The Arctic Rock
Discussion in '2.5 Gen Builds (2014-2021)' started by Wikid, Dec 21, 2017.
  1. Feb 20, 2018 at 1:39 PM
    #91
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Wow!!! Mean ass build brotha!
    That bumper! Hmmmm
    Wikid[OP] likes this.
  2. Feb 20, 2018 at 1:53 PM
    #92
    smslavin
    smslavin New Member
    Hudson Valley
    2016 Tundra CrewMax SR5
    Some stuff
    truck is looking great. are you using a single switchpros unit this time or will you have multiples again?
    this is on my list. really want to get out there and photograph some of that race.
  3. Feb 20, 2018 at 2:14 PM
    #93
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    Great build and great looking truck!
  4. Feb 23, 2018 at 9:18 PM
    #94
    Wikid
    Wikid [OP] New Member
    Don
    Toyota Tundra Crewmax Platinum
    On order
    Thank you. If I get more accessories I may get another one, . I think I may be one short currently :)
    smslavin[QUOTED] likes this.
  5. Mar 8, 2018 at 6:53 PM
    #95
    Wikid
    Don
    On order
    I haven't had a chance to do much to the truck lately.. busy at work !! Taking the weekend off to head to Vegas for the Mint 400. Hopefully I get a chance to play in some dirt. On another note, I am seriously considering doing a full blown long travel set up. I just need to figure out what I want and how to pay for it :) . IMG_1573.jpg
    When I get back, my compressor under the body mount gets some serious work on it. I have a plan. I have had this going for awhile, but I needed to get my welder some electric, so I can finish the mount. That is now done
  6. Mar 8, 2018 at 7:18 PM
    #96
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Holy bajeezus!!!
  7. Mar 8, 2018 at 7:19 PM
    #97
    Eclipsed & Floating
    Voluptuous Whitey
    More accessories??? You might need another truck if you get more
    TheBeast and Wikid[QUOTED][OP] like this.
  8. Mar 8, 2018 at 8:50 PM
    #98
    Eclipsed & Floating
    Voluptuous Whitey
    @DecalsByDesign check this guy’s truck out
    Watt maker likes this.
  9. Mar 8, 2018 at 9:58 PM
    #99
    TheBeast The Beach
    do they make the same bumpers for gen 2s Tundra ?
  10. Mar 8, 2018 at 10:09 PM
    #100
    Wikid
    Don
    On order
    If you go to icionline.com you can select a bumper then it will have a drop down menu for what year. Some only go back to 14-18 some go back to 07 It just depends on the bumper you select. I check for both of mine and they were only listed for 14-18
    TheBeast[QUOTED] likes this.
  11. Mar 8, 2018 at 10:15 PM
    #101
    Wikid
    Don
    On order
    I found a picture that shows how well these Baja Design LP9's actually project. This was actually just the 3 LP9's on a hill overlooking Hammertown. I want to say it was about a mile or 2 away. The dust was bad, but you can see the fill out to the sides, then the beams, projecting straight out front. These lights do it all IMG_1778.jpg
  12. Mar 21, 2018 at 11:15 AM
    #102
    Wikid
    Don
    On order
    I did a little more completion of the light install. I was going to install the Baja Designs 40" S8 in the hood bulge , but thought differently about it and mounted it inside the upper grill. SDHQ makes the mounts for it. You need to change the support that houses the latch and the mount itself
    Here are a few pics of the install and the final product
    The latch itself is pushed back as far as possible with the new bracket, plus the spring is even replaced, because of cleanse issues
    It also involves relocating the horns. One attaches to the center bracket and the other to the side , like you see here
    Clearance issues are key in being able to install this light in the upper location, especially with an intercooler. The hardware is also replaced to squeeze another 1/4 inch for clearance of the back of the light bar
    Here are the results of the install. I think I like the backlit feature, on all the lights
    While I was dong some glam shots, I figured a booty shot was in order
    Watt maker and drumzdj like this.
  13. Mar 21, 2018 at 11:22 AM
    #103
    Wikid
    Don
    On order
    tundraoffroad on instagram is having a March Madness bracket contest. My truck will be posted soon against another truck in the first round . If any of you use instagram and want to go vote for my truck, I would appreciate it.
    Thanks
    I did a mostly complete mod list to condense it
    Flyinryank, TheBeast, cjmay13 and 2 others like this.
  14. Mar 21, 2018 at 11:27 AM
    #104
    drumzdj
    drumzdj New Member
    Oro Valley
    2011 Crewmax 4x4
    Great pic. Where was it taken?
  15. Mar 21, 2018 at 12:21 PM
    #105
    Wikid
    Don
    On order
    Thanks. It was taken in front of the Superstition Mountain Range in Apache Junction AZ
  16. Mar 21, 2018 at 12:36 PM
    #106
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    Good luck!
  17. Mar 21, 2018 at 2:59 PM
    #107
    TheBeast The Beach
    did you remove front sway bar or still have it ?
  18. Mar 21, 2018 at 3:31 PM
    #108
    Wikid
    Don
    On order
    I still have it. I may try it on my next offload excursion to see if you get less jar transfer from the fact that they are connected in the front
  19. Apr 1, 2018 at 3:19 PM
    #109
    Gman16Pro
    Gman16Pro New Member
    16 Super White TRD Pro
    Did you have any rubbing with the initial install?
  20. Aug 13, 2018 at 8:39 PM
    #110
    mgm16trdpro
    Northern NJ
    2016 mgm trd pro crewmax
    What's up Don, I didnt realize you were posting here as well. Seen lot on tc fb. Glad I realized u posting on artica here. Down the road one day I'm gonna bother you on those LP9's probably. Truck looks great.
  21. Nov 18, 2019 at 1:25 AM
    #111
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Are the lights in the balance pinch mounted to the material or is there a bracket behind it? How hard was that material to cut.
    like the look an even though ici is done I may get that trophy bumper as well if the price is right
