The Coachbuilder TRD Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by trdpro144, Mar 29, 2018.
  1. Nov 14, 2019 at 10:17 PM
    #151
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    No tie rod ends needed. No alignment issues so far.
    Rica25 and Coachbuilder1 like this.
  2. Nov 14, 2019 at 11:06 PM
    #152
    tmart
    tmart New Member
    Travis
    So 2 shims up front on each side give you 2 inches of lift? And the trd pro kit sold on the website only includes 1 set good for 1 inch of lift correct?
    Rica25 likes this.
  3. Nov 25, 2019 at 10:50 AM
    #153
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    You're still able to align the truck with your OE tie rods but once the truck is in motion the amount of travel produced exceeds what they can handle. You'll notice bump steer and a bit of wheel chatter without upgrading. Our Coachbuilder steering kit provides 30% more travel in the steering and will cycle much smoother. https://www.shopcoachbuilder.com/co...ucts/coachbuilder-oe-replacement-steering-kit
    Rica25 likes this.
  4. Nov 29, 2019 at 2:31 PM
    #154
    Coachbuilder1
    David
    Salt Lake City UT
    Rica25, DjSamthrax and Voyagermike like this.
  5. Nov 30, 2019 at 6:03 AM
    #155
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Minnesota
    2020 TRD Pro Tundra, 8371 Club
    Coachbuilder Pro Kit, 35x12.5 BFG KM3s, Baja S8 hood mounted, Rago Lo-Pro Brackets sitting empty at the moment, Rago Dash Divot Plate, AJT Stuff, LED Lighting throughout, TRD Intake, Bedliner, Tint, Full front PPF, SPS Graphene Coating, and dropped the B out of JBL ;-)
    ORDERED!
    Very excited to get these in!
    Rica25, Coachbuilder1 and Voyagermike like this.
  6. Nov 30, 2019 at 12:30 PM
    #156
    HighOctane
    HighOctane New Member
    SFV
    2019 White Tundra
    Just placed my order aswell!!
    Coachbuilder1 likes this.
  7. Dec 17, 2019 at 10:07 AM
    #157
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
    For you guys running shims up front. I'm curious about ride quality.
    I LOVE the stock ride of my 2020 Pro. Did you notice that adding 2 shims on the driver side( for 1" lift), and one shim (for .5 inch lift) on the passenger side effect the ride quality?
    I'm definitely getting shackles for the rear. And I'm debating between one shim on the driver side to correct the lean, or 2 drivers and 1 passenger for .5 in lift.
    TIA
  8. Dec 17, 2019 at 1:50 PM
    #158
    Weavin Pro
    Weavin Pro New Member
    2020 Army Green TRD PRO
    So, just installed my PRO KIT last weekend. 1 shim equals 1” with this kit...I do not have a lean? Don’t know what that is about? My 2020 Pro now sits perfect...about 1” higher in the back for a factory looking rake.
    So I had 295s installed before the lift was put on. That is where you see/feel your ride difference. Going from basically a street tire, to a 10 ply rated AT is a big difference. IMO a much better, firmer ride. Installing the lift did not change the ride...maybe handles a percent different??? But ride quality is the same.
  9. Dec 17, 2019 at 2:10 PM
    #159
    Coachbuilder1
    David
    Salt Lake City UT
    On the PRO's we use the same shim size on each side, this is why we designed a specific shim for the PRO's. adding the shims won't change ride quality because we're not adding any additional preload to the coil itself and would def recommend using our full Coachbuilder TRD Pro kit rather than just shims and shackles.Let me know if you'd like to go over in better detail. call anytime David 801.635.4872
    https://www.shopcoachbuilder.com/collections/frontpage/products/coachbuilder-trd-pro-kit-2015
    Rica25 likes this.
  10. Dec 17, 2019 at 2:11 PM
    #160
    Coachbuilder1
    David
    Salt Lake City UT
    Ive been excited to see your truck go together. If you have any pics to share.. LETS SEE THEM!!!!! :yes:
    Rica25 and Voyagermike like this.
  11. Dec 17, 2019 at 5:26 PM
    #161
    Weavin Pro
    Pictures don’t do it justice!
    The Coachbuilder Pro Kit is awesome! Very high quality, straight forward install. The perfect stance for the Pro!
