The BETTER Light Bar Bracket - 42" Lower Grille Bracket
Discussion in '2.5 Gen Tundras (2014-2021)' started by memario1214, Nov 10, 2022.
  1. Nov 22, 2022 at 10:04 AM
    memario1214
    memario1214 [OP] Hotshot Offroad Staff Member Vendor
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    Sometimes... Sometimes you begin to lose your mind in the pursuit of perfection. Last night we punched out versions 3 & 4 as testing was underway.
    V2 to V3 Adjustments:
    • Moving end "notch" from the bottom to the top to allow for vertical alignment and placement. In the end we took some material from both the top and bottom to allow those who want to move it around the latitude to do so.
    • Further adjustment of back plate holes to allow for adjustment by end user.
    • Angle change on interaction between backing plate and support arm. We were getting a small gap at the lower-most hole of the plate where it met the frame. When tightening that down it was applying downward pressure to the system and passing that onto the support arm. As a result this was pressing the light bar against the lower bumper. Seemed cool as it made it more sturdy when it was being pressed down by virtue of being pressed against the crash bar, but essentially eliminated the ability to make vertical adjustments.
    V2 vs V3 side-by-side:
    Showing interaction angle changes between V2 (front) and V3
    Welded and smoothed out V3 (assuming we were closing in on final product)
    THEN THERE WAS V4
    As testing continued on V3 it became apparent that we still had not knocked out enough of the vibration for me to be happy with putting the Hotshot name on it. Was it secure? Yes. Did it perform MUCH better than the DD offering? Absolutely. However, I still wanted more. We know we are working with a relatively heavy bar with long distances between support arms whose job is to hold something with a lot of leverage acting against it. That doesn't mean we're going to give up!
    We were left with a few options for how to address:
    1. Re-Engineer into a 2-piece design
    2. Add more material width between upper-most hole and gusset as that is where we were getting our deflection
    3. Further reinforce backing plate
    OPTION 3 IT IS!
    We moved from the already thicker backing plate that we were using up to a 3/8" frame support plate to essentially confirm that we would have enough meat back there to offset the deflections that plague a system like this. The support arm's specs were not changed at all during this change.
    Other changes to V4:
    • Narrowed rear adjustment hole to just slightly larger than bolt diameter (no photos showing). We were going to go with a sleeved approach on the back screw, but were finding that it wasn't applying enough pressure to be a true "support" component which simply cannot be.
    Testing last night finally yielded the result we wanted! Headed over to the powdercoat place here shortly to get final pricing on that, and then I will be able to make this go live! We'll still need to source hardware that are up to our standards, but the hard(est) part is over and we should be able to open pre-orders soon!
  2. Nov 22, 2022 at 10:16 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Any chance you've looked to see if longer studs exist to replace the factory crash bar studs with longer ones? The V4 plates will definitely be too thick to use with both bumper shim plates in place, but I'd be ok losing one to get these brackets in.
    Toe404 likes this.
  3. Nov 22, 2022 at 10:35 AM
    memario1214
    Colton
    Missoula, MT
    Proof of concept here will potentially make way for a shim with an incorporated light bar bracket. That’s a song for another day though.
    The OEM studs are tacked in via a weld and I figure most folks would not be interested in knocking them out.
    TRDFerguson[QUOTED] and Toe404 like this.
  4. Nov 22, 2022 at 11:35 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Newbie to anything under the bumpers on these trucks here: what will I need to do for an installation, in general?
  5. Nov 22, 2022 at 11:39 AM
    memario1214
    Colton
    Missoula, MT
    14mm wrench, probably a breaker bar (or 1/2” ratchet) with a 14mm socket, some zip ties, a trim removal tool (or a screwdriver will work but may mar the plastic) to get the grille mesh out, and an Allen wrench. Sizing on the wrench is still TBD as I secure and decide on hardware.
  6. Nov 22, 2022 at 11:40 AM
    Ghost Rider
    Ghost Rider Mods wouldn't be an issue if money wasn't.
