Tell me I didn't make a mistake
Discussion in 'General Tundra Discussion' started by Shaw725, Nov 13, 2019.
  1. Nov 13, 2019 at 6:29 PM
    Shaw725
    Shaw725 [OP] New Member
    2016 SR5 TRD
    Stock
    Ok guys I have read a ton of reviews and watched a ton of videos about reliability of the Tundra. This helped me make my decision. I drove 6 hours to buy a the Certified 2016 CM SR5. It currently has 33,000 miles. I've put 5,000 on myself.
    In the 6 months that I've owned it, the front rotors have warped. The second door actuator has went out. Now its in the shop for a cold start problem where it idles extremely rough and rich for about 15 seconds during this cold weather that we are experiencing.
    I have plans for a leveling kit, camper shell, maybe wheels but I'm starting to wonder if this thing is going to nickel and dime me to death. I'm looking for a 200,000 mile truck. Not sure its going to make it at this point. Any thoughts?
    Rica25 likes this.
  2. Nov 13, 2019 at 6:34 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    It will going to nickel and dime you to death, but only on mods :thumbsup:. Good luck
  3. Nov 13, 2019 at 6:38 PM
    The OEM rotors aren't the greatest. My non certified 07 had warped rotors when I bought it...replaced rotors and pads myself, other than that I did replace power steering pressure sensor at 12 years/98,000 miles. $20. Ran perfectly. Sorry to hear about your issues but your Tunny was certified. Make them correct your issues. Can't get nickel and dimed if the repair work is free, assuming you are still under extended warranty.
  4. Nov 13, 2019 at 6:40 PM
    Pics of Tundra???
    Pinay likes this.
  5. Nov 13, 2019 at 6:40 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    :itllbuffout:
    But really though, sounds like maybe it was rode a little hard by the previous owner. Do a once-over on some of these things and I bet you'll be fine.
  6. Nov 13, 2019 at 6:42 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    You’re still new enough you may be able to buy a genuine extended warranty from a dealer
    Black Wolf likes this.
  7. Nov 13, 2019 at 6:42 PM
    roy2015
    roy2015 Waterproof
    Houston
    Super White = Super Fast
    All vehicles have minor problems and maintenance, which are what these sound like. Only time will tell if this truck has more problems than normal. But historically Toyota has few serious problems. I doubt you made a mistake.
    I’ve owned 6 Toyotas now, sure to have put 100s of thousands of miles combined. I can list the big ticket repairs I’ve had on all of them: clutch, cracked exhaust manifold, coilpacks on fwd v6.
  8. Nov 13, 2019 at 6:43 PM
    Shaw725
    2016 SR5 TRD
    Stock
    I certainly hope not. I hope the nickels and dimes are on mod's as well. It's disheartening when you think you are going to have miles and miles carefree only to have issues so soon on a certified truck. I look forward to many great years ahead with this truck!
    Pinay and Black Wolf like this.
  9. Nov 13, 2019 at 6:46 PM
    Your issues aren't too bad. Sucks though. Make the dealer fix them. Let us know how it works out.:thumbsup:
    Pinay and Shaw725[QUOTED][OP] like this.
  10. Nov 13, 2019 at 6:46 PM
    Shaw725
    2016 SR5 TRD
    Stock
    I don't know. I was hoping I wouldn't need it based on the reputation.
  11. Nov 13, 2019 at 6:47 PM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Sounds like the previous owner was my wife
  12. Nov 13, 2019 at 6:50 PM
    I've always got the extended warranty and never had to use them even once, but I believe in Murphy's Law. If I didn't get the extended warranty I'd no doubt wish I had it. :goingcrazy:
    jtwags likes this.
  13. Nov 13, 2019 at 6:54 PM
    Do used Certified Tundras come with some sort of warranty??? I've never bought a certified truck. Curiosity....
  14. Nov 13, 2019 at 6:55 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Probably wont
  15. Nov 13, 2019 at 6:56 PM
    7.62Tundra
    SA Texis
    2015 5.7 Crewcab
    Yes they do. Take it back and make them fix it. You get 12K warranty and 100K drivetrain
  16. Nov 13, 2019 at 6:56 PM
    Shaw725
    2016 SR5 TRD
    Stock
    rebmo, Skey44, kenomouth64 and 11 others like this.
  17. Nov 13, 2019 at 6:57 PM
    Thanks for that...I thought so. OP should have no more issues if the dealer gets things corrected....
