The 4 month $27k 2007 RCSB TRD Pro build (Full 2014+ conversion, Front Clip, Interior, Bed)
Discussion in '2nd Gen Builds (2007-2013)' started by Jeff_5_7, Jun 7, 2021.
  1. Jun 8, 2021 at 9:17 AM
    #61
    2undra
    2undra New Member
    Reg cab short bed 4.7
    Stock
    Damn man! Can you do that to my white RCSB ?
    I’m sure it wouldn’t cost tooooooo much
    Jeff_5_7[OP] likes this.
  2. Jun 8, 2021 at 9:19 AM
    #62
    2undra
    2undra New Member
    Stock
    Ps- Just put a cargo net tailgate on her and call it good..... with a parachute pouch to slow ya down!
  3. Jun 8, 2021 at 9:34 AM
    #63
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Looks very very very good, you did a great job!
  4. Jun 8, 2021 at 9:37 AM
    #64
    Jeff_5_7
    Jeff_5_7 [OP] New Member
    Jeff
    Houston Tx Area
    Sure, with enough money nothing is impossible. As you read I paid $9,000 for my truck stock and I now have over twice that ($18K) in parts alone.
    I seriously could consider doing another one someday. The problem is only younger guys with no family or older retired guys buy single cabs as a primary truck. Its is really a small market share and a big reason Toyota quit producing these.
    This kind of stuff is for people with a little extra spending cash that want a fun weekend truck or something. If I made another one I would have to get $30k plus for it when I sold and just not a lot of people willing to spend that kind of money on an extra truck in my opinion.
    Due to limited production of single cab short bed trucks it is also not easy to find a great starting platform. Cutting a 2014+ long bed down to a short bed could be much easier. The new interior and front end is already done by Toyota. I would want to add the center console/shifter however.
    15whtrd likes this.
  5. Jun 8, 2021 at 9:50 AM
    #65
    2undra
    2undra New Member
    Stock
    O7 -80k miles/ super clean undercarriage. 4.7 tho
    KTM753 and Jeff_5_7[OP] like this.
  6. Jun 8, 2021 at 9:52 AM
    #66
    2undra
    2undra New Member
    Stock
    I wouldn’t mind a Faux Trd Pro ....4.7 , ha
  7. Jun 8, 2021 at 9:58 AM
    #67
    Jeff_5_7
    Jeff
    Houston Tx Area
    Clean truck... go for it!
  8. Jun 8, 2021 at 9:59 AM
    #68
    2undra
    2undra New Member
    Stock
    I’ll just admire yours- and keep saving for a 2022. Use the RCSB for daily work
  9. Jun 8, 2021 at 9:59 AM
    #69
    2undra
    2undra New Member
    Stock
    Real nice work you have done, That’s a beauty
  10. Jun 8, 2021 at 10:21 AM
    #70
    Wow!!! :101010:
    And I thought it was scary just taking the silver radio surround out and making it black.
    Great job Jeff.:hattip:
    texasrho83, BGoodiE and Jeff_5_7[OP] like this.
  11. Jun 8, 2021 at 10:46 AM
    #71
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    On the Gen 2, the wiring harness for the servos is available separately - I haven’t looked into Gen3 but I’m betting it is the same harness. There is one harness for the non-auto trucks and one for the auto-AC trucks with different part numbers. Each connector has its own PCB built into it for each servo. And you can’t just use the wire harness, it has to be plugged into that extra servo.
    Servo itself on the Gen 2 auto-AC trucks is an auto-blend for defrost and upper vents if i remember correctly. When in auto mode, it redirects some air differently that just the standard defrost, but I can’t remember exactly the difference. The servo itself was located high on the passenger side of the housing. I never even tried to install a blend door inside - just attached the servo to the outside and plugged in the harness. It would move, but wasn’t doing anything.
    you can get to all of it by only removing the lower dash/glove box areas and the stereo. You do need the thermister, Venturi tube, and so that jazz as well. And I’d recommend adding the solar sensor and auto-on headlights while your in there!
    texasrho83 and KTM753 like this.
  12. Jun 8, 2021 at 11:03 AM
    #72
    Jeff_5_7
    Jeff
    Houston Tx Area
    Yea makes perfect sense. The PCB pickup the CAN signals and also send back the position of the servo it is plugged into. If one PCB or servo is missing the AC amp knows and will reset/have an error code.
    I will defiantly be upgrading to the digital panel soon.
    RainMan_PNW[QUOTED] likes this.
  13. Jun 8, 2021 at 11:37 AM
    #73
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Congrats on a great build. More than the actual upgrades, I'm most impressed by your dedication and determination. Your parents must be very proud of you, young man!
    BTW; Black-out Pro LED headlights might look nice too...;)
    300BLK, camron1039 and Jeff_5_7[OP] like this.
  14. Jun 8, 2021 at 11:57 AM
    #74
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    First off why havent I seen this thread lol
    Nice job on a very well planned out conversion. Your neighborhood looks really familiar like one here in San Antonio.
  15. Jun 8, 2021 at 12:04 PM
    #75
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Dope! Makes me want to get a 2014+ 4x4 regular cab, chop it, and put a short bed on.
    831Tun and Jeff_5_7[OP] like this.
  16. Jun 8, 2021 at 12:04 PM
    #76
    Jeff_5_7
    Jeff
    Houston Tx Area
    Thank you for this! I definitely developed a motivated attitude as I was growing up. It helped push me to a very solid education and successful career. This "fun" truck is one of the first big rewards to my adult self.
    I just created the actual build thread yesterday evening after work. I actually stumbled across your profile a few weeks ago on here. Your RCSB is very sharp as well.
    I currently live in a neighborhood in Bryan/College Station. After several years at Texas A&M I never left.
