The "Added to the list" Thread
Discussion in 'SDHQ Offroad' started by sdhq_offroad, Jan 17, 2017.
  1. Jan 17, 2017 at 2:54 PM
    sdhq_offroad
    sdhq_offroad [OP] New Member Vendor
    GILBERT, AZ
    Hey guys, I wanted to start a thread where I can keep you guys updated on the new products that I have coming in along with some of the products that we carry. I know a few of you guys have been to the shop here in Gilbert, AZ and are amazed at the inventory we keep on hand. Due to the vast amount of product, we are constantly trying to update our website with the new products that we get in weekly, however its hard to get everything on there.
    I will be posting some of the odds and ends that we carry here at the shop that are Tundra specific along with some of the universal application products. Feel free to discuss and ask questions about any of the product posted as well as inquire about something you are looking for that you just can't seem to find.
    I see a lot of questions as far as headlight bulbs as HID vs LED, etc. We like to use the Putco LED replacement bulbs. They are far more reliable than the HID ballast and we have seen a better light spread from these bulbs. These are all US made and use an aluminum body. Instead of using a fan the keep the bulb cool, it uses a ribbon heat-sink design. This eliminates the chances of the fan failing and over heating the unit.
    http://store.sdhqoffroad.com/tundraputcoledlights.aspx
    I keep these in stock on the shelf.
    CM-LENNY likes this.
  2. Jan 17, 2017 at 4:14 PM
    Morgan51
    Morgan51 New Member
    2016 Inferno CM Tundra TRD
    Those are interesting, I wonder if they would produce too much glare in the stock Tundra headlight housings?
  3. Jan 17, 2017 at 5:25 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    What's the pricing and color temp on these?
  4. Jan 17, 2017 at 5:59 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  5. Jan 17, 2017 at 6:34 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Sliders and front bumper :goingcrazy::goingcrazy:
    sdhq_offroad[OP] and 831Tun like this.
  6. Jan 17, 2017 at 6:39 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    ^^^^^^^This
  7. Jan 17, 2017 at 11:27 PM
    Cuzin Eddie
    Cuzin Eddie New Member
    Shane
    2014 CM Black Platinum 4X4
    TRD Supercharged * BDS 4.5 level with Fox Shocks * AMP running Boards * Bed Rug, Spyder Headlights with HID Conversion * 46 Gal TransferFlow Fuel Tank * Fuel 2 Piece Hostage Wheels * 35" Toyo RT's * Backflip Bed Cover * Pioneer Avic NEX8200 with Amp, Speakers & Subs * Trailer Tow Mirrors * N-Fab Bumper Bar with 30" Vision LED Light Bar *
    Will they work in the Spyder Headlights?
    darkknight2014 likes this.
  8. Jan 18, 2017 at 3:38 AM
    Beardedbeast
    Beardedbeast New Member
    Killeen TX
    2013 tundra crewmax
    ALOT!
  9. Jan 18, 2017 at 7:45 AM
    sdhq_offroad
    GILBERT, AZ
    We haven't had any issue as far as "glare".
    They operate at 6500K, which gives you a white w/ a hint of blue. They retail at $209.99 for the pair w/ the anti-flicker harness. PM me for pricing.
  10. Jan 18, 2017 at 7:47 AM
    sdhq_offroad
    GILBERT, AZ
    They are a plug and play bulb. I believe the Spyder headlights are projector correct? You shouldn't have an issue. We have done them in other projector headlights such as the dodge without an issue.
    They make a Silver-Lux Pro model as well which is designed specifically for projectors, so they are brighter (and run a little hotter). The projectors give a more focused beam pattern and due to the projector itself, you don't have to worry about melting the housing from heat from my understanding.
  11. Jan 19, 2017 at 2:08 PM
    sdhq_offroad
    GILBERT, AZ
  12. Jan 25, 2017 at 1:05 PM
    sdhq_offroad
    GILBERT, AZ
    We carry a full array of electrical rocker switches, fuses, heat shrink, and wiring. Our most popular switches being the Air On Board which pop right into the 2005+ Toyota factory switch blanks. They give the OEM appearance without having to cut up your switch location for a bulky rocker switch!
