Tell me about D.A.P tune.
Discussion in 'Performance and Tuning' started by Mat1018, Mar 11, 2018.
  1. Mar 11, 2018 at 11:30 AM
    Mat1018
    Mat1018 [OP] New Member
    Mat
    2016 Super White platinum CM 4x4
    4" lift, spyder headlights and tail lights, LT headers. Carven exhaust, and XD series monsters II wheels.
    So been reading about dap and bullydog lately but want to know more about dap. Others then people saying it's badass or get one you won't regret. Big thing that I like about dap is the torque management removed. Evething else I don't care for. So what im getting at is it's really worth the price tag or is tow hual the exact same thing.
    JCVD and MDHinSD like this.
  2. Mar 11, 2018 at 11:37 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    I’m a dealer for both products. And have personally tested both products. Here’s how I recommend:
    Get Bullydog for a mostly stock truck with stock cats. Where you aren’t tryin to shut off any codes. You simply want power.
    Get Bullydog if you’re Trd supercharged with an otherwise stock truck.
    Get Bullydog if you’re running long tube headers with cats and you’re not getting a check engine light for catalyst inefficiency.
    Get dap if you’re supercharged with smaller pulley
    Get dap is you’re not running cats and need to turn off check engine light.
    Get dap if turbocharged.
    Please feel free to give me a call for more details. I’ve tested both products and am happy to share knowledge.
    Keith 760-877-4234
    JCVD, savtundraguy, aperezsh and 4 others like this.
  3. Mar 11, 2018 at 11:50 AM
    Mat1018
    Mat
    Thanks Keith, yeah I'm planing in the next week or so adding LT headers. I've got aftermarket exhaust, bigger wheels and tires on a 4inch lift so I'm just looking at getting some power back if not add alittle more. So I'm hoping headers will get me back to stock numbers if anything. So just getting info on both to see what everyone thinks about them. I know tow hual wakes the truck up nice. Not not sure if there's any negative effects using it often. If SC weren't so pricey I would jump on that but dont want to sell a kidney for one haha.
  4. Mar 11, 2018 at 11:55 AM
    15whtrd
    15whtrd Mr. Blonde
    Add gears to the mix. That would be the best bang for your $. 4.88 or 5.29 for some extra pep.
    Sunnier and dirtydeeds like this.
  5. Mar 11, 2018 at 11:58 AM
    Mat1018
    Mat
    Definitely been thinking that also after headers. I'm a big diy guy but gearing I'm not very sure I can do that one
  6. Mar 11, 2018 at 11:59 AM
    15whtrd
    15whtrd Mr. Blonde
    Gearing would get you closest to your stock tire size feeling. All the other things you mentioned would just be a bonus.
    robstruck, Sunnier and dirtydeeds like this.
  7. Mar 11, 2018 at 1:31 PM
    dirtydeeds
    Keith
    USA
    Exactly. Gearing brings you back into your Power band. All the other stuff makes your power band better.
    Having a better powerband but never being in the power band is like being married to a hot blond but only being able to look but not touch. Haha. Exaggerated. But you get the point.
  8. Mar 11, 2018 at 2:05 PM
    Tundra4us
    Tundra4us New Member
    "D"
    Gearing for sure. I have 35" tires and 4.5" lift. I never really had the issue of the tranny "hunting", but I did notice the power loss. Installed 488 W/ LSD, and now truck pulls and has getty up it had with stock wheels.
    Not to hi-jack, but can the Bully Dog tuner be detected by the dealer?
  9. Mar 11, 2018 at 3:53 PM
    Mat1018
    Mat
    So for re gearing what's the common brand people use? Don't want trash but also don't need gold plated diamond encrusted gears, just want a good reliable brand.
    mjgonz1 likes this.
  10. Mar 11, 2018 at 4:37 PM
    Sting Ray
    Sting Ray New Member
    Ray
    Vegas
    2017 SR5 Crewmax
    Not enough space here...
    I have had a bullydog for about 5 months and just got DAP tuned yesterday. I'm keeping the bullydog in the truck for use as a monitoring device. I have jba longtubes, stock cats welded into mid pipes, 8" BAM exhaust, AFE drop in filter.
    The bullydog is cool because you can change things like throttle response, shift points, and customize the display to show different gauges like intake temp, trans temp, pyro temp, coolant temp, MAF, AFR (which never changes), rpm's, speed, etc. you can also change settings on your truck like turning the seat belt chime off, light settings, door lock settings, etc. it also has performance testing where it will record your 0-100 kph, 0-60 times, 1/4 mile times, etc. you can also read and clear codes.
    DAP is cool because it actually makes your truck faster, more powerful, better/faster shifting. In person tune is undetectable by the dealer supposedly while the bullydog and remote DAP is not.
    3 out of 4 people prefer the bullydog, 5 out of 4 prefer DAP.
    If you want a tune that makes your truck fast, take it from me, save your money, don't buy a bullydog. Get a DAP tune. Get one of those Bluetooth obd things and the torq app (other apps do the same thing) if you want to see all of the readings that the bullydog does.
  11. Mar 11, 2018 at 6:47 PM
    Mat1018
    Mat
    Thanks. That's what I'm looking for is people going into detail explaining both rather then just saying Get it or useless info
  12. Mar 11, 2018 at 6:52 PM
    Stulloh
    Stulloh New Member
    Dallas
    18 Tundra TSS
    I have a stock sr5 trss with a 3/1 lift via bilstein 6112/5100’s ...no other mods ...what’s best for me
    Sting Ray likes this.