    Ian
    Cypress, Texas
    2021 White Tundra CM SR5
    14mm? At least I didn't lose the 10mm socket somewhere, or did I?
  7. Nov 22, 2022 at 4:01 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM Tundra & 25 TRD Pro Sequoia
    Wow that bracket is not messing around!! Looks awesome!!
    memario1214[OP] likes this.
  8. Nov 22, 2022 at 4:03 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    But you’ve talked to me about this stuff before… :sawzall::welder:
  9. Nov 23, 2022 at 8:32 AM
    memario1214
    Colton
    Missoula, MT
    Thank you kindly! I should be able to have the listing up later today for those jonesin' to pre-order. Did some hard hammering on it in the wee hours this morning to really confirm to myself that this was the spec!
    That sounds like a Jake project... Not one that I would prescribe to the masses :rofl:
    TRDFerguson[QUOTED] likes this.
  10. Nov 24, 2022 at 11:43 AM
    PomDad
    PomDad we having snacks?
    Conrad
    Atlanta
    2021 Cement Limited
    Just ordered the 30" bar this morning from y'all, so definitely would be in the market for a better bracket if you ever adapt this 42" one.
    Thanks for all you do for the community, Colton!
  11. Nov 25, 2022 at 10:49 AM
    memario1214
    Colton
    Missoula, MT
    bulldog93, evanhauer, PomDad and 2 others like this.
  12. Nov 25, 2022 at 11:09 AM
    SnowSquach
    SnowSquach New Member
    Upstate, NY
    2021 Super White TRD Pro
    Wireless Charger Ride-Rite Airbags with Dynastar Cradles Westcott 1.5" Front Lift Coachbuilder +3 Shackles Gator Cover Swingbox Tailgate Power Lock
    Awesome! and ordered! Thanks for your efforts on this.
    memario1214[OP] and RusPro21 like this.
  13. Nov 25, 2022 at 11:17 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Awesome Colton, Just placed my order. Thank you for the better brackets.
  14. Nov 25, 2022 at 11:28 AM
    Ghost Rider
    Ian
    Cypress, Texas
  15. Nov 25, 2022 at 12:31 PM
    memario1214
    Colton
    Missoula, MT
    Appreciate it guys!
    Yessir that's correct. Since you already purchased a big light bar from us though I can do you a little better than the $120 as a thank you for purchasing previously. I saw your order come in so I'll square you up :D
    HulkSmurf14 and RusPro21[QUOTED] like this.
  16. Nov 25, 2022 at 3:22 PM
    robi4901
    robi4901 New Member
    Colton, thank you for being "the real deal". If only everyone cared about doing good as you do. Oh yea, thanks for taking my many calls, even while you were driving to your holiday destination. Just ordered the light kit.
  17. Nov 25, 2022 at 4:32 PM
    memario1214
    Colton
    Missoula, MT
    No problem at all. I'm excited to get these into folks' hands, and everyone's support is much appreciated!
  18. Nov 25, 2022 at 7:29 PM
    Rangergillikin
    Rangergillikin New Member
    Alabama
    2021 magnetic grey TRD Pro Crew Max.
    TracRac bed rack, Retrax bedcover, Anytime forward facing camera, Rago dash mounting plate, changed all lights to LED with 1200lumen reverse light, added LED above tag reverse light, rear bumper step, Go Rhino step sides, CCM Cat Security Shield, tool mounts on bed rails, added tie down pad eye on bed rails.
    It’s awesome that you cared enough to build a good bracket. DD should buy your brackets to include in their stealth kits instead of that useless bracket that comes with it. DD makes some really nice lights but that bracket was awful. You have my business because you seem to care about customer satisfaction. Just bought 9 more lights from you all yesterday. Looking forward to hooking them up. I got another 42" bar to go on my roof rack. Probably will be machining out another bracket for it so that it will fit my rack better than the one that comes with it. Thanks for the support.
