The 2-1/4 Gen Rock Warrior
Discussion in '2nd Gen Builds (2007-2013)' started by 68vert, Nov 25, 2019.
  1. Dec 1, 2020 at 4:25 PM
    68vert
    68vert [OP] New Member
    AZ
    2011 Rock Warrior
    Welp. The long travel insanity teardown has begun. Just got the green light from the local diff shop that my other front diff with 4:88's is good to go. Only the steering rack bushings to replace before reassembly. Anyone want some OE parts...?
    Peeeheeuuu likes this.
  2. Dec 3, 2020 at 2:17 PM
    68vert
    AZ
    2011 Rock Warrior
    Just got my front diff back with 4:88's cleaned up and new seals. Also Fab shop welded on the spindle gussets and was able to press off the lower spindle brackets from the ball joints.
    Who would've thunk most of a Tundra front end would fit in the trunk of a BMW coupe. Not me, not till today.
    Mater and Leo's first like this.
  3. Dec 13, 2020 at 5:17 PM
    68vert
    AZ
    2011 Rock Warrior
    Finally got them rack bushings done today. Get this guy back in and onto welding in the cam tabs.
  4. Dec 29, 2020 at 5:41 PM
    68vert
    AZ
    2011 Rock Warrior
    Strapped! And almost ready to roll......
  5. Dec 29, 2020 at 6:18 PM
    tdn
    tdn New Member
    Michigan
    2021 CM 4x4
    Sweet! Excited to see it all mounted up!
    68vert[OP] likes this.
  6. Jan 10, 2021 at 5:41 PM
    68vert
    AZ
    2011 Rock Warrior
    Ran into a hurdle, one of the CV axles rebuilt with the extended shafts most likely has a bearing problem. Seizes up when the Axle shaft nut is tightened. This is my conclusion after swapping in 3 different bearing and swapping the shafts side to side.
    Phoenix Rack and Axle is the only place in the state that rebuilds CV axles and they dont perform service on the weekends :( Gonna try to make the drive to Phoenix this coming week. Hopefully they can get it resolved quickly.
    In the meantime, I made brackets to mount the King remote resi's. Painted em silver to match the resi's o_O Inserted clinch nuts into factory frame holes to mount the brackets.
    Black@Blue19 likes this.
  7. Feb 12, 2021 at 3:52 PM
    68vert
    AZ
    2011 Rock Warrior
    After several bouts and weeks dealing with CV axles, I'm leaving some info here for others in hopes this save somebody headaches down the road.
    I received 3 sets of wheel seals from Rockauto. The set I originally used has a thicker flange. That thicker flange was causing the drivers side axle to bind as soon as the axle nut was tightened down ever so slightly. This only happened with that one axle. Everything operates like it should after replacing with wheel seals that have the thinner flange. Should've saved the factory ones I took out to compare instead of just trusting whatever Rockauto sent me.
    When the CV axles were rebuilt, there was some grease under the boots. Plus the band clamps were not fully tightened down. Made a freaking mess first time I drove the truck. Ended up buying band clamps, crimping tool, and grease from Amazon to fix myself. Used some 3M VHB double sided adhesive on the outboard side of the boots to make sure they seal and prevent them from slipping off. Working good so far.
    WFD473 and Peeeheeuuu like this.
  8. Feb 12, 2021 at 3:57 PM
    68vert
    AZ
    2011 Rock Warrior
    Now that the truck is back in action. Onto better things. Just received rear SS brake lines to match the fronts. Rears are 3" longer. Also ordered the lines that run into the calipers.
    Put on the RCI skids I got for Christmas. Really impressed with the quality. Install wasnt that bad once I had plan to solo install. Thinking I might get some RCI sliders to match...
  9. Mar 16, 2021 at 7:58 PM
    68vert
    AZ
    2011 Rock Warrior
  10. Jun 17, 2021 at 5:53 PM
    68vert
    AZ
    2011 Rock Warrior
    Got my sliders in from RCI. Did a heavy Raptor liner texture on em. Really impressed by RCI's quality. These thing are STOUT!
    After a lot of back and fourth regarding size and tires. Finally got some bigger meats!
    Peeeheeuuu and TheBeast like this.
  11. Aug 7, 2021 at 5:22 PM
    68vert
    AZ
    2011 Rock Warrior
    Just got my truck back from Zona Motorsports. They made some custom shock mounts to go along with my Deavers. Cycled the suspension to ensure there will be no binding. 15" of travel with spring over. Rides great and soaks up bumps like a champ. Oh - and they got me new Kings for the rear in a couple days even though King is quoting 44 weeks.
    Chrslefty, TG705, 68 RS/SS and 7 others like this.
  12. Aug 7, 2021 at 10:00 PM
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    do you know what degree of shock angle you got from Zona regarding your new rear setup?
  13. Aug 8, 2021 at 5:59 AM
    RepeatPete
    RepeatPete New Member
    Pete
    2008 Tundra SR5
    And what length Kings? 12”?
  14. Aug 8, 2021 at 4:02 PM
    68vert
    AZ
    2011 Rock Warrior
    I do not know the angle. If you're interested, I'd contact the owner Bobby and talk to him. For anyone interested, it should be far less than I paid because all the R&D is done. The top mount is bolt in and they said they will offer it as a kit.
