The Coachbuilder TRD Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by trdpro144, Mar 29, 2018.
  1. Oct 16, 2018 at 5:39 AM
    #91
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    1 shim per side. Only thing pro is my grill don’t hate!
  2. Oct 16, 2018 at 5:52 AM
    #92
    ungaze
    ungaze New Member
    2013 4.6L V8 DC Tundra
    Clean build
    Rica25 likes this.
  3. Oct 18, 2018 at 8:37 AM
    #93
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Ok. I may be getting a 19 white. I like the wheels, but am used to the 20 inch and my KO2'S. What are you guys doing to fill the gap? And keeping stock wheels??
  4. Oct 18, 2018 at 10:51 AM
    #94
    Airfire06
    Airfire06 New Member
    2016 trd pro
    Nothing yet
    295/70r18 no need do any mods
    Darth Tundra and netranger6 like this.
  5. Oct 18, 2018 at 12:40 PM
    #95
    netranger6
    Jeremy
    Ok. Test drove it. Never mind. The Trd exhaust kills the low end. Just as I suspected.
    Rica25 likes this.
  6. Oct 18, 2018 at 12:41 PM
    #96
    netranger6
    Jeremy
    Steering wheel felt smaller too as did seats. My cloth ones feel wider.
  7. Oct 18, 2018 at 12:45 PM
    #97
    netranger6
    Jeremy
    I have 285 55 20 now. Wonder if stock PRO wheels just felt weird to me
  8. Dec 27, 2018 at 10:04 AM
    #98
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Hey all. Are UCAs needed on the PRO after adding CB shims?
  9. Dec 27, 2018 at 1:29 PM
    #99
    cjscinta
    cjscinta New Member
    Nashville TN
    No. Stock TRD Pro ucas.
  10. Dec 27, 2018 at 2:27 PM
    #100
    209TRDPRO
    209TRDPRO New Member
    2016 Tundra TRD PRO
    Just lights for now
    Nope.
  11. Jan 4, 2019 at 7:27 PM
    #101
    pitts101
    pitts101 New Member
    2016 TRD Pro
    are these still available? I couldnt find them on your site?
    Rica25 likes this.
  12. Jan 6, 2019 at 1:01 PM
    #102
    sato_unit
    sato_unit New Member
    Abbitt
    Tundra TRD PRO
    Need to order this kit finally
  13. Jan 8, 2019 at 3:58 PM
    #103
    okstate
    okstate New Member
    Question for the ride quality?
    I had the +3 shackles installed and 295/70/18 Toyo Open Country A/TII. I now feel more bed bounce in the right rear then usually did before. Has anyone experienced this? Could it be a tire lost its balanced adding to it? Would it be if the poly bushings weren't installed and they used the OEM bushings?
    Thoughts @Coachbuilder1? Anyone else?
  14. Jan 8, 2019 at 5:07 PM
    #104
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Take a look underneath and take some pics of the shackles/bushings
  15. Jan 11, 2019 at 6:53 PM
    #105
    InfernoPro15
    InfernoPro15 New Member
    What does the steering kit do exactly? Is it necessary?
    monaco730 and Rica25 like this.
  16. Jan 12, 2019 at 9:01 AM
    #106
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Any rubbing on the front cab mount or did you get it chopped? Asking because I’m thinking about going 35s on stock wheels also.
  17. Jan 12, 2019 at 10:36 AM
    #107
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    The kit replaces the ball joints and tie rods from steering rack to the spindle. They articulate and function at the higher angle as a result of lifting the truck. As the LCA is pushed down further with the CB spacer(or any +3 lift), the angle at the rod becomes greater. This steering kit accommodates for this greater angle without binding.
    Hope this helps
    escuzi_me likes this.
  18. Jan 12, 2019 at 10:48 AM
    #108
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    What is the carrier bearing drop for? It came with CB +3. Install is next week so just curious.
  19. Jan 12, 2019 at 11:00 AM
    #109
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    The carrier bearing drop is a spacer kit that lowers the carrier bearing bracket down 1". The bearing is a mid-driveshaft support and stabilizer for our really long driveshaft. As you push the axle down with the shackles, the driveshaft angle increases. The drop reduces that angle.
