The Coachbuilder TRD Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by trdpro144, Mar 29, 2018.
  1. Oct 14, 2021 at 7:38 AM
    #421
    FISHN43
    FISHN43 New Member
    Ohio
    2020 Super White TRD Pro
    Look on top of your shock mount where the strut bolts on. Measure the remaining threads on top. If you already have the 1/2” shim in there from Wescott I bet you won’t have enough thread to get another shim in there. 1/2” pretty much maxes it out.
  2. Oct 14, 2021 at 3:10 PM
    #422
    Deepsea121284
    Deepsea121284 New Member
    Yeah I looked. Not really any threads their but per a conversation with David at coachbuilder. Those studs are similar to wheel studs and can just be pressed out and replaced with longer ones. After measuring my truck though it doesn’t appear to have a driver side lean. I guess it just appeared to have it when I was looking at it in my driveway that’s not all that level.
  3. Oct 15, 2021 at 3:10 PM
    #423
    FISHN43
    FISHN43 New Member
    Ohio
    Mine looks like it leans sometimes to depending on where I park. Thats just the nature of suspension on different terrain. Glad your all good though!
  4. Oct 15, 2021 at 5:25 PM
    #424
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    35x12.50 Toyo OC A/T III’s mounted, MAN, this thing rides SO smooth compared to those Nittos.
  5. Oct 15, 2021 at 5:40 PM
    #425
    FISHN43
    FISHN43 New Member
    Ohio
    Daaaaamn!! Looks so good! Any rubbing? Hows your UCA clearance?
  6. Oct 15, 2021 at 5:45 PM
    #426
    boostedtrdpro
    Jeremy
    Thanks man, I still have a ton to do. It’s dark and I just got home not too long ago. I have to take it all back apart and install the steering kit and spacers, then take the grinder to the tabs in the spare tire compartment to get the new spare to fit. I’ll be sure to follow up, she’s still a ways from done. The tire shop couldn’t get the tpms to cooperate and said I need to come back Monday for them to dismount the uncooperative wheel/tire so they could visually see the serial number on the sensor. Their autel machine wasn’t picking up on it or something. They said the sensor could be junk…I call BS. Wonder if I can re-learn the tpms with Techstream. I’ll have to check it out. Anyhow, I’ll dig into more stuff tomorrow and post more info and pics!
    FISHN43 likes this.
  7. Oct 15, 2021 at 5:57 PM
    #427
    FISHN43
    FISHN43 New Member
    Ohio
    It sure is coming along nicely!
    boostedtrdpro[QUOTED] likes this.
  8. Oct 16, 2021 at 2:36 PM
    #428
    boostedtrdpro
    Jeremy
    Spacers and steering kit installed.
    Wheel poke before spacers
    Wheel poke after spacer install
    Stance as she sits now
    Pretty happy with the results, thanks for everything @Coachbuilder1 !
  9. Oct 17, 2021 at 4:02 AM
    #429
    FISHN43
    FISHN43 New Member
    Ohio
    Turned out great! Are those 1” or 1.25” spacers?
  10. Oct 17, 2021 at 6:50 AM
    #430
    boostedtrdpro
    Jeremy
    They are the 1.25” Boras that David recommended.
    FISHN43 likes this.
  11. Oct 17, 2021 at 9:32 AM
    #431
    WinterWarlock21
    WinterWarlock21 New Member
    South Jersey
    2016 Quicksand TRD Pro CrewMax
    https://gearproject.co/profile/SandShark21
    I saw you went 35 x 12.5 for tires. You think that's the right move over the 295/70's? I just bought the kit a week ago so I still have some time to figure out the tires I want but I'm still debating on the size.
  12. Oct 17, 2021 at 10:22 AM
    #432
    boostedtrdpro
    Jeremy
    I am pleased with my decision. Obviously I didn’t have both sizes side by side to compare but when I was looking there were only 3 available in the 295/70’s and the 35x12.5 were plentiful. So I scooped up 5 and haven’t looked back. Today the TRD skid gets reinstalled and the spare tire guides get chopped. Pray for me the 35” spare fits between the shackles ha!
  13. Oct 17, 2021 at 10:47 AM
    #433
    WinterWarlock21
    South Jersey
    I’m hoping it does! Let us know and good lucky lol
  14. Oct 17, 2021 at 1:39 PM
    #434
    boostedtrdpro
    Jeremy
    BARELY! I mean 3/16” from the shackles on both sides and about 2” from the dual exhausts.
  15. Oct 17, 2021 at 2:19 PM
    #435
    WinterWarlock21
    South Jersey
    I am glad it fits! I think I'm just going to follow you and go 35's when the time comes, i know if I go 295/70's I will wake up and regret it a week later and start kicking myself.
  16. Oct 19, 2021 at 7:44 PM
    #436
    FitsofRage88
    FitsofRage88 real eyes realize real lies.