    Air On Board Switches:
    http://store.sdhqoffroad.com/search.aspx?find=air+on+board
  13. Feb 2, 2017 at 10:22 AM
    sdhq_offroad
    GILBERT, AZ
    We stock a full line of oils, fluids, and chemicals.
    We stock pretty much every Lucas Oil product they make along with Swepco, Redline, Bel-Ray, Maxima, Evans Waterless Coolant, Race Gas, VHT, and Dupli-Color. We do stock the K&N Oil Filters as well.
  14. Feb 20, 2017 at 3:58 PM
    sdhq_offroad
    GILBERT, AZ
    This is for all the builders, garage fab guys, and "do it right the first time" guys. We carry pretty much close to any AN fitting you can think of, from push-lock to your normal an fittings to high pressure power steering fittings. We carry Fragola, Aeromotive, Vibrant, and Russell fittings on the shelf. If there is something you need, PM me. We also carry any AN weld bungs in aluminum and steel that you may need.
    Hattori likes this.
  15. Feb 20, 2017 at 7:56 PM
    rockjockey
    rockjockey Per ardua ad astra!
    Spring, TX
    2016 White Tundra TSS
    Your picture shows the Silver-Lux bulbs but the link goes to what Putco calls their Nite-Lux bulb. Are they both a direct plug in for a 2016 Tundra and what is the difference between the two?
  16. Feb 21, 2017 at 8:34 AM
    sdhq_offroad
    GILBERT, AZ
    Nite-Lux was the older model. Silver-Lux is the newer version. We have been working on getting it switched over on the website. But the Silver-Lux is what you will receive.
  17. Feb 21, 2017 at 7:33 PM
    rockjockey
    Spring, TX
    Thanks, that clears it up! I'll be ordering a set in the next day or two!
  18. Feb 22, 2017 at 6:40 AM
    sdhq_offroad
    GILBERT, AZ
    PM me and I'll get you all set up.
  19. Feb 22, 2017 at 6:55 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Damn! Nice inventory and selection you guys have there!!
    sdhq_offroad[OP] likes this.
  20. Feb 22, 2017 at 9:09 PM
    rockjockey
    Spring, TX
    Just PM'd you for ordering details. Looking forward to installing the Silver-Lux bulbs in my Tundra. Will post before and after pics for all to see. By the way, your pics of the store make me wish I lived in Gilbert!
  21. Feb 22, 2017 at 9:58 PM
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    Pm'ed for led lights
  22. Feb 23, 2017 at 7:28 AM
    sdhq_offroad
    GILBERT, AZ
    PM'd
  23. Feb 23, 2017 at 7:29 AM
    sdhq_offroad
    GILBERT, AZ
    Anytime you are around, please stop by! This goes for anybody! We will give you the complete shop tour. Our showroom only account for probably a quarter of the products that we carry!
    SlickRick2013Tundra likes this.
  24. Feb 23, 2017 at 9:40 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    looking into LED head lights, any help in this category? I don't like the blue or hints of blue but want a WHITE WHITE and bright look. I think they say it's 5000K.
  25. Feb 23, 2017 at 9:57 AM
    sdhq_offroad
    GILBERT, AZ
    The Putco gives you a super bright white output, I would say with the ever so slight blue hint. I haven't seen a bulb comparable yet.
  26. Feb 23, 2017 at 10:02 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    Well I'm not yet convinced on retros for 1000 but I definitely want more output then my oem's. You tell me the brightest white I can get and i'll give you some awesome money!!!!
  27. Feb 23, 2017 at 10:34 AM
    sdhq_offroad
    GILBERT, AZ
    That I know of, yes they are.
  28. Feb 24, 2017 at 8:02 AM
    rockjockey
    Spring, TX
    Just ordered the Silver-Lux bulbs from Joey @ SDHQ by phone. Quick and easy. Joey was most helpful.
    Will post pics and comments next week sometime.
  29. Feb 24, 2017 at 9:10 AM
    sdhq_offroad
    GILBERT, AZ
    Don't forget to take some before and afters for the guys here!
  30. Feb 24, 2017 at 11:31 AM
    rockjockey
    Spring, TX
    Will do - taking before pics tonight. When LEDs are installed will take after pics from same distances/angles for direct comparison. Will post all at same time.
