The Big Mystery
Discussion in 'Audio & Video' started by Rbohno, Jun 30, 2020.
  1. Jun 30, 2020 at 4:28 PM
    Rbohno
    Rbohno [OP] New Member
    Rich
    NC
    2020 Tundra CrewMax Limited
    Icon stage 5,method 18 x 9, BFG KO2s, Bushwacker flares, tinted windows,Havoc HST running boards,Weatherguard slimline box, DSR1, JL Audio 900/5 amp, two 10W0 subs in a box, hertz centro in the front and Hertz Uno in back doors
    Hey Guys,
    I have JBL system
    I have changed entire system except for dash speakers( see my signature) from JRT.
    How do I change dash speakers so they play a fuller sound stage all the while allowing center dash speaker to play phone and navigation. I don’t mind changing all dash speakers but want something other than ear piercing treble.
    There are 4 wires going to each corner dash speaker how are you guys wiring this??? I called I-Data Link and they were not helpful at all.
  2. Jun 30, 2020 at 5:40 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Tech 12 volts has replacement speakers for them and so does a couple more but can’t remember who???? DUH!!!:). All plug and play
  3. Jun 30, 2020 at 7:01 PM
    Rbohno
    Rich
    NC
    I know but poor @JRT is having a rough time and am trying to help educate myself and others without stressing James. He is such an asset to this forum and others that he is spread waaay too thin. He responds every time I have called or Emailed and cares for each and everyone of his customers. So my thought is to try and ask questions about my specific situation that we can help each other out.
    AGAIN HATS OFF TO @JRT , he sent me an earth shaking system that I LOVE but am trying to figure out some quirks.
    ROCK ON JRT, GET SOME REST
    Sincerely
    Rich
  4. Jul 1, 2020 at 5:20 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    2017 Tundra XSP CrewMax
    Take the connector from the speaker and take pin 1 or 3 and then 2 or 4 and tap into them. One combo is positive and the other negative.
    The Tundra factory wires are run in parallel so if you unplug them completely and are using the factory wiring, the door speakers will not get any sound. It all runs through the dash speaker plug. I had to figure this out and it drove me nuts until I did.
    Let me know if I can help further
    Rbohno[OP] likes this.
  5. Jul 1, 2020 at 10:43 AM
    Rbohno
    Rich
    NC
    Thanks @Kojack
    My other question is when I hook the front FACTORY tweets to the amp using the wires from the maestro the sound stage is much fuller but waaay too bright.
    If I switch them out with say a 2.75” mid-range such https://www.crutchfield.com/p_20647KSC27/Kicker-47KSC2704.html
    WILL that change that sound like a true mid or will it still be bright like a tweeter?
    Yes one more question there is a pair of wires from the maestro for the center channel. The instructions say to hook the dash corners to the front channel on the amp. So how would I power the center channel?
  6. Jul 1, 2020 at 11:31 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    Then I would say that a 2.75 would fit the bill and not be as bright as what is there now. It's worth a shot. I tried Kenwood 3.5" and they were too deep so make sure you get the most shallow ones you can find. The vent ducts run right under them and there is not a lot of room. I have seen here where some guys would heat up the duct and massage them but air flow, to me, is as important as sound.
    The center dash speaker gets is power from the HU so I wouldn't hook it up to the amp. The center speaker is also as dual voice coil so if you replace it, consider that man. I didn't bother getting a dual. I just hooked into the right side speaker. It's mainly there (IMHO) for speaker phone anyway.
    Just my opinion man... With the amp, you should get the majority of the sound from the doors and tweets (if you have components)
    Hope I helped some.
  7. Jul 11, 2020 at 7:43 AM
    Rbohno
    Rich
    NC
    Hey Mike
    I am golden on everything you said with one more question regarding center dash channel. It’s currently not getting any due to Maestro etc...
    If I were to buy that center channel from James so the phone could play through there “How would it get power to do that “
  8. Jul 11, 2020 at 2:29 PM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    That’s an interesting question man. The center and Front side dash speakers get their power from the HU unless you’re running them through an amp and have run wiring up to them.
    I have the maestro and my center channel works like it should. I don’t know if there is a difference in JBL vs Non JBL though and i have a non JBL truck.
    Maybe someone else can chime in as I can’t say I can answer your question for sure.
  9. Jul 11, 2020 at 4:33 PM
    Rbohno
    Rich
    NC
    Non jbl dash speakers come through head unit.
    JBL all the speakers dash, doors etc run thru amp
  10. Jul 13, 2020 at 5:15 AM
    Kojack
    Kojack New Member
    MIke
    Black Mountain, NC
    If you want to just use the center dash for the speaker phone and have a little sound coming through, I would remove the center dual vc speaker and cut the wires on the connector plug as close to the speaker as possible and just use either the left or right channel to get the sound.
    If you buy from @james@tech12volts , I'm sure he has a plug and play harness since what he sells has 2 speakers in it. On his site, it does show those are out of stock so you may want to email him for confirmation.