    Hill Country, Texas
    2019 FFV CM (3URFBE) 2Gen
    Blackhawk(0CU00) Working on it!
    have you found a way to locate a new tpms sensor id with techstream.
  17. Oct 19, 2021 at 8:19 PM
    #437
    boostedtrdpro
    Jeremy
    I haven’t even hooked it up to the computer just due to lack of free time. Tomorrow morning the truck goes back to the shop that mounted the tires for them to fit a new OEM Toyota sensor. Since that last post I went to Schwab (for an alignment) and Discount tire and they both confirmed the right rear is unresponsive and the alignment tech said he’s 99% sure he heard the sensor flopping around in the wheel on his test drive. I’m reluctant to let these people touch my truck again, but they should be able to at least defend themselves and make it right. We’ll see!
  18. Oct 19, 2021 at 8:25 PM
    #438
    FitsofRage88
    Hill Country, Texas
    i hear that… do you know if tour sensors are 20 degree or 40degree??
  19. Oct 19, 2021 at 9:03 PM
    #439
    boostedtrdpro
    Jeremy
    I do not know. I didn’t order the replacement, the shop did. Sorry I couldn’t be more help.
  20. Oct 25, 2021 at 5:27 PM
    #440
    Ejp1234
    Ejp1234 New Member
    2021 TRD Pro DC Lunar Rock
    For the full TRD Pro kit, what would you say is the total install time for a “medicore” wrench? I saw the youtube video on the shackles, thats easy peezy…. Curious on the front axle goodies.
    Thanks!
  21. Oct 25, 2021 at 5:57 PM
    #441
    boostedtrdpro
    Jeremy
    :rolleyes::cool:
    https://www.tundras.com/threads/need-help-with-stock-shackle-removal.97128/#post-2466261
    Took me about 8 hours BUT, I snapped a bump stop stud off in the frame and had to drop the lower control arm completely and drill it out. Just your average shade tree mechanic enjoying cold beverages the entire time…and stopping for lunch.
  22. Oct 27, 2021 at 1:25 PM
    #442
    Gman8P0W1
    Gman8P0W1 New Member
    Utah
    21 Lunar Pro
    ADD Venom w/Rigid 30” AT Overland Summit KMC: 315/70/17 KO2
    I haven’t add the shackles in yet but I was able to clear a 315/75/17
  23. Oct 30, 2021 at 7:56 AM
    #443
    Ron_Pro
    Ron_Pro New Member
    California
    2020 Tundra TRD Pro CrewMax
    How long did it take everyone to receive their parts or get an update on their order from Coachbuilder? Its been a week since I placed my order and I haven’t received any updates on my order. I sent a direct email and messaged them on this forum and no response. I completely understand the delays that are widespread with shipping, but I was just curious with others recent experience. Thanks!
  24. Oct 30, 2021 at 8:49 AM
    #444
    boostedtrdpro
    Jeremy
    I placed my order on 9/10 and they shipped my TRD Pro kit on 9/29. I also order the Bora spacers on 9/10 and those were drop shipped directly from Bora on 10/12. Patience grasshopper!
    Ron_Pro[QUOTED] likes this.
  25. Oct 30, 2021 at 9:01 AM
    #445
    Ron_Pro
    Ron_Pro New Member
    California
    Appreciate the info! I did not want to come off as complaining at all, because I understand what’s going on right now. I didn’t order the full TRD Pro kit. I just ordered the rear shackles, because I went with another option for the front. I was just curious with everyone else’s experiences. Thanks again!
  26. Nov 4, 2021 at 4:38 PM
    #446
    COTundra23
    COTundra23 New Member
    how was the install for the tie rods?
  27. Nov 4, 2021 at 7:15 PM
    #447
    boostedtrdpro
    Jeremy
    Not bad at all my friend
    COTundra23[QUOTED] likes this.
  28. Dec 3, 2021 at 10:20 AM
    #448
    FloatinGator
    FloatinGator New Member
    TD
    2018 Crew 5.7L 4x4
    any update on yours? I ordered mine mid november, no update since. Just got off the phone with them and they said they are waiting on Bushings from a supplier, about 2 weeks out, I suggested that they communicate over here, when you don't communicate you let people come up with their own answers...
  29. Dec 3, 2021 at 10:33 AM
    #449
    Squeaky
    Squeaky New Member
    Wisconsin
    ‘19 White TRD Pro
    I ordered mine the 1st week of November. No updates either.
  30. Dec 3, 2021 at 10:43 AM
    #450
    FloatinGator
    TD
    2018 Crew 5.7L 4x4
    sounds like its the bushings manufacturer, and the new bushings play a big role in the whole quieter ride thing, David said he had shackles on the shelf waiting to go
    Squeaky[QUOTED] likes this.
