TG705’s 2011 Double Cab build
Discussion in '2nd Gen Builds (2007-2013)' started by TG705, Dec 31, 2019.
  1. May 19, 2023 at 3:31 PM
    #211
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    2011 super white Tundra double cab
    King 2.5 coilovers, King 3.0 rear bypasses, Camburg uniball UCAs, RCI skid plates, Camburg front bumper, warn zeon 10s platinum winch, monster hook reaper shackles, Rigid Industries lights, SDHQ sliders, SDHQ A-pillar brackets, SPOD, 17" Method standard wheels, 315/70/17 Cooper STT tires, Morimoto XB LED headlights, Boon dock steel rear bumper, Durobumps front bumpstops, Deaver U748 with MCM shackles
    Your truck would be sweet with that set up! Put your order in now so you can get them some time next year:rofl:
    Cruzer[QUOTED] likes this.
  2. May 19, 2023 at 6:17 PM
    #212
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I want longer shocks but don’t know how much longer without something to reference it to.
    TG705[QUOTED][OP] likes this.
  3. May 19, 2023 at 7:22 PM
    #213
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Could take some measurements and get some custom shocks built too
  4. May 20, 2023 at 7:37 PM
    #214
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Swapped out my RCV axles back to OEM today. Man what a pain, been holding that off for over a year lol. The RCVs are only 3 years old but look like they’re 50 years old. Can’t believe how thrashed they look. Oh well, off to RCV they go for a freshen up. Also did the ECGS bushing annd new axle seals and what a nightmare that was! Had to grind the pulling tool over and over to finally get behind the needle bearing then putting the bushing in took probably 20 minutes of straight pounding! Sure hope that thing lasts the life of this truck because I doubt that thing is coming out. Once all that was in it was smooth sailing.
  5. Jun 12, 2023 at 5:28 PM
    #215
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Picked the truck up today after getting the Camburg relocation kit installed, put all new bushings, isolators, u-bolts, and center pins in the leaf pack so the rear end should be good for a while. Finally closed the body mount since I cut it and just left it open 5 years ago haha. Also had all the shocks topped off with nitrogen.
  6. Jun 12, 2023 at 5:31 PM
    #216
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    oh you fancy now?!?
  7. Jun 12, 2023 at 5:32 PM
    #217
    Cruzer
    Cruz
    Sunnyvale, CA
    So how does the rear ride now?
  8. Jun 12, 2023 at 5:33 PM
    #218
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Haha just trying to keep up with you guys!
    BiggHertz[QUOTED] likes this.
  9. Jun 12, 2023 at 5:36 PM
    #219
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    About that same, maybe a little softer. Definitely a whole lot louder with these bypasses compared to the OEM bypasses I had. I’ll have to mess around with some tubes next time I take it out.
  10. Jun 12, 2023 at 5:46 PM
    #220
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    not a whole lot of shock shaft showing at ride height. Makes me nervous they have indexed the lower shock mounts too far forward and you're gonna bottom out the shock before getting into your bumps...bad things happen to that bolt-on upper shock mount...
    TG705[OP] and FrenchToasty like this.
  11. Jun 12, 2023 at 8:37 PM
    #221
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    That was the first thing I said when I picked it up, he said he did a bunch of cycling with the axle level and Flexed and that there was 3/8” shaft showing at full bump. Fingers crossed:fingerscrossed:
  12. Jun 13, 2023 at 9:47 AM
    #222
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    FULL SEND!
    nb_nielsen and TG705[QUOTED][OP] like this.
  13. Jun 13, 2023 at 11:34 AM
    #223
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Absolutely! Keep an eye out for the broken upper mounts and destroyed shocks post:rofl:
  14. Jun 16, 2023 at 12:46 AM
    #224
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    Only question is if the leafs were flat when it hit bump or they were bumping it with positive arch. it looks close, maybe the took that into consideration
  15. Sep 18, 2024 at 8:19 PM
    #225
    liltrok
    liltrok New Member
    Anaheim, CA
    2nd Gen DC RW
    What is your wheel offset?
  16. Sep 19, 2024 at 10:01 AM
    #226
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    0 offset 4.5” backspacing
  17. Dec 10, 2024 at 11:04 PM
    #227
    Black Beauty 5.7
    Black Beauty 5.7 New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    How has the "new" rear treated you so far?
    I'll be replacing my oem springs with the U748s eventually but struggle to find information regarding the camburg relocation kit w/ 3.0 double bypasses and if it's much better than just keeping the original shock mounting locations with 3.0 king oem triple bypasses :monocle:
    Since you've had both I figured you'd be the best to ask lol.