  20. Jan 12, 2019 at 11:37 AM
    #110
    4Runner
    4Runner New Member
    Columbia, SC
    Got it. Thanks.
    Toyotoholic likes this.
  21. Jan 12, 2019 at 5:35 PM
    #111
    InfernoPro15
    got ya, thanks
    Toyotoholic[QUOTED] likes this.
  22. Jan 26, 2019 at 11:44 PM
    #112
    SK_Tundra
    Stockton Ca
    What rear shackles are u using?
  23. Jan 27, 2019 at 7:16 AM
    #113
    Juddrussell
    Juddrussell New Member
    Jacob
    Bentonville, AR
    2016 MGM Tundra TRD Pro
    BAMF Bedrack, 295/70/r18 General Grabbers, Bedslide, Weathertech floor mats, and Tepui Autana Sky RTT.
    Coachbuilder +3 shackles, carrier bearing drop kit, 1 (1/2”) shim each side up front and bumpstop extensions, very happy with it! Running 295/70r18 general grabber X3’s.
  24. Jan 27, 2019 at 8:42 AM
    #114
    hunter35745
    hunter35745 New Member
    Keith
    Midlothian, Va
    2018 Tundra Platinum Super White
    Ionic 5" stainless tube steps, Weathertech vent visors front and rear,Weathertec all weather mats, Shorty antenna, TRD cold air intake,oil cap,radiator cap ,rear sway bar and dual exhaust,console safe, color match mirror caps,gloss black color match door handles, Tinted D&P front windows, Line X Premium spray in bed liner, TRD front swaybar
    I beg to differ on the TRD dual exhaust killing low end torque, I have it on my 18 Platinum, and it will plant you in the seat and take off like a scaulded dog from dead stop to rolling at 10 mph, however from 45+ mashing the pedal to the floor is just a steady climb and not very rapidly. This has nothing to do with the exhaust just how the power and torque curve work on these motors. That part was the same before dual install as it was with my totally stock 2010.
    Tundra_361 likes this.
  25. Jan 27, 2019 at 5:45 PM
    #115
    TrdUllrPro
    TrdUllrPro New Member
    Bozeman, MT
    2015 TRD PRO DC
    Fuel Vector 18x9, 295/70 Yokohama Geolander MT, AFE Dry Pro S Air Filter, TRD Air Flow Accelerator, carbon air filter delete, Firestone airbags, stubby antenna, inlay decals, WT mats, frogskinz center console, Leer topper.
    Can you update me on the status of your rig with regard to the plastic trim you removed in the front wheel well? I’ve been debating this mod but wondered if it’ll throw too much dirt into the fog light area.
    Rica25 likes this.
  26. Jan 27, 2019 at 6:16 PM
    #116
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    If you follow the trimming on this thread, then you will maintain the same coverage of the fog lights as the stock setup.
    https://www.tundras.com/threads/where-do-i-trim-this.11691/
    Rica25 likes this.
  27. Jan 30, 2019 at 12:24 PM
    #117
    pitts101
    pitts101 New Member
    2016 TRD Pro
  28. Jan 30, 2019 at 12:46 PM
    #118
    15whtrd
    15whtrd Mr. Blonde
    I was hoping to see a picture of somebody with the stock pro set up. No shims in the front and +3 shackles in the rear. I have shims for the front but did not install them.
  29. Jan 30, 2019 at 1:58 PM
    #119
    Juddrussell
    Jacob
    Bentonville, AR
    I installed shackles first and felt it had a good stance without the front shims but i have a pretty good static load in the back with a bedslide and full bed rack 100% of the time. I decided i wanted to install the shims as i will most likely do a new leaf spring pack next. I had a picture of it just like you are requesting but cannot seem to find it.
    15whtrd[QUOTED] likes this.
  30. Feb 18, 2019 at 9:09 AM
    #120
    okstate
    okstate New Member
    This is my truck installed with the Coachbuilder +3 shackles and stock up front with Toyo Open Country Extreme A/T II. I have the shims for the front but have not gotten around to installing them yet.
