The "Cracked Seat Panel" MEGA Thread
Discussion in '3rd Gen Tundras (2022+)' started by TundraSurveyor, Jul 14, 2022.
  1. Jan 11, 2024 at 7:48 PM
    #301
    RGSIII
    RGSIII New Member
    Got my third panel put on today. The part was paid for due to having paid for a previous replacement still being under the part's warranty, installation $100. Had dealership install it because it was in the shop for the temporary fuel line recall and brake ECU campaign.
    The part for the seat panel according to the parts department has the same number as the previous ones.
  2. Jan 11, 2024 at 8:05 PM
    #302
    G3ardnut
    G3ardnut Brushed Chrome is COOL
    Joe
    Canada
    2023 Limited TRD Offroad Crewmax Celestial Silver Metallic
    The same part number may not mean anything. It could be a new revision level. By keeping the same part number all the existing part list manuals remain the same.
    Tundrastruck91 and Mattedfred like this.
  3. Jan 15, 2024 at 12:31 PM
    #303
    RGSIII
    RGSIII New Member
    Hi, talked with the LaGrange Toyota parts department and they told me that the part remains unchanged and the replacement would have a new number. This makes sense to me, otherwise it would be impossible to tell the revised part from the older ones. I just hope a fix comes soon.
  4. Jan 15, 2024 at 1:00 PM
    #304
    G3ardnut
    Joe
    Canada
    Not nessarily so, part numbers as well as revision levels can be put on the backside of this part. I've been in manufacturing for 40 years that's how our industry does it by changing rev level unless the part is so significantly different from the previous one that's when a new part number is warranted. I guess we will know for sure once a new part is available.
    RGSIII[QUOTED] likes this.
  5. Jan 15, 2024 at 3:33 PM
    #305
    obgod3
    obgod3 New Member
    NC
    2023 Tundra Limited
    So mine was replaced today, my service advisor laughed out loud when I asked if the new one is a redesigned part. He said he has seen the newer ones break just the same. I like my service advisor, he is transparent on shit. Mine had a crack in it but he said some are destroyed and usually it is weight issue ;).
  6. Jan 19, 2024 at 1:21 PM
    #306
    Midnight Rider
    Midnight Rider None of the above.
    Dave
    Wright City MO
    2023 Platinum Crewmax 4x4
    Cup grips & a 2 decals.
    Had mine replaced today with an “updated reinforced panel” , one time goodwill replacement per the invoice. IMG_2324.jpg
  7. Jan 19, 2024 at 2:27 PM
    #307
    G3ardnut
    Joe
    Canada
    Good to hear they replaced it free of charge. Only time will tell if that is really good will or not.
    So is 711791 the new part number? If it is what is the old part number. Sorry without seeing the physical diferences between these two parts I am not going to believe it has been "upgraded".
    tundznoff likes this.
  8. Jan 19, 2024 at 2:41 PM
    #308
    Midnight Rider
    Dave
    Wright City MO
    Yeah I’m with you on that. Time will tell.
  9. Jan 19, 2024 at 3:13 PM
    #309
    chaztizer
    chaztizer New Member
    2023 Tundra TRD Pro
    Glad they replaced it for free, but I’m a little unsure why they needed to emphasize this was a one time goodwill repair. This should really be covered as part of their standard 36k bumper to bumper warranty right? Seems disingenuous to suggest it is “wear and tear” or abuse with how widespread the issue has been.
  10. Jan 19, 2024 at 3:17 PM
    #310
    Gray Hawk
    Gray Hawk New Member
    Cincinnati, Ohio
    2023 toyota tundra 4x4 1794 edition smoked mesquite
    Tonneau cover; dash cam
    Agreed. 100%
  11. Feb 14, 2024 at 2:37 PM
    #311
    matth66
    matth66 New Member
    matt
    Nor cal
    2023 Black Tundra Trd Pro
    So now I am a victim of the cracking seat trim piece. I had a thought and wanted to get everyone’s take on my idea. If we could find a member or a vendor that could make thin metal plates with the really strong 3m adhesive tape that would fit it this area, it might reinforce the plastic. The plates could be colored or engraved with “TOYOTA” “TRD”.
    Kind of like the no soliciting signs people stick on their front doors. Thoughts?
    shorenetworks and Tundrastruck91 like this.
  12. Feb 15, 2024 at 1:52 AM
    #312
    wing-2
    wing-2 New Member
    I guess I would prefer that the manufacturer would replace the part with one that won't fail.
  13. Feb 15, 2024 at 4:12 AM
    #313
    raylo
    raylo not so new member
    Frederick, MD
    I believe that plastic would be a better way to reinforce it. maybe just cut a piece of 1/16" or 1/8" ABS to fit the back side and glue it on.