    Also, have you considered stiffening the frame under the bed? I can't stand the horrible bed bounce I have to endure daily in my DC :annoyed:
  18. Dec 12, 2024 at 1:30 AM
    #228
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    I installed the 748s back when I had 2.5” remote resi shocks. Then I bought the 3.0 kings thinking they would have a longer stroke and more travel, but when I installed them I had to jack the axle up quite a bit to get the lower shock bolt in, so the shock was really limiting travel. I wanted to maximize the mid travel set up so I got the relocation kit. I haven’t even really taken the truck out at all since I had it installed, but on the road it rides about the same as it did with the 3.0 OEM kings. I would eventually like to box the rear but not anytime soon
    BiggHertz and eccracer104 like this.
  19. Dec 12, 2024 at 6:03 PM
    #229
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Awesome thread man! Great build and great adventures!
    TG705[OP] likes this.
  20. Dec 12, 2024 at 6:58 PM
    #230
    Black Beauty 5.7
    Cannon
    So do you think it's worth biting the bullet before hand and doing the whole shebang with relocating shocks in the rear?
    To start off my rear end build I'll be doing the leaf pack first and driving around on it for a while until I can afford everything else. Hoping to order the pack after the new year begins :)
  21. Dec 12, 2024 at 9:51 PM
    #231
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Thanks dude! Hoping to continue the adventures once my kids get a little older lol
  22. Dec 12, 2024 at 10:08 PM
    #232
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    If you're set on getting the relocation kit I'd say just buy it instead of going with the OEM replacements. Not sure where things are at now but when I ordered that kit from Camburg, it took 1 year and 5 months to get since the shocks were back ordered. Are you considering other shock brands? ADS has a Deaver spec 2.5" triple bypass that fits in the stock shock location and works really well with the Deaver packs.
    eccracer104 likes this.
  23. Dec 12, 2024 at 10:13 PM
    #233
    eccracer104
    eccracer104 Dirty Paws Off-Road
    San Diego, CA
    2011 Tundra 5.7 4x4 CM
    Any chance you measured the bypasses for the shock relocation? I'm guessing they're 12" but would be curious what the specific kit 3.0 bypass measure to. Going to alternative would still need the tubes clocked correctly.
    Awesome truck by the way! :cheers:
  24. Dec 12, 2024 at 10:38 PM
    #234
    Black Beauty 5.7
    Cannon
    I have considered the ADS stuff, but it'd drive me crazy having two different shock brands on my truck lol
    Haven't really called in anywhere to see how long orders might take since I'm not really in a hurry yet but it'd probably be a good idea to check it out now.
    Where'd you order your stuff from? I was thinking maybe SDHQ? I live in Nebraska so there is absolutely no local shops that support this sort of thing unfortunately
  25. Dec 13, 2024 at 7:12 AM
    #235
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Hahaha I feel you on that, that’s why I stuck with king and didn’t do that route:rofl:
    I ordered the kit and shocks through Camburgs website. Should have better luck that I did because I ordered it when everything had a shortage
  26. Dec 13, 2024 at 7:23 AM
    #236
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Thanks buddy! Right back at you!
    I don’t know the eye to eye length, but it’s a 12” stroke shock. I remember seeing on someone’s build thread here that he used a standard off the shelf King 2.5 x 12” triple bypass with this kit and it worked, I think a 3.0 would rub with the standard tube layout tho
    eccracer104[QUOTED] likes this.
  27. Dec 13, 2024 at 7:42 AM
    #237
    Deaner
    Deaner New Member
    Dean
    The Mac
    2010 Rock Warrior
    Same here. Can't go out as much right now until my little one gets a little older. Lol
  28. Dec 13, 2024 at 8:09 AM
    #238
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Yeah, imho don't bother upgraded leaf packs without an appropriate shock package. be it relocation kit, RXT shocks or @AccuTune Offroad 's rear frankenshock they developed for the short length OEM units. the down travel limit of OE length shocks is real...
    my 3.0x12 vs OE length 2.5's
  29. Dec 13, 2024 at 8:17 AM
    #239
    mart1nezdaniel
    mart1nezdaniel AZ
    Arizona
    Tundra TRD PRO 2017
  30. Dec 13, 2024 at 9:20 AM
    #240
    TG705
    TG705 [OP] Braaaap
    Tony
    San Jose, CA
    Well said! When I bought the OE 3.0s it said on the website that they must be used with an aftermarket leaf pack so I thought they’d offer more but nope!