  17. Jun 8, 2021 at 12:12 PM
    #77
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I mean, it got me all worked up.
  18. Jun 8, 2021 at 12:12 PM
    #78
    TX210Tundra
    Let me know if you ever make it down my way, would love to check yours out in person. I go to Austin from time to time myself.
    Thank you btw
    Jeff_5_7[QUOTED][OP] likes this.
  19. Jun 8, 2021 at 12:33 PM
    #79
    ezdog
    ezdog New Member
    Gateway To The West
    Not sure if this is what you were saying but I read that you think the 3rd gen AC controls are single zone only?
    I am sure that the one you bought is that way but there are sure 3rd gen 2 zone AC controls too and maybe that is what you really need to make that work correctly?
    Amazing tenacity here too!
  20. Jun 8, 2021 at 12:35 PM
    #80
    ezdog
    ezdog New Member
    Gateway To The West
    Sorry but you will need to pry mine from my cold dead hands before I would let anyone chop it into near uselessness to me!
  21. Jun 8, 2021 at 1:29 PM
    #81
    Jeff_5_7
    Jeff
    Houston Tx Area
    Oh come on we just need to cut out like 1.5-2 feet from this area in red ...... But seriously, cool truck. Still sad Toyota cut the regular cab completely. Would have loved for it to stay around even if it was only a long bed option.
    Ignore my high quality photoshop skills but this looks cool!
  22. Jun 8, 2021 at 1:53 PM
    #82
    ezdog
    ezdog New Member
    Gateway To The West
    I searched a long time to find a newer RCLB and went on an adventure to collect it too!
    Plus I would need a shorter shell and bedslide and tools too!?
    I imagine I love my Long Bed as much as you guys love your Shorties?!
    Jeff_5_7[QUOTED][OP] and Pbed85 like this.
  23. Jun 8, 2021 at 1:54 PM
    #83
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    So you're done and bored with the truck already..... I guess I could offer you $27k for it :spending:
    Great Job!! I actually priced the TRD Pro 6'5" bedsides and they're $1,500 each, but no telling how long to actually get them from Toyota. P/N's 656000C170 and 655000C170.
  24. Jun 8, 2021 at 2:35 PM
    #84
    Jeff_5_7
    Jeff
    Houston Tx Area
    To each their own right? I once had a guy tell me his dad thought short bed truck were worthless because a standard 8x4 ft sheet of plywood could not lay flat in the bed with the tailgate closed. For this reason alone the guy would only buy long beds. Of course plywood prices are so high it doesn't matter anymore. A regular cab long bed would be a great work truck, as you point out.
    I found the bedsides and the P/N explicitly said they had the "TRD Pro Stamp" When I looked they were like $850 each plus shipping. My good friend in the auto body world said you would probably always be able to tell the bedsides has been replaced if I went this route. I did look into it however before buying my bed.
    Last week, a guy in the Facebook group from Florida told me he was going to buy the bedsides and swap them. I am looking forward to see how this turns out.
    Another guy I know said when he tried to order the bedside the dealer said he had to provide a Pro Vin# to be able to get them. He gave them one but then they said something about they couldn't even be ordered after all. When I ordered the trim piece on the dash above the console I used the TRD Pro Vin# from the truck I got my seats out of. Nobody questioned me and they sent the parts.
    Long story short others guys are talking about/looking at swapping the bedsides. I have yet to see it happen but it might in the future.
  25. Jun 8, 2021 at 2:58 PM
    #85
    Bikeric
    Bikeric New Member
    Eric
    2007 DC 5.7
    Blown Engine.....
    I had my eye on a black double cab TRD Pro in hopes of doing the swap that you did, but the asking price actually kept climbing every day until it finally sold. My goal was to just swap the body parts as you did and forget about the dash. That just seems too tuff for me, but after seeing your results I can confirm it would be too tuff for me. Your truck looks Fantastic!!
  26. Jun 8, 2021 at 3:07 PM
    #86
    Jeff_5_7
    Jeff
    Houston Tx Area
    I laughed a little reading this. Thanks.
    What part of the country was the TRD Pro for sale in? I assume it was wrecked or something? Do you remember what it sold for or have a picture or it?
    I just ordered more connectors and wires to make more plug and play in line harnesses for the cluster and AC controls. I think a few guys are going to buy them and give it a shot. Its the little stuff like the illumination lights and buttons on the dash that will burn you up.
    EDIT: This is the TRD Pro my bed came off of, It would have been a good one to buy whole but by the time I found it, it had been parted out. The bed as all that was left.
  27. Jun 8, 2021 at 4:00 PM
    #87
    TampaRD Pro
    TampaRD Pro Cunning Linguist
    Stanley
    Southwest Florida
    2020 MGM CM TRD Pro
    Lots.
    Congratulations for all your hard work, that is one tight truck! Anything worth doing is worth doing well. Good job!
  28. Jun 8, 2021 at 8:03 PM
    #88
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    This is probably the best thing I have ever read. Awesome job!
  29. Jun 9, 2021 at 3:06 AM
    #89
    Mixb7
    Mixb7 New Member
    Napa Valley California
    2010 4x4 Tundra Platinum Crew Cab
    Bilsteins all around,110v and 12v in the bed, Rocklights, Dual Batteries, Trailer Brake Controller Mod, Lots of DIY Mods
    Genius young man,genius! Here’s a suggestion for your personal license plate, It comes from the old Johnny Cash song “I got it one piece at a time and it didn’t cost me a dime”, 1PCATIM. Although that last part of the song you can keep trying to convince yourself.
  30. Jun 9, 2021 at 3:36 AM
    #90
    War Machine
    War Machine SSEM # 5 3MW
    Very cool. That’s a lot of dedication and hard work!
