The Coachbuilder TRD Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by trdpro144, Mar 29, 2018.
  1. Jul 19, 2018 at 12:12 PM
    #61
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Sounds great, much appreciated!
    Email works just as well.ekstrom_design@yahoo.com. Thanks!
  2. Jul 21, 2018 at 8:29 PM
    #62
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    What tent is that? How many does it sleep?
  3. Jul 30, 2018 at 4:43 PM
    #63
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Hey quick Q. Do i need bump stop spacers for the double shims up front? Im going to put 4 shims up front (two on either side) and wasn't sure if i needed anything for the front besides some loctite.
  4. Jul 30, 2018 at 5:03 PM
    #64
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Hey, what color thread locker do i use for the front shims? blue or red?
  5. Jul 30, 2018 at 10:03 PM
    #65
    Coachbuilder1
    David
    Salt Lake City UT
    Our Front bumper shim kit slides the bumper forward just a touch (.50") allowing extra tire clearance. needing to install will depend on tire/wheel combo along with offset. You can always install everything and then check clearance, if you need a set let me know. We have plenty built and ready to go. Blue Loctite is great for the studs above the coilover top plates.
  6. Aug 3, 2018 at 5:21 PM
    #66
    Jimes
    Jimes New Member
    Bay Area, California
    2015 toyota tundra trd pro
    So just picked up my truck from the dealership cause they said I had a bent leaf spring. So I am interested in Buying Deaver U748 springs. My question is will those springs work with the coachbuilder +3 shackles I just installed? Or do I need to do anything else besides just swap out springs?
  7. Aug 11, 2018 at 3:27 PM
    #67
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    David let me know the squeaking coming from my tie rods was due to poor lubrication. If you bought the coachbuilder steering kit more than 1-2 years ago, you most likely do not have boots on your tie rods. David sells a set of boots that go over the heim joints so you can keep grease on them. I installed mine today and I finally have a quiet front end. IMG_3388.jpg
  8. Aug 17, 2018 at 7:38 PM
    #68
    cjscinta
    cjscinta New Member
    Nashville TN
    So I want to do the Coachbuilder upgrade to my 2017 TRD Pro. I know the recommended tire size is a 295. I’ve already purchased 275 70 18 ko2s. If I keep the 275s on there will it look odd if I get spacers to give me a wider stance without having to buy wider tires or should I just leave it as is and just put a wider tire on it after I wear the 275s out? Which could take a while because I’m a low mileage driver. If I go with a spacer, what size 1.5 2 inch etc? I would go with a Bora. Thanks for the input.
    Coachbuilder1 likes this.
  9. Aug 17, 2018 at 10:45 PM
    #69
    InfernoPRO
    Scott
    Sacramento
    If you get the steering kit you will need the spacers. The Coachbuilder tie rods will grind on inside of a stock rim. I ran this with no spacers for awhile, but I knew to avoid a hard turn. I now run 1.25” spidertrax spacers. That’s all you need to avoid rub. With your tire size you may be able to get away with adjusting the front liner. If your worried about looking awkward I think 2” would be too much.
  10. Aug 18, 2018 at 5:59 AM
    #70
    cjscinta
    cjscinta New Member
    Nashville TN
    Good info. Thank you Kind sir.
  11. Aug 25, 2018 at 6:26 AM
    #71
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    I have 275/70 with spidertrax and I love how it looks. Could I have gone bigger sure, but overall very happy. I have attached a pic for reference. I also have the CB pro shim kit up front.
  12. Aug 25, 2018 at 8:39 AM
    #72
    cjscinta
    cjscinta New Member
    Nashville TN
    Thank you that looks great. The pic is a big help. What size spacer did you go with?
  13. Aug 25, 2018 at 9:45 AM
    #73
    seniramsu
    Nate
    VA
    1.25 sir.
  14. Aug 26, 2018 at 4:40 AM
    #74
    cjscinta
    cjscinta New Member
    Nashville TN
    Thank you.
  15. Sep 4, 2018 at 3:00 PM
    #75
    Coachbuilder1
    David
    Salt Lake City UT
  16. Sep 4, 2018 at 3:03 PM
    #76
    Coachbuilder1
    David
    Salt Lake City UT
    Great writeup, thanks for posting!
