The Coachbuilder TRD Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by trdpro144, Mar 29, 2018.
  1. Dec 4, 2021 at 12:18 AM
    #451
    Ron_Pro
    Ron_Pro New Member
    California
    2020 Tundra TRD Pro CrewMax
    I placed my order on 10/23 and received it on 11/4. It looks like I just missed the delay on the bushings. I’ve had them on my truck for a month now and it rides so much better. If you are going to install them yourself, I suggest buying/renting a ball joint press. It will make the install so much easier. I hammered the stock busing out using a 27mm deep socket. It took awhile and it wasn’t easy, but it’s doable. Also, if you plan to mount a 35” tire, make sure the bolt head is on the inside and the lock nut is on the outside. Just thought I would share a couple of learning lessons from my install.
  2. Dec 4, 2021 at 12:37 AM
    #452
    jbcrewmax
    jbcrewmax New Member
    SETX
    2019 TRD Pro
    Man those RW wheels look just about perfect on this setup.
    COTundra23 likes this.
  3. Dec 5, 2021 at 4:38 AM
    #453
    DDOC1840
    DDOC1840 New Member
    2017 tundra platinum
    Magnuson supercharged Elka suspension SPC UCA’s RAS HD Diamond back cover w/ Yakima HD Rack All led lights and fogs diode dyn Coachbuilder TRD Pro kit set to 3” OZ rally raid wheels - satin black 2018+ OEM smoked headlights 295/70R18 Baja boss AT Ceramic coated
    Just finished the pro kit. Ride quality and steering is noticeably better! Back end handles better over bumps w/ the shackles - I really like it!
    I paired the CB kit with -
    OZ RR +30 wheel offset w/ 295/70/r18 Baja Boss AT, Icon delta joint UCAs and Mev tech LP inner tie rods.
    Thx to all on this forum for the info about this setup. I would have never found out about it as no off-road shops around here push this one.
  4. Dec 7, 2021 at 12:15 PM
    #454
    FloatinGator
    FloatinGator New Member
    TD
    2018 Crew 5.7L 4x4
    I have the boss coilovers and rear shocks, the diff drop kit and new JBA UCAs waiting to go...
  5. Dec 12, 2021 at 6:19 PM
    #455
    InfernoPro15
    InfernoPro15 New Member
    So I just got my Westcott kit, two questions: why did it come with shims? Thought it was just a preload collar kit and does anyone know what those 4 washers are for? Appreciate the help.
  6. Dec 13, 2021 at 3:24 AM
    #456
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    The shims work in conjunction with the collar to give approximately 1.5”-2” of lift. The four washers are your bump-stop extenders.
    excelw and InfernoPro15[QUOTED] like this.
  7. Dec 23, 2021 at 6:04 AM
    #457
    FloatinGator
    TD
    2018 Crew 5.7L 4x4
    got the shackles, everything is ready to go on.
    boostedtrdpro likes this.
  8. Mar 2, 2022 at 8:49 AM
    #458
    FloatinGator
    TD
    2018 Crew 5.7L 4x4
    Well, I got the shackles, made the appt for the install, had them installed and had some issues with the install shop.
    #1 they scratched my truck
    #2 they failed to tighten the nut in the collar at the top of the passenger side coilover
    and #3 they did not replace the friggin bushings in the rear leaf springs when they put the new coachbuilder shackles on.
    I don't understand... I had the friggin instructions printed out for them.
  9. Mar 2, 2022 at 8:52 AM
    #459
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    That sucks man, a lot of this boils down to laziness and not liking being told what to do by the customer. In their defense, those bushings aren't for the faint of heart...but if it were part of the deal and you were clear up front about wanting them installed, I'd bitch about it. Sounds like I'd just demand a partial refund though and do it myself if they were THAT incompetent. Sorry they scratched your truck man!
  10. Mar 2, 2022 at 8:54 AM
    #460
    FloatinGator
    TD
    2018 Crew 5.7L 4x4
    it was part of the deal, obviously can't take it back to them and have a hard time talking to incompetent people, going to send a registered letter demanding a refund.
  11. Mar 2, 2022 at 12:01 PM
    #461
    FloatinGator
    TD
    2018 Crew 5.7L 4x4
    so I call them, tell them they didn't install the bushings, the shop manager tells me they did and he watched them do it, turns out they didnt change the rear leaf spring eyelet bushings, they replaced the frame bushings, I called Ekstrom design and they were nice enough to call the shop and tell them they had messed up. then I called the shop and asked for a full refund , made an appt with another shop to fix their mistakes.
  12. Mar 2, 2022 at 12:14 PM
    #462
    FISHN43
    FISHN43 New Member
    Ohio
    That sucks. I have a hard time trusting anyone to do anything on my vehicles or work on my house. I always say “If you want something done right, you better just do it yourself.”
    I did the shackle install myself. Sprayed the leaf spring eyelet bushings four times with Blaster PB starting two days prior to my install. Then used a ball joint press and impact wrench to remove them. It took a little trial and error to get it set up right in order to push against the metal sleeve (used a series of different sized sockets) but once I got that figured out they came right out with no issues. Install of new bushings and shackles was super easy. Took me probably an hour or hour and a half (including clean up) to do the job.
    nasher75 and FloatinGator like this.
  13. Sep 5, 2022 at 10:22 PM
    #463
    Luke_Skywalker
    Luke_Skywalker New Member
    Luke
    2020 Tundra TRD Pro
    Eibach TRD Pro Front Springs, Dirt King UCA's Coachbuilder +3 shackle (poly bushings)/carrier bearing drop, steering upgrade, bumper shims, White Knuckle Sliders, Leitner Designs, Baja Designs, Switch Pro, Victron Solar, BORA 1.25", BFG KO2s, Wheelers Superbumps, VLED interior lights, 12" Sub, Window Tint.