  13. Mar 11, 2018 at 7:21 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Well DAP doesn't have a tune for the 2018 yet. But when he does, you should get it.
  14. Mar 11, 2018 at 7:24 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    No problem, forgot to mention that soy will get better gas mileage. I averaged 15-15.5 with the bullydog and stock tune. I'm only a 1/4 tank into it so far with DAP, normal
    Mix of highway and city just like I always drive. And I just hit 18.8.....truck cruises at 75 on the highway about 1900-1950 RPM's compared to 2050-2100 RPM's before.
    Drk_Jdi, MDHinSD, O'hAodha and 2 others like this.
  15. Mar 11, 2018 at 7:32 PM
    Mat1018
    Mat
    Damn pretty good mpg. You have anything you don't like about dap? Or complaints
    MDHinSD and Sting Ray[QUOTED] like this.
  16. Mar 11, 2018 at 7:35 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    No complaints but it's only been a day.
  17. Mar 11, 2018 at 7:38 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    It really makes the ass end squat now when you floor it.
  18. Mar 11, 2018 at 7:47 PM
    Mat1018
    Mat
    Does it change anything when your in tow hual also or does it only effect drive on the shifter? How would you compare the tune to tow hual?
  19. Mar 11, 2018 at 8:05 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Haven't tried tow haul since getting tuned but the only thing tow haul does is raise your shift points and increase the throttle sensitivity. It doesn't add power or make your truck faster. It feels faster but only because it makes the throttle super sensitive.
    CMB and MDHinSD like this.
  20. Mar 11, 2018 at 9:16 PM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    Sting Ray, did you DAP yourself, or have it done?
  21. Mar 11, 2018 at 9:33 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    11 more days for me then I'll be DAPped. Pretty pumped! I'm going with the in person tune so the dealer doesn't get wise. Not that I go there that often, I just don't wanna screw with any of that resetting and driving 50 miles before service stuff.
  22. Mar 11, 2018 at 9:43 PM
    Areith762
    Areith762 Go Avs!!!
    39.944182, -104.760113
    2017 Blazing Blue 5.7L CM SR5 4X4
    DAP Tune, Katskin interior leather, ESP rear under seat storage, door sill protector, door edge protector, TRD Pro shift knob, heated seats, all weather Tundra floor mats, driver side a-frame handle, Tundra trucks center console emblem, clear bra protection, Bushwacker fender flares, paint match front bumper caps, paint match rear bumper caps, paint match mirror caps, ProComp 3/1 lift, 20" Fuel wheels, 33-11.50/R20 Falcon tires, black TRD Pro badge's, black Tundra tailgate badge insert, TRD Pro headlights, Recon smoked tail lights, Recon smoked 3rd brake light, Roll N Lock tonneau cover, Line-X bed liner, Tundra bed mat, Cobra led remote alarm/remote start, N-fab tube steps, factory match window tint, TRD Pro grille -paint matched, paint matched hood bulge, TRD dual exhaust, Black out exhaust tips, led interior lights, led plate lights, Spyder smoked fog lights, TRD Cold Air Intake
    Hey, 11 days for me too!
    boostedtrdpro[QUOTED] likes this.
  23. Mar 12, 2018 at 4:49 AM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Shrek tuned it for me while he was here in Vegas on his west coast tour.
  24. Mar 12, 2018 at 7:37 PM
    Tundra4us
    "D"
    I purchased "Nitro" 488 gears, master set for front and rear and "Auburn" pro posi LSD. Purchased from JustDifferentials.
    Troynjade likes this.
  25. Mar 14, 2018 at 4:32 PM
    Abrook
    Abrook New Member
    Savannah
    2016 Supercharged Tundra
    Magnuson Supercarger, bullydog gt, fuel cleaver wheels on 33 Terra grapplers, custom royalty core grill, rigid industries LED's(20,30, d-series), katzkin, bilstein shocks, spyder head & tail lights. spyder 3rd brake light, TRD sway bar, corsa exhaust.
    Anyone know if there is a tune for a SC flex fuel by DAP or anyone else on the east coast? I remember a thread about DAP having one in the works for flex fuel but never heard if it was released.
    The Magnuson kit came with a BD can tune but it’s lacking. The BD GT mine came with, non tuner version, can’t control anything Stingray mentioned in his post. I Wish it could.
  26. Mar 14, 2018 at 5:15 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Talked to shrek about this on Saturday. It's not ready yet. He's tuned a couple ffv's but he said he's not happy with it yet. It's the only thing preventing me from starting to save my allowance for a. SC
  27. Mar 14, 2018 at 6:37 PM
    Abrook
    Abrook New Member
    Savannah
    Ok, thanks. Hopefully Shrek will have it finished soon. Where is DAP located?
    Is he working on a super charged flex fuel tundra or naturally aspirated FLex fuel?
    Is there a piggy back system that will work with flex fuel?
  28. Mar 20, 2018 at 7:24 PM
    I met Shrek today. He’s tuning a couple of trucks at Toytec and more this week.
    aperezsh, NCinCO, JC303 and 1 other person like this.
  29. Mar 20, 2018 at 7:34 PM
    Sting Ray
    Ray
    Vegas
    2017 SR5 Crewmax
    Dallas. SC ffv tune is inwork. NA ffv works great! That's what I have.
  30. Mar 20, 2018 at 7:34 PM
    boostedtrdpro
    Jeremy
    I'll be there Friday if I can get off work and up there before he leaves at 5
    JC303 and T-Rex266 like this.
