram.
    4njZCN-6kwbZBmIrBFcAPn83wmijusM5q4PPeXnG_0a21fb9e4d88555e809ba09dd2a4c277ee932087.jpg
    A0643qh-Ov6G9eklZWQJDJpqb85_HSDl4pu7UUjI_e4604632f907df50a966a08c92e8464df67e397e.jpg
    ZDo7I5kfw6iWGKZGExLk3Yc6j_utlLCaANP12LHU_73d7f55e17cb88a95d4d3b0ffb034f97ffcaf9c8.jpg
  11. Jan 30, 2020 at 10:51 AM
    #101
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Impressive!
    the_white_shadow[OP] likes this.
  12. Feb 4, 2020 at 5:04 AM
    #102
    the_white_shadow
    Some more progress last night. New Skys Offroad flat pitman arm installed on the box. This let me build the drag link and get it in place. I then moved the panhard bar mounts to match the angle of the drag link. Both are about 44" long and are parallel to each other. This is important to reduce bump steer.
    U7RzF2mFu8afQhmGPSMZY8__jr1UqamkW3uvB3Tr_a090739754e2355bfa8d69eefd7bd4a18851d934.jpg
    HuJ2OuzWGCm4aPVc9i0ft4F3X40RIC_FL9IWs1Ds_bd93f1d3cc8b8c784cac2b15817f72f878a5d789.jpg
    KJwV0_xzxkSOA6a1d3imJOlJcSs5Uso3SpUhftmt_c2ed8a3bc6e7128ae636b4727a9115065e7178a4.jpg
    I also won a waffle on facebook and picked up these slick ball joint eliminators for the Ford axle. They are slick.
    qG5E-WEJ5r1j-148JLAPXnedUjdb1SynYtj6sETX_9b66e164f841bb5910a6fd013cc22fd3f3ce48e9.jpg
  13. Feb 4, 2020 at 6:49 AM
    #103
    because_wumbo-truck
    Jon
    Houston, Texas
    That's some serious beef
  14. Feb 4, 2020 at 8:31 AM
    #104
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    If you don't like this build, you need to be banned from this site.
  15. Feb 4, 2020 at 8:49 AM
    #105
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
  16. Feb 5, 2020 at 5:08 AM
    #106
    the_white_shadow
    Full droop checks out
    6qks6m_q4kLGXD0Z9R9Oz-q8BYdXncXsVZ4lTHNH_f785901dede13bee6907f8d8776193e1e10acc41.jpg
  17. Feb 6, 2020 at 5:35 AM
    #107
    the_white_shadow
    Off the lift for the first time since october. The rear settled more than i thought, but these are the stock springs still. Front will need a few inches trimmed under the lights. This is 5" of uptravel. Its going to sit super low which i like. Going to take it mostly apart and start welding it all up.
  18. Feb 6, 2020 at 5:44 AM
    #108
    LogCabins
    'Merica
    2017 TRD Pro
    Killing me I cant see the pics....but could be because I'm at work and our server sucks.
    because_wumbo-truck likes this.
  19. Feb 6, 2020 at 5:47 AM
    #109
    the_white_shadow
    maybe refresh your cookies? Work servers be weird sometimes.
  20. Feb 6, 2020 at 5:50 AM
    #110
    LogCabins
    'Merica
    2017 TRD Pro
    Especially Government servers....I thought the Army was bad, but after retiring and now working for the Navy as a contractor, there stuff is worse than old dial up o_O:rofl:
  21. Feb 6, 2020 at 7:11 AM
    #111
    MrDirtjumper
    MrDirtjumper Ol’ dickhead
    Josh
    Slam Angelo, Texas
    06 DC TRD, 2wd to 4wd Conv.
    Nah, the last post with pictures isn't working for me either.
    Bama and LogCabins like this.
  22. Feb 6, 2020 at 7:21 AM
    #112
    because_wumbo-truck
    Jon
    Houston, Texas
  23. Feb 6, 2020 at 7:23 AM
    #113
    because_wumbo-truck
    Jon
    Houston, Texas
    Once you free up your lift, you wanna help me fix my cross member? Preferably on a Sunday :D
  24. Feb 6, 2020 at 7:34 AM
    #114
    the_white_shadow
    Not sure when, as i have customers truck thats going on there next to remove the body.
  25. Feb 6, 2020 at 7:35 AM
    #115
    the_white_shadow
    Shit. Let me try again.
  26. Feb 6, 2020 at 7:35 AM
    #116
    the_white_shadow
  27. Feb 6, 2020 at 7:37 AM
    #117
    MrDirtjumper
    Josh
    Slam Angelo, Texas
    :muscleflexing:
    Haysus that looks beefy.
  28. Feb 6, 2020 at 7:40 AM
    #118
    the_white_shadow
    No clue why they didnt work in the first post. I can see them fine, but that doesnt always mean shit.
  29. Feb 6, 2020 at 7:52 AM
    #119
    because_wumbo-truck
    Jon
    Houston, Texas
    That's cool. I can wait if I must. One of these weekends I need to swap a CV so I can wheel without worrying about it missing the inner boot at Hidden Falls at the end of the month. Having the cross member straight so I can throw on my skids would be a plus. But I might take my chances. YOLO
    Or i might just ride along with someone else til I can fix my shit lol. You plan on going to that event?
  30. Feb 6, 2020 at 7:53 AM
    #120
    the_white_shadow
    doubt it. I hate hidden falls.