  19. Nov 25, 2022 at 7:41 PM
    #49
    evanhauer
    evanhauer Snow Chaser
    Erik
    VT
    ‘16 Tundra CM SR5 TRD OR 4x4
    Heck yeah, Colton. Just ordered and I can't wait to see the final product! :santa2:
  20. Nov 26, 2022 at 10:38 AM
    #50
    Rangergillikin
    Alabama
    Colton I sent you a pm about a order.
  21. Nov 26, 2022 at 7:11 PM
    #51
    memario1214
    Colton
    Missoula, MT
    Truly appreciate the support everyone! Can't wait to get them out to everyone!
    Got it and updated!
    RusPro21 likes this.
  22. Nov 28, 2022 at 8:39 AM
    #52
    memario1214
    Colton
    Missoula, MT
    Just dropped off the first official batch at the powdercoater! Should have them in just a couple of weeks! That'll give me a little bit of time to clean up the rubble from Black Friday festivities and source some suitable hardware.
    For anyone else who may be lurking these will be on sale for just a few more days!
  23. Nov 28, 2022 at 9:01 AM
    #53
    19PlatinumCrew
    19PlatinumCrew New Member
    Dave
    MGM 19 Platinum Crew
    Toytec 3" coilover lift,295/75/18 on Method Nv,Nitto tires,Retrax cover,spray liner.
    Will these work with the smaller stealth bar that sits behind the grill? If so send me a message and I'll order some
  24. Nov 28, 2022 at 9:03 AM
    #54
    memario1214
    Colton
    Missoula, MT
    These will not. Depending on the uptake/feedback of this 42" variant we may look into developing a 30" version though.
    PomDad and MedCityMoto like this.
  25. Nov 28, 2022 at 9:19 AM
    #55
    19PlatinumCrew
    Dave
    Thanks, keep us posted on the 30 bracket...mine moves so much I stopped using it.
    PomDad and memario1214[OP] like this.
  26. Nov 30, 2022 at 11:49 PM
    #56
    Kenny1794
    Kenny1794 New Member
    Ordered mine thx, also do the black friday sale go toward this purchase?
  27. Dec 1, 2022 at 4:22 PM
    #57
    memario1214
    Colton
    Missoula, MT
    BF Promo rates on the bracket are only applicable when bundled with a light bar, unfortunately. Thanks for the order though! We should be getting these out soon.
  28. Dec 1, 2022 at 4:29 PM
    #58
    memario1214
    Colton
    Missoula, MT
    Brackets are back from powdercoating WAY SOONER than we expected! We've started to get ourselves dug out of the Black Friday fulfillment hole so we're back onto R&D projects. We'll spend tomorrow getting the final hardware situation figured out, and then work out sourcing if time permits. Hoping that we can get these orders started to ship late next week which is a week ahead of schedule!
    If you want to jump on these kits we are discounting BOTH the DD light bars AND the brackets through tomorrow (12/2) when purchased as a kit.
    BRACKET KITS LINK
    HulkSmurf14 and TRDFerguson like this.
  29. Dec 1, 2022 at 4:36 PM
    #59
    RusPro21
    Don
    Pa.
    :yes:Getting pumped for my new light bar and brackets!!​
  30. Dec 14, 2022 at 11:18 AM
    #60
    memario1214
    Colton
    Missoula, MT
    UPDATE 12/14 -
    First couple of production-spec test units out in the world! One of which was our own @TRDFerguson. He brought about a concern with a piece of the hardware which is what is our current shipping hang-up, but fortunately they were small issues that are easily remedied.
    I have a couple of orders in to McMaster-Carr, and everything needed shows in stock on their end. I am anticipating that we should have no trouble shipping kits next week!
    E83815DE-B211-41BA-9FF9-E74E8A06EC3A (1).jpg 161AC916-3384-47B4-A799-EB93F4B457FB (1).jpg
    RobertD and TRDFerguson like this.
