The Coachbuilder TRD Pro
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by trdpro144, Mar 29, 2018.
  1. Aug 27, 2020 at 5:27 PM
    #331
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Had 2 lifted tundras and I never got them. Everything works fine. I guess it really depends on the lift.
    COTundra23 and BurgEER[QUOTED] like this.
  2. Aug 27, 2020 at 5:47 PM
    #332
    G10dra
    G10dra Not a New Member
    @excelw
    in the last 2 pictures, it seems like you have a negative camber. Maybe its just at the picture :notsure:
  3. Aug 28, 2020 at 6:44 AM
    #333
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    2019 Toyota Tundra TRD Pro (Midnight Black)
    leather wrap steering wheel, front window tint, ceramic coating, AMP research power steps, Toyo open country at3 35”x11.5x18, Volk Racing te37xt 18 9.5 0 offset, Rays formula II lug nuts Warn fender flares, Coachbuilder +3, bilstein 8112 front and 8100 double bypass rear, Kenwood excelon 996xr stereo +7” speakers Westcott designs front lift, RAS rear leafs, yota leds, NSV Lightbar
    yea the alignment was out for sure i had an alignment done the next day and it drives great now:thumbsup:
  4. Sep 20, 2020 at 8:40 AM
    #334
    TonyNCo
    TonyNCo New Member
    Tony
    2019 VooDoo Blue TRD Pro
    Audio, 11 channels Kenwood HU, Mini DSP Digital Sound Processor 2 Alpine 4 Channel Amps, 3 Alpine Sub Amps approx 4K watts 3 way Focal in dash, front doors. 6 1/2" in door swapped for 8" 10" Focal Sub, front passenger floor, custom sealed box 2 way Focal rear doors 2 JL Audio 12W6 Subs, behind backseat Aux lights, all but ditch on modified bumper light bar (3 Hella Rally 4000) Spot, Fog, and Euro beam. Euro beam has yellow bulb. 4 White Spot beam LED Ditch 4 Yellow Spot beam LED 42" Curved, Yellow/Fog LED light bar 50" Curved, White LED light bar 295/70/18 Falken Wildpeak, Revolver Bed Cover
    Hello,
    In process of lifting my TRD Pro. To confirm above, a 1/2" shim will give a 1" lift?
    Coachbuilder1 likes this.
  5. Sep 20, 2020 at 10:35 AM
    #335
    Kris p bakon
    Kris p bakon New Member
    2019 Tundra TRD Pro
    Anyone came across this issue and got a fix for it?.. before my CB Pro Kit installation, with 295\70 and took off the front forward flap, I didn't rub. After the install with the same rims and tires, on full left or right driving reverse, I'm rubbing towards the front portion of fender Liners, by that location where the small front mud flap was taken off at. I thought the bumper shims was supposed to clear this out, and it's weird that I'm now rubbing AFTER the lift.
    mdrabicki and Coachbuilder1 like this.
  6. Sep 20, 2020 at 10:47 AM
    #336
    773_eddie
    773_eddie Trd Pro
    Eddie
    Chicago
    Tundra Trd Pro
    12volt remote start, weathertec accessories, Trd Pro decals, Toyota console safe,VLEDS Puddle Lights,Frac Harness,TRD PRO front and Rear Sway Bar,NSV Hood Light Bar,ESP long box,AJT accessories,Thinkware U1000 dashcam, coachbuilder 1/3 Lift, HR LED’s,Pro comp Traction bars, JL complete System wit 2 10” subs, Kenwood DDX9907XR HU
    1 shim up front +3 shackles in rear and 1/8 inch Procomp bracket on the rear leaf so it measures 38 3/4 up front and 41 1/2 in rear from ground to edge of fender
  7. Sep 20, 2020 at 11:03 AM
    #337
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    Hi tonynco yes it does equal 1” of lift
  8. Sep 20, 2020 at 11:04 AM
    #338
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    kris p bakon maybe after you get an alignment it may stop the rubbing you mentioned.
  9. Sep 20, 2020 at 2:46 PM
    #339
    Coachbuilder1
    Coachbuilder1 Industry Leader Vendor
    David
    Salt Lake City UT
    2007 SR5 5.7 Katzkin, LED lighting through out, LED door handles, Color Matched handles & grill surround, CST 3.5" Spindles OME 614 Full Suspension, Coachbuilder +3" Shackles by Ekstrom Design, BHLM,35"/12.5"/20 Nitto Trail Grapplers,BMF SOTA death metal black finish 20"x10" -19 offset.
    Yes, The shims provide a 1:2 ratio.
    iHacker likes this.
  10. Sep 20, 2020 at 2:49 PM
    #340
    Coachbuilder1
    David
    Salt Lake City UT
    This can happen for a few reasons.. Id say the caster is now set higher than it was prior to the lift going on. by lowering the caster the tire will come away from the bumper. If you need a hand going over in better detail please follow up . David 801.635.4872
    mdrabicki and iHacker like this.
  11. Sep 20, 2020 at 6:48 PM
    #341
    Kris p bakon
    2019 Tundra TRD Pro
    Thanks David, I'll definitely hit you up for some advice. I've had this kit installed for a while, and it's a really small fault, I thought the alignment would fix it too, but I'm pretty much used to it now. If I play around with the steering wheel while backing up, and I get it to that sweet spot, I don't really hear it rubbing.
    Coachbuilder1[QUOTED] likes this.
