Tell me what you think
Discussion in 'Suspension' started by upchurch_k, Aug 8, 2019.
  1. Aug 8, 2019 at 7:06 AM
    upchurch_k
    upchurch_k [OP] New Member
    Just bought my first Tundra, here's what I'm looking to get done suspension wise pretty shortly. Let me know what you think, is it overkill? Think I'll be happy?
    Truck Info:
    2019 1794 4X4
    Driving Info:
    Mostly pavement driving, during hunting season there will be some light offroading with a descent load in the bed. I also haul a 24ft bumper pull ultralite travel trailer probably 4 times a year.
    What I'm trying to accomplish:
    I want to bring the front up so I can put 275/65R20 Cooper ATP on the stock rims, keep close to the factory rake, smoother ride on and off road, and have an enjoyable drive with the travel trailer.
    Suspension Upgrades:
    • Bilstein 6112 set at 1.9"
    • Bilstein 5160
    • Boss 4X4 Adjustable 1' - 1.5' Shackles in the rear
    • Airlift Load Lifter 5000 Airbags
  2. Aug 15, 2019 at 12:37 PM
    MAGDADDY
    MAGDADDY TTC #280
    JON
    Houston TX
    18 Platinum CM MGM
    Leer 100XL, Bedrug, Go Rhino running boards, LED int/ext lighting, Bilstein 6112/5100 1/2”shims up front, Coachbuilder +3 shackles, CB drop, TRD front/rear sway bar, 275/65/20 Michelin LTX M/S 2, sequoia painted mirror cap/door handles, Rago Fab low pro ditch brackets, Baja Designs S2 sports ditch lights. Baja Designs S2 sport rear flush mount pod
    F4154C77-C25B-4371-83A0-DA05C3E11301.jpg I’m running the 6112’s on the top setting with 1/2” shims. Did coachbuilder +3 shackles in rear with 5100 shocks. Also running the same size tire 275/65/20 Michelin LTX. Only thing I had to trim was the skid plate, also installed 1” spacer on front bumper to give me more tire clearance. It’s a great ride on and off road! Good luck with your build!
    Jerry311SD and Blueknights75 like this.
  3. Aug 15, 2019 at 2:00 PM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Women way out of my league should be paid by the gov't to treat me like Brad Pitt.
    Jerry311SD, Watt maker and 15whtrd like this.
  4. Aug 15, 2019 at 2:33 PM
    Kerch71
    Kerch71 Surgical Precision
    Mechanicsville VA
    Right on. Good choices. Definitely show it off when you're done.
  5. Aug 26, 2019 at 6:27 AM
    Mike19
    Mike19 New Member
    Chi town
    2019 SR5 CM 4X4 TRD Sport
    TRD Exhaust, Bilsteins 6112/5100, CB Shims 2/1, CB +3 Shackles, Air Ride, RCI Engine and Trans Skid Plates, Cooper AT3 XLT 275/65/20
    Got a similar setup but looking to keep the factory rake. You'll be happy with the ride!
    I was thinking of going with a 275/65R20 tires but still researching which one to go with for the Chicago winters.
    Here's what I did for suspension upgrade:
    • CB 1/4" shim on driver side
    • Bilstein 5100
    • CB +3 Shackle
    • Firestone Air Bags
    Watt maker likes this.