  18. Nov 13, 2019 at 6:58 PM
    Super clean! You have a nice truck. Just make sure your dealer treats you right. We got you!
  19. Nov 13, 2019 at 7:03 PM
    Once your dealer gets you squared away......you mentioned a getting camper shell, look into getting a wall to wall BedRug too. You won't regret it. https://bedrug.com/
    Shaw725[OP] likes this.
  20. Nov 13, 2019 at 7:23 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    I've posted this before, but your rotors probably didn't warp. It really takes a lot to truly warp a rotor. Most likely had brake pad imprints left after a hard stop. I too thought that I had "warped" my rotors on my Tundra early on after a hard stop. But, then I did a little more research and tried re-bedding the brakes. Worked like a charm. No more pulsating under braking. I changed the OEM pads and rotors at about 65,000 miles (the rotors were fine, but I always put new rotors on when I change my pads). Probably could have got another 10K out of the pads, but didn't want to push it too much. Anyway, I have attached a video that describes the bed-in procedure that I use and does a pretty good job of describing what happens. YMMV, but ever since I started doing this on my vehicles, I have had no brake problems that is often mis-diagnosed as "warped rotors" (shops will often tell you that the rotors are warped - because they want your money).
    Video is long, but worth it.
    https://www.youtube.com/watch?v=pdPX6rzuINc
  21. Nov 13, 2019 at 7:27 PM
    My rotors were warped. Couldn't get them turned they were so bad. Warpage can happen, but like you posted you need to make sure so you don't waste money on new rotors.
  22. Nov 13, 2019 at 7:30 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    Since you only bought it 6 months ago and its certified you're covered under the 12 month/ 12k miles. And you have until 36k miles to purchase the Platinum Toyota warranty (supposed to cover everything). You can purchase it through ANY toyota dealer but the cheapest is (err....) cant remember the dealer name, but it's in michigan. Ill dig around and edit the post when I find it. I believe the gentleman quoted me $1400 for 7 years and 125k. Not too bad.
    PermaFrostTRD and Black Wolf like this.
  23. Nov 13, 2019 at 7:40 PM
    bdpeelgren
    bdpeelgren New Member
    Round Rock, TX
    2014 Tundra CrewMax Super White
    Readylift 3/1, Rigid D-series fog lights, Supernova V.4, F/R Coverking covers.
    As for the door lock actuators, they’re a common issue on tundras. I’ve had to replace 2.
  24. Nov 13, 2019 at 7:44 PM
    Shaw725
    2016 SR5 TRD
    Stock
    I would be interested in that. Thanks.
  25. Nov 13, 2019 at 7:49 PM
    Shaw725
    2016 SR5 TRD
    Stock
    They are really nice. I loved my last shell. There are a lot of options out there to spend your money on. LOL
  26. Nov 15, 2019 at 9:13 AM
    lewishenry19
    lewishenry19 New Member
    If your worried get a full comp extended warranty
  27. Jan 8, 2020 at 6:03 PM
    Tiamat
    Tiamat New Member
    2015 tundra crewmax xp
    There is a fix for the cold start take to your dealer. Tell them about problem it’s covered.
  28. Jan 8, 2020 at 7:27 PM
    TundraDude18
    TundraDude18 Deus vult
    'Merica
    '21 Limited CM
    Silver Bullet Express
    100,000 miles is nothing on these trucks.
    200,000 miles is nothing too.
    Think bigger, if you want to keep it. My neighbor is driving a 4runner with over 325,000 miles on it with just regular maintenance. Dude at the gas station the other day was driving a 20 year old Tacoma that he said just won't quit running: again, just regular maintenance.
    Truck looks great, btw.
    Keep moving forward!:thumbsup:
  29. Jan 9, 2020 at 2:28 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    I would be interested in this too.
  30. Jan 9, 2020 at 3:50 AM
    PermaFrostTRD
    Northern NY
    Yup. CPO will be covered for your first full year or 12k miles of your ownership. Rotors, if warped, would be part of that. As would the cold start and door actuators.
    Give them a call. Be nice about it. I’d start with “not trying to be a dick here but... I have problems x,y,z. Truck isn’t even out of original warranty and certainly not out of my CPO warranty. Is there a time to set something up where I can have all 3 of these taken care of at the same visit? Thank you. I’m not talking about scratches in the clear coat. These are problems I was hoping to avoid by going with a Toyota. I’d like to get another one when this gets me to 200k”
    You’d be surprised how far that will go.