  17. Sep 30, 2018 at 9:15 PM
    #77
    Pipusplace
    Pipusplace New Member
    Josh
    TRD PRO 17
    I just got my coachbuilder kit installed... looks awesome....20180929_084725.jpg
  18. Oct 1, 2018 at 9:07 AM
    #78
    Coachbuilder1
    David
    Salt Lake City UT
    Man that turned out Great!!! :bowdown::muscleflexing:
    What do you think of the ride quality and handling after your install?
  19. Oct 1, 2018 at 11:35 AM
    #79
    HornFrog
    HornFrog Go Frogs!
    Fort Worth
    2016 MGM SR5 4x4 Crewmax
    TC UCA's, King 2.5, Ex-Pelf Bumpers and skids, TRD Pro Grill, 2018 Lights, BD Fogs, FRAC
    :popcorn:
    zachzap361 and Coachbuilder1 like this.
  20. Oct 1, 2018 at 12:54 PM
    #80
    Coachbuilder1
    David
    Salt Lake City UT
    Thank you for the post, I missed it earlier.
    HornFrog[QUOTED] likes this.
  21. Oct 1, 2018 at 12:56 PM
    #81
    Coachbuilder1
    David
    Salt Lake City UT
    You're def able to use our +3"s with any of the Deaver's as well as our poly bushing kit. With them being longer we've had a few guys with aftermarket tow hitches get very close to the hitch. Are you using anything aftermarket other than the leafs?
  22. Oct 2, 2018 at 6:04 AM
    #82
    Jimes
    Jimes New Member
    I ended up going with the stock shackles since I didn’t want it any higher after the custom leafs. They added 2 inches of height alone. My truck sits level with just the king shocks all the way around. My truck doesn’t seem to have much of a lean so I didn’t need the shims. I sold the shims, shackles and poly bushings. I kept and installed the CB steering kit.
  23. Oct 12, 2018 at 10:24 PM
    #83
    Cemented
    Cemented Function over Form
    Manuel
    2017 Cement TRD Pro
    FINALLY installed my +3 shackles, 2 shims up front, bump extensions, carrier bearing spacers. Adding a camper shell so went with +3 on the shackles.
    It’s a tight squeeze getting the 35” spare back up there, but it works if you’ve removed your spare tire guides, make sure the shackles bolts are facing outward, and shove forward as far as you can while raising the tire.
    Looks great, drives great. Happy.
    Yes I know this pic is inconsistent lighting and two different sides, but you can kind of get the picture. Top is before, bottom is after.
  24. Oct 12, 2018 at 10:32 PM
    #84
    InfernoPRO
    Scott
    Sacramento
    What tires are you running? Are you using any spacers? I am still on stock Pro rims too.
  25. Oct 12, 2018 at 10:43 PM
    #85
    Cemented
    Manuel
    2017 Cement TRD Pro
    Running 35x12.50 KO2s with 1.25” spidertrax spacers. I wanted to keep the stock Pro rims and the spacers helped clear the UCA. I’ve had the wheel/tire/spacer setup for about 15k miles so far, just hadn’t installed the CB stuff until today
  26. Oct 13, 2018 at 9:42 AM
    #86
    Coachbuilder1
    David
    Salt Lake City UT
    Excellent job!!! Thanks for posting :burnrubber:
    Cemented[QUOTED] likes this.
  27. Oct 14, 2018 at 4:34 PM
    #87
    Airfire06
    Airfire06 New Member
    2016 trd pro
    Nothing yet
    How did u do the raptor style lights
  28. Oct 15, 2018 at 1:44 PM
    #88
    Coachbuilder1
    David
    Salt Lake City UT
    Pipusplace
    Rica25 likes this.
  29. Oct 15, 2018 at 10:14 PM
    #89
    Pipusplace
    Josh
    TRD PRO 17
    There is a thread about it. Let me see if I can find it for you.. it looks easy but I had a guy do them for me since he was doing other work. Got them on ebay...
    #89
  30. Oct 15, 2018 at 10:23 PM
    #90
    Pipusplace
    Josh
    TRD PRO 17
    Airfire06[QUOTED] likes this.