    Out of curiosity, has anyone installed this kit and not installed the steering components. According to Ekstrom, the steering stuff is the reason wheel spacers are required.
  14. Sep 6, 2022 at 5:30 AM
    #464
    FISHN43
    FISHN43 New Member
    Ohio
    You don’t have to install the steering kit. Many just buy the strut shims and shackles and run with those.
  15. Sep 6, 2022 at 6:31 AM
    #465
    COTundra23
    COTundra23 New Member
    This is what I plan on doing..shims and shackles
    FISHN43[QUOTED] likes this.
  16. Oct 3, 2022 at 8:18 AM
    #466
    MrZack
    MrZack New Member
    Zack
    2016 Tundra TRD Crewmax
    So I'm considering the TRD Pro kit, or even just shims and shackles, and the site says this for wheel fitment:
    ** Requires +30 mm / +25 mm / +20mm / +18 mm offsets if using 18" wheels
    The wheels I am considering are 18x9 +12. Tire sizes are a toss up between 285/75/18 because I just loved the Duratracs on my 4runner or if necessary, I'll run 295/70s
    Will this work together?
    Also, should I wait for any anticipated black Friday deals? I just know the later into the season I wait, the more miserable I'll be installing it in the colder temps
  17. Oct 3, 2022 at 8:48 AM
    #467
    COTundra23
    Every truck is different but I would that that would work. For reference, I have a TRD pro on stock fox suspension with 285/75/18 ridge grapplers.. and had to cut a good bit of the inner fender liner and use wheel spacers
    that being said, I think the duratracs run a tad smaller because I’ve seen other pro users with that tire and size on stock suspensipn and no rub at all
  18. Feb 15, 2023 at 9:31 PM
    #468
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    I have a brand new in box full Trd Pro Coachbuilder kit for sale! $700.00 DM me if interested. I will be putting it up in the for sale thread next week!
  19. Apr 20, 2023 at 5:38 PM
    #469
    a_double
    a_double New Member
  20. Apr 20, 2023 at 6:10 PM
    #470
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    @a_double Thats what i used, along with PB blasting them, a little heat from a torch, and because toyota uses these metal sleeved bushing I had to bring out the sawzall. I also had a rubber mallet, channel locks to grab and turn the sleeve once it pops out some. And I had a piece of pipe the diameter as the sleeve that I jammed into the leaf so that I could smack it with the rubber mallet. One side came out in 5 min, the other in 20.
    a_double likes this.
  21. Apr 20, 2023 at 6:29 PM
    #471
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    I rented this same tool from my local auto parts store. Worked well. It wasn't as much of a PITA as I thought it would be.
    a_double[QUOTED] likes this.
  22. Apr 20, 2023 at 6:43 PM
    #472
    a_double
    a_double New Member
    That tool doesn’t have a fitting that sizes up against the sleeve, thus allowing it to be pushed out with the clamp?
  23. Apr 20, 2023 at 9:27 PM
    #473
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    I don’t understand the way you worded that. If you don’t have the sizing correct you’ll find that once the sleeve does come out you’ll max out the tool before the bushing is all the way out and you’ll have to pound the rest of it out.
    Grab a buddy, and a good impact gun before you start to drive the tool. The vibration helps
  24. Apr 20, 2023 at 9:43 PM
    #474
    a_double
    a_double New Member
    I guess you’re saying the tool isn’t adequate? In other words, additional tools/techniques are needed.
  25. Apr 21, 2023 at 10:30 AM
    #475
    Luke_Skywalker
    Luke
    2020 Tundra TRD Pro
    The tool is adequate, in fact i don’t see how you would possible do it without the tool short of removing the whole leaf and using a press. But yes, you will need additional tools unless you’re very lucky and they slide right out. I have yet to see a post of someone who’s done it and had no issues.
  26. Apr 21, 2023 at 10:41 AM
    #476
    FISHN43
    FISHN43 New Member
    Ohio
    I used the ball joint press, a socket (I don’t remember the size) that mated against the metal sleeve of the bushing, and impact wrench and they came out relatively easy. My truck was less than a year old when I did it so there wasn’t much if any corrosion and I also used PB Blaster for two days on the bushings before I did the job to help loosen ‘em up.
  27. May 27, 2023 at 1:46 PM
    #477
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
    Had to make a few mods to fit these but totally worth it
  28. Jul 10, 2023 at 1:00 PM
    #478
    COTundra23
    Anyone have any hub to fender measurements post install?
  29. Jul 31, 2023 at 10:27 PM
    #479
    a_double
    a_double New Member
    I just installed my +2 CB shackles and durobump stops on my 21 Pro. It looks great with the rake IMO. It feels a lot better too, the rear feels less restricted.
    The aforementioned tool worked but you do need a socket or something else of a slightly less diameter than the bushing sleeve, to use on the tool plunger/drive side.
    Gotta take her in for an alignment.
    @COTundra23 I can get you the rear if you're interested in the results after a +2 CB shackle install. I don't have the front CB shim/steering setup.
  30. Sep 23, 2023 at 1:40 PM
    #480
    robstruck
    robstruck New Member
    2016 Tundra Trd
    Pro comp leveling with 305/65r18 bfg ko2, magnaflow exhaust, tanneu cover, alpine speakers
    Hey all, a bit late to the forum. Got front portion of the pro kit done last night and i gotta say first ride impressions are not good. Had 35's installed last week and felt a bit heavier but pretty good overall. Now i can feel bumps alot more. I know my alignment is off so hoping that will make a difference but not likely. I know everyone seems to love theirs and thats why i got mine. Anyone run into any issues?
    Coachbuilder1 likes this.