  14. Feb 15, 2024 at 7:47 AM
    #314
    matth66
    matth66 New Member
    matt
    Nor cal
    Totally agree but sadly often times it’s up to the aftermarket community to solve the problem.
    shorenetworks and 2mchfun like this.
  15. Feb 15, 2024 at 8:08 AM
    #315
    donia
    donia New Member
    Miss’ippi
    2023 Celestial Silver Tundra 1794 4x4
    The replacement panel seems much thicker made. The original that cracked was easily malleable/bendable, but the replacement is much stiffer and has held up well.
    6’3” 250lbs
    pwpblue and Tundrastruck91 like this.
  16. Feb 15, 2024 at 10:56 AM
    #316
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Reading about all the cracks is only reason I left the step boards on. That and tell myself they protect rocker panels from debris.
  17. Feb 17, 2024 at 5:47 AM
    #317
    LouALouA
    LouALouA New Member
    Lou
    Central Florida
    2023 1794 Blueprint 4x4
    I had mine replaced with the new and improved version a couple months ago. It has cracked as well.
    2mchfun and ryanwgregg like this.
  18. Feb 17, 2024 at 12:43 PM
    #318
    dwilly1
    dwilly1 New Member
    Anyone have any luck getting dealer to fix the seat trim panel under warranty?
  19. Feb 17, 2024 at 2:38 PM
    #319
    Tundranewcomer
    Tundranewcomer New Member
    ‘22 MBM Platinum w/ power running board and advanced package
    Yes. Everyone.
  20. Feb 17, 2024 at 4:05 PM
    #320
    donia
    donia New Member
    Miss’ippi
    Dang…as soon as I post how well the updated panel seems to be built, I notice mine is cracked. The updated one, but not cracked as severely as the original was. Dealer Service Mgr has been good about making issues right.
  21. Feb 17, 2024 at 5:17 PM
    #321
    dwilly1
    dwilly1 New Member
    What do you mean T-SB-0007-24?
  22. Feb 17, 2024 at 6:08 PM
    #322
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Tech Service Bulletin
    2mchfun and dwilly1[QUOTED] like this.
  23. Feb 25, 2024 at 6:33 PM
    #323
    901tundra
    901tundra New Member
    Memphis, TN
    2023 Magnetic Gray Limited TRD Off-road
    - Color-matched grille and rear bumper insets - 1-inch Cornfed front spaces - TRD grille with light bar and amber marker lights - Debadged
    Made an appointment to have mine looked on Friday. It's not broken off yet but it's growing a bit each week and pops when getting in and out.
  24. Feb 27, 2024 at 4:36 AM
    #324
    extremes074
    extremes074 New Member
    David
    West Coast, Florida
    22 1794 TRD Off-Road
    Had mine replaced when at the dealer a few weeks ago. Luckily the service advisor was familiar with the issue as he has a Tundra and his piece had recently broke...lol
    Was able to swap it out without any hassle at all.
    Hopefully by now many of the dealerships know about these defective parts...
    Mattedfred likes this.
  25. Feb 28, 2024 at 7:46 PM
    #325
    Jw72
    Jw72 New Member
    I am seriously considering getting an extended warranty, yes on a freaking Toyota. Never in my life would I have thought I needed one on a toyota but my 2022 Tundra is having a few issues. My question: will a cracked seat be covered on the Toyota extended warranty? Thank you.
  26. Feb 28, 2024 at 7:49 PM
    #326
    Breathing Borla
    Northern Illinois
    The oem platinum warranty is bumper to bumper minus wear items like brakes , plugs at 40k etc, so yes that’s covered
  27. Feb 29, 2024 at 6:49 AM
    #327
    extremes074
    David
    West Coast, Florida
    Dealer replaced just the broken side for me (25,000 miles). I asked in the future if the other one breaks if they’d replace and he told me yes they would no question.
    I’m think this is due to the fact that the old part is obviously defective as the new part is a different design…
    Hopefully most dealers would see it this way?
  28. Feb 29, 2024 at 12:40 PM
    #328
    RGSIII
    RGSIII New Member
    So far I have spent $500 dollars and it looks like another crack is starting.
  29. Mar 1, 2024 at 10:45 AM
    #329
    Jw72
    Jw72 New Member
    I pulled the trigger on an extended warranty, the Jerry told me crack seats are not covered on the EW. I will fight that fight down the road when it fails again. 8 year, 75K 900 bucks plus 3% for using CC.
    BossDawg24 likes this.
  30. Mar 1, 2024 at 10:55 AM
    #330
    Jw72
    Jw72 New Member
    ‘i know it is cover under the 3yr/36000 when new. Are you saying it covered under a Toyota extended warranty? That would be great, hell, should have the 10 year. TY