    I chose Zona for several reasons:
    • Came highly recommended by local guys that all play hard in the dirt and sand
    • Zona has experience and a reputation. They had LT kits for Chevy's for quite awhile now, and are well known in the Chevy crowd. When I stopped by, they just proto-typed their first LT kit for Ram's, and are interested in releasing a kit for Tundras
    • I got really good vibes from talking to the owner (Bobby), and a team member (Josiah). Josiah has the sic-est 1st gen I've seen with LT, CF bedsides, and some really nice SCS wheels in a rare color I've never seen before
    Yes, I believe its a 12" spec'd by Zona. They are a ADS distributor but I went with Kings to match my coilovers. I doubt they are a King distributor, but just had a connection, and called in a favor to get the project rolling. I appreciated him not pushing me to get ADS tho. Good guys there. I'll go back for sure.
    RepeatPete[QUOTED] likes this.
  15. Aug 8, 2021 at 9:24 PM
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    If your the prototype for their kit, I’d be interested in that TC Kit u got:rolleyes:
  16. Aug 15, 2021 at 6:44 PM
    68vert
    AZ
    2011 Rock Warrior
    Was experiencing some extended crank issues, and fuel smell after turning the truck off. Found a defective filler solenoid.
    Since the fuel tank had to be removed to replace the solenoid, I decided to do a DeatschWerks high volume pump upgrade.
    What a difference it made to power and overall driveability.
    Blang805 likes this.
  17. Jan 2, 2022 at 5:20 PM
    68vert
    AZ
    2011 Rock Warrior
    We had a little Christmas eve adventure. Woke up Christmas day and found at least 1" of mud caked all over. Really glad I made the fenderliners.
    Changed the waterpump and serpentine belt kit. Having everyone tell me my belts squeak when I first start up the truck was more annoying than the squeak itself. FWIW, the OEM waterpump is an AISIN
  18. Jan 3, 2022 at 12:47 PM
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    Love everything about this truck!
  19. Jan 3, 2022 at 12:57 PM
    #49
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Nice work!! Heck of a job!:) Very nice!!!:). Good On Ya….:)
  20. Jan 3, 2022 at 1:16 PM
    #50
    toyofan87
    toyofan87 Beer thirty
    Seth
    Gettysburg, Penna
    Rocking the Rock.. Killer build, Well done sir...
  21. Jan 3, 2022 at 4:11 PM
    #51
    68vert
    AZ
    2011 Rock Warrior
    Thank you kindly for the compliments. I have learned A LOT during this build. Hopefully some of my lesson learned the hard way will help someone else.
    @68 RS/SS, by the sound of your user name, I think we have more hobbies in common than Tundras. I recently sold my 68 Camaro convertible. My brother just sold his 70 split bumper to these guys who are auctioning it.
    68 RS/SS[QUOTED] likes this.
  22. Jan 4, 2022 at 11:14 AM
    #52
    68 RS/SS
    68 RS/SS New Member
    MIke
    New Hampshire
    2020 TRD Sport DC
    pro touring is the route I would have taken if money was no object, car looks killer. Mine is just a street/strip ls swapped roach that I bought right out of college in 2008. I’m not ever selling it but I would love to grab a 6 speed challenger hellcat to park next to it.
  23. Jan 28, 2022 at 10:57 AM
    #53
    68vert
    AZ
    2011 Rock Warrior
    Interior makeover almost complete......
  24. Jan 28, 2022 at 6:24 PM
    #54
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    is that a 07-13 steering wheel? where can i get one?
    Retroboy1989 likes this.
  25. Jan 29, 2022 at 7:37 AM
    #55
    Retroboy1989
    Northern Utah
    2012 SR5 TRD OR (prev) 2025 SR5 TRD Rally (now)
    More info needed!!!
  26. Feb 3, 2022 at 6:14 PM
    #56
    68vert
    AZ
    2011 Rock Warrior
    Interior makeover complete. The front camera is great offroad & in tight parking lots. Which feels like almost all parking lots with this truck. Ha Ha.
    The integrated brake controller and the stereo (including the subwoofer box) looks OEM. More pics to come soon...
    For those interested in the steering wheel, look at Loncky.
  27. Feb 4, 2022 at 3:33 PM
    #57
    SpeshulED
    SpeshulED New Member
    Sandy Eggo/Chula Vista, So Cal.
    2015 Mag Gry Ltd. CM TRD Tundra
    TRD Pro Grill | AMP Steps | Husky Floor Mats | SnugTop Sportsman Super Sport Shell | 55w 5k HID Headligts | Method Racing NV Bronze 18x9 | BFG KO2 35x12.5r18
    nice build so far. Im going to look into that rear relocation shock mount from Zona.
  28. Apr 28, 2022 at 9:17 PM
    #58
    Hotwire
    Hotwire New Member
    Montana
    2008 Tundra SR5 double cab
    Awesome work! Looks like it came that way.
    68vert[OP] and WFD473 like this.
  29. May 6, 2022 at 9:57 AM
    #59
    68vert
    AZ
    2011 Rock Warrior
    Thank you! Appreciate the compliments.
    Just finished making a bedrack to mont my Hi-Lift & tire outta the way which still leaves me quite a bit of bed space for hauling stuff. No way the 37" spare was gonna fit under the bed.
    WVI likes this.
  30. May 6, 2022 at 9:59 AM
    #60
    68vert
    AZ
    2011 Rock Warrior
    Close ups....
    WVI likes this.