  12. Oct 13, 2020 at 9:39 PM
    #342
    TRDren
    TRDren New Member
    2020 MGM Tundra TRD Pro
    CoachBuilder TRD Pro Lift Kit 1.25” BORA Wheel spacers Chassis Unlimited Front Bumper
    What size tires are you running?
  13. Oct 14, 2020 at 6:21 AM
    #343
    excelw
    excelw AfRo Samurai
    WW
    AB, Canada
    I’m running 275/70/18
    TRDren likes this.
  14. Oct 14, 2020 at 7:29 AM
    #344
    bigheadjack
    bigheadjack New Member
    2016 DC SR5 5.7 FFV 4x4
    Bilstein 5100s BAMuffler Standard 10” BD Platinum GT AFE Pro Dry S Method 705 18" Toyo AT3 LT295/70R18
    dumb question: I like the look/stance this provides, but is it compatible/appropriate for a non-TRD pro model? I’m not sure why it wouldn’t be, but I’m no expert. My truck is a 2016 SR5 DC 4x4.
  15. Oct 14, 2020 at 8:44 AM
    #345
    BUCS_KID88
    BUCS_KID88 New Member
    It wouldn’t do you any good.. the whole point on the TRDpro models it adds lift to the leveling kit And keeps the Heart of the truck (suspension) all same...I guess you can do The shackles +3 and but only provides 1.75 lift. For Regular tundras there’s a lot More options and better lifts out there. Pro’s not many options unless switching whole suspension... lol
    bigheadjack[QUOTED] likes this.
  16. Oct 19, 2020 at 9:24 AM
    #346
    bigheadjack
    Thank you for the reply. Still learning.
    I left my 07 TRD completely stock, but put 5100s on my 2016 (middle setting in the front; stock setting in the rear). I use my bed (mostly deer feed, but I’ll max out the payload) and I tow occasionally (double axle flatbed with a Polaris on it). The truck drags its tail under the load a little more than I would prefer.
    I don’t intend to do anything too aggressive. I might put some 34s on it (with +25 offset) and want to have a bit more rake in the back to negate the dragging effect. I don’t intend to hijack the thread though.
  17. Nov 10, 2020 at 5:49 AM
    #347
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    Question for those in the know, whats the ride difference between 1 shim and 2 up front? Clearly adding shims has to have some affect on the suspensions capabilities right? What are the disadvantages of adding them, less travel, over extending, ride quality ect...?
    Thinking about adding one more shim on each side to get a little extra up front. I have one on each side right now.
    Thanks
  18. Dec 7, 2020 at 12:23 PM
    #348
    SDBRENT25
    SDBRENT25 New Member
    Brent
    2017 TRD PRO
    Has any one stacked an additional .50 shim on top of the inch shim included in the Coach Builder kit? If so, did the have any issues? I want to avoid to much rear rake.
    Thank you
  19. Dec 7, 2020 at 12:25 PM
    #349
    BUCS_KID88
    Umm . I have the one inch and nuts barely tighten..... maybe there’s other options
  20. Dec 7, 2020 at 12:37 PM
    #350
    SDBRENT25
    Brent
    2017 TRD PRO
    Yes, i ran into same problem and then was told The thin shim needs to be installed under the top plate and above the coil. The coil needs to be compressed and center nut removed in order to remove the top plate. The thicker shim sits above the top plate. I am concerned it may cause issue with with UCA's.
  21. Dec 9, 2020 at 7:54 PM
    #351
    Backpacktundra
    Backpacktundra New Member
    Norcal
    2020 trd pro super white
    CB kit 295 coopers
    Just got the coach builder kit installed without the bora spacers on my 2020 trd pro. Caster is slightly out of spec and shop is suggesting new uca's. Stock bbs wheels with 295 coopers. Is it normal to do the uca along with the cb kit?
  22. Dec 9, 2020 at 8:01 PM
    #352
    BUCS_KID88
    I didn’t I got CB full kit installed with 18x9 sr8 wheels and 295’s since brand new. No issues 24k now.
  23. Dec 9, 2020 at 8:06 PM
    #353
    Backpacktundra
    Norcal
    CB kit 295 coopers
    Do you happen to know your caster angle?
  24. Dec 9, 2020 at 8:12 PM
    #354
    BUCS_KID88
    I gave alignment shop the CB alignment specs that they give with the CB kit.... it’s on the website aswell. Zero issues and steering hella straight aswell...
  25. Dec 9, 2020 at 8:13 PM
    #355
    BUCS_KID88
    mdrabicki, Coachbuilder1 and NoRcptn like this.
  26. Jan 1, 2021 at 12:52 PM
    #356
    Quicksand_noob
    Quicksand_noob New Member
    Gerad
    Albany, NY
    2016 quicksand Tundra TRD pro
  27. Jan 1, 2021 at 3:44 PM
    #357
    GarTX526
    GarTX526 New Member
    2016 QuickSand TRD-Pro
    Many pending.....
    That looks great!!!
    What are the wheel and tire specs?
  28. Jan 1, 2021 at 4:17 PM
    #358
    Quicksand_noob
    Gerad
    Albany, NY
    Method NV’s 18x9 +25mm offset wrapped in a 295x70x18 Ridge Grappler
    GarTX526 likes this.
  29. Jan 1, 2021 at 6:54 PM
    #359
    Pitbull410
    Pitbull410 New Member
    2020 TRDPro CM MGM, 2018 LC200 MGM
    What rear shackle did you use?
  30. Jan 2, 2021 at 4:34 AM
    #360
    Quicksand_noob
    Gerad
    Albany, NY
    +3” rear shackle
    Gee Dub and Pitbull410 like this.