  12. Dec 18, 2019 at 11:23 AM
    #162
    DjSamthrax
    Minnesota
  13. Dec 18, 2019 at 11:35 AM
    #163
    Moco
    Moco New Member
    Marcos
    Boerne
    2019 Tundra TRD Pro, 2015 JKU Rubicon, 2016 HD 48
    In the same boat, can’t wait to get the email with the tracking number. Good things come to those who wait
  14. Dec 18, 2019 at 11:48 AM
    #164
    TownTRD
    TownTRD New Member
    Cris
    Bay Area, CA
    2020 Army Green TRD PRO CM
    Rica25 and Coachbuilder1[QUOTED] like this.
  15. Dec 18, 2019 at 1:06 PM
    #165
    Weavin Pro
    Yes, just the Coachbuilder shackles in back! Like I said, this kit makes the Pro look perfect!
    Sitting at the alignment shop now...fingers crossed the rubbing is corrected!!!
  16. Dec 18, 2019 at 1:22 PM
    #166
    DjSamthrax
    Minnesota
    I trust you have them the coachbuilder specs listed on the website?
    Rica25 likes this.
  17. Dec 18, 2019 at 1:40 PM
    #167
    Weavin Pro
    So live update...the Tire Discounters that I am at does not have the 2020 software for the alignment specs yet! They cannot set it to 2019 standards because of lane control and brake assist features have changed. They will set it good to drive today, no charge...and I will be back in a couple weeks to set to Coachbuilder specs.
    Rica25 likes this.
  18. Dec 18, 2019 at 4:26 PM
    #168
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    Looks great!
    What size tires you running?
    Rica25 likes this.
  19. Dec 18, 2019 at 5:01 PM
    #169
    Weavin Pro
    I have Falken Wildpeak AT3W in 295/70/18 on factory TRD wheels.
    Mtriple, Rica25 and Squeaky like this.
  20. Dec 19, 2019 at 8:55 AM
    #170
    tmart
    tmart New Member
    Travis
    see I’m confused, does 1 shim per side equal 1 inch or lift or 2 per side is 1 inch? And how many shims per side does the pro kit come with??
  21. Dec 19, 2019 at 10:12 AM
    #171
    Weavin Pro
    The Pro Kit comes with one shim per side, equaling 1” of lift.
    From what I understand...the Pro shims are made specifically for the Pro.
    I’m sure David could clarify this better than me.
    Rica25 likes this.
  22. Dec 19, 2019 at 10:20 AM
    #172
    tmart
    tmart New Member
    Travis
    So you can add 2 more with your order to equal 2 inches of total lift...? Some clarification would be appreciated
    Rica25 likes this.
  23. Dec 19, 2019 at 11:19 AM
    #173
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    Not sure you would want 2"s of shim lift...the pro is already "lifted" with stock suspension vs. a non-Pro....if you added 2" worth of shims you would be at some horrible strain and angles on your front diff axles and your UCA, and not to mention probably a nightmare to align.
    Rica25 likes this.
  24. Dec 19, 2019 at 11:31 AM
    #174
    tmart
    tmart New Member
    Travis
    well I would get ucas...my problem is I just want to fit 37s without to much chopping lol
    Rica25 likes this.
  25. Dec 19, 2019 at 11:34 AM
    #175
    LogCabins
    'Merica
    2017 TRD Pro
    Rica25 likes this.
  26. Dec 19, 2019 at 12:13 PM
    #176
    tmart
    tmart New Member
    Travis
  27. Dec 20, 2019 at 6:35 AM
    #177
    19TundraPRO
    19TundraPRO New Member
    AZ
    Looking for feedback, my 2019 Pro is stock with Nitto 285/70/18s and the rear measures 5/8" higher than the front as it sits without a load. I was considering adding the CB +1 rear shackle to give it a little more lift in the rear and take advantage of the ride improvement with the poly bushings. Is that enough or go +2? Would I need the carrier bearing spacer with +1 or +2? Opinions???
  28. Dec 20, 2019 at 6:51 AM
    #178
    LogCabins
    'Merica
    2017 TRD Pro
    Honestly just call David 801-635-4872 @Coachbuilder
  29. Dec 20, 2019 at 11:56 AM
    #179
    19TundraPRO
    AZ
    Talked to David - Thanks. He said there is a mix depending on truck usage and personal preference.
    After jacking it up to both heights, I thought the +1 looked better and ordered it. I don't have a load in the back all the time and if I did then +2 is the way to go. With 230 lbs (me) on the bumper it sags 1".
  30. Dec 21, 2019 at 2:59 AM
    #180
    Huckwheat
    Huckwheat New Member
    Scott
    Adirondacks
    2025 MGM Platinum Hybrid TRD
    Hey 19 T-PRO, any rubbing with the 285/70/18's?
    Rica25 likes this.
