Techstream Software (Menu Choice?)
Discussion in 'Performance and Tuning' started by DrasticDelima, Aug 19, 2017.
  1. Jan 26, 2018 at 9:00 PM
    saadi996tt
    saadi996tt New Member
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Limo Tint (all around), Weather Tech Floor Mats, Morimoto XB LED Fog Lights, Nerf Bars, Paragon Bed cover (Paint to match), Bilstein 6112’s (F) & 5100’s (R), Wireless iPhone charger, TRD rear sway bar, swing case, led bed lights, pop-n-lock...
    Thanks Jeremy, you’re the man!
    boostedtrdpro[QUOTED] likes this.
  2. Jan 26, 2018 at 9:00 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
  3. Jan 27, 2018 at 7:29 AM
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    Is there any drivers for os systems (apple)
  4. Jan 27, 2018 at 8:57 AM
    boostedtrdpro
    Jeremy
    That I cannot tell you, just not sure.
  5. Jan 27, 2018 at 3:02 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Too many…scratch that…not done yet.
    Ok...so turns out, I'm needing some help.
    Downloaded everything.
    Put in the key code
    Clicked okay and it brought back up the same pop up.
    Do I need to register it?
  6. Jan 27, 2018 at 3:29 PM
    boostedtrdpro
    Jeremy
    Did you replace the mainmenu.exe file in the system folder?
  7. Jan 27, 2018 at 3:31 PM
    boostedtrdpro
    Jeremy
    Once you put the key in, it should register itself for 4999 days which you will see in the lower left of the TIS screen.
  8. Jan 27, 2018 at 3:42 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    I don't recall doing so. I followed the "instructions" txt. file.
    How do I replace the mainmenu.exe file?
    Just FYI, I don't see anything about the days/registration on Techstream in the corner.
  9. Jan 27, 2018 at 3:47 PM
    boostedtrdpro
    Jeremy
    After you've extracted and ran the install, close the techstream software and go to the folder you've extracted the unzipped files to, and open the folder called program files-then toyota diagnostics-techstream-bin, from here you will see a mainmenu.exe file. You need to copy that file to your clipboard, then you go to the folder in which the application was installed on your PC and look for the same exact file. Once you find the file, you right click in that folder and click paste. Then it will ask what you want to do, click replace file with new file. You are basically swapping the mainmenu.exe file that the installer put on your computer, with the one you copied to your clipboard.
  10. Jan 27, 2018 at 3:51 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    10-4. I just uninstalled Techstream, so I can start the process over again...just to be sure.
    I'll give this a go and hopefully reply back with success.
    Thanks again brotha!
  11. Jan 27, 2018 at 3:56 PM
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
  12. Jan 27, 2018 at 3:57 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    BTW...doing all the install last night while 3 bourbons in......prolly the reason it wasn't working....
  13. Jan 27, 2018 at 4:20 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Gents...We have success!!!
    This....truly....is....the.....best.....group.....of......people!!!
    saadi996tt and NewImprovedRon like this.
  14. Jan 27, 2018 at 4:26 PM
    boostedtrdpro
    Jeremy
    Right on! Now silence that damn seat belt chime! Haha
  15. Jan 27, 2018 at 4:30 PM
    GAknight
    GAknight New Member
    Shade of a Pine, GA
    '14 TSS 4x4
    Already done! First thing on the list!
    I owe you a couple drinks....next time I'm in CO.
  16. Jan 27, 2018 at 4:30 PM
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    Can you silence the driver side seat belt chime on a 07? I done the passenger side.
  17. Jan 27, 2018 at 4:55 PM
    boostedtrdpro
    Jeremy
    I'm sure you can. They are both able to be done in the newer models, but I can't say for sure because I've only owned a gen 3.
  18. Jan 27, 2018 at 4:57 PM
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    I haven't found it to turn it off.
  19. Jan 27, 2018 at 5:07 PM
    #49
    boostedtrdpro
    Jeremy
    After reading a few articles, it appears the 2007 is a mixed bag. Some folks report having been able to turn off both, and some say it's not possible. The ones that say it IS possible, say they did it via techstream and the driver side seat isn't "advertised" as being customizable, but after further digging, they were indeed able to deactivate the driver side chime. If I had an 07 to hookup and play with, I'd be glad to check it out for you.
  20. Jan 27, 2018 at 5:09 PM
    #50
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    ok, i'll keep playing with it.
  21. Jan 27, 2018 at 7:32 PM
    #51
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think you may have to dig around. If memory serves, the two seatbelt chime settings aren't in the same place.
  22. Jan 27, 2018 at 7:39 PM
    #52
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    I know its not with the passenger seat. I'll keep looking for it.
  23. Jan 28, 2018 at 7:14 AM
    #53
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    Ok, on the front page it says driver seat, when i click on it, it give me an error code, then it puts a * beside it. when i go to in to check o2 sensor, click on it, i get error code. I upgrade my techstream from 024 to 127 and tried a different cable. still the same thing
  24. Feb 1, 2018 at 10:52 AM
    #54
    Garvin74
    Garvin74 New Member
    2017 Tundra CM SR5
    First I want to say thank you too all that posted on this thread. I was able to install and successfully use TIS. I am not computer savy but yall made it happen. Second, the only setting I changed was the seat belt buzzer for both front seats. Which is great. But this is the only thing I could really see that helped. What are some of the things that you guys do with TIS or that can be done. I know someone changed to one push on the key fob to unlock all doors instead of two which I did but I did it through the radio screen using the settings screen. I have an bluetooth OBD II reader so I assume I don't need TIS for that. Just doesn't seem worth to keep the cable if there is only one function to change. I have a 17 SR5 Crewmax TRD Off Road if that helps. Thanks guys.
  25. Feb 1, 2018 at 12:09 PM
    #55
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    I think you can change the volume and "ding" rate of your key reminder. Some of the things you can change with TS are also available via your radio screen menu, if you have that (as in your case). There's a PDF of all the adjustments that can typically be made with TS. "Changable Tundra Electronics" may be the search term.
  26. Feb 2, 2018 at 5:34 PM
    #56
    saadi996tt
    Saadi
    Bakersfield, CA
    2014 CM LTD
    Success! Got it to work, enabled the oem alarm and turned off the seat belt chime. Thanks to Jeremy (rocky_mtn_trd) for posting a link to the software.
    boostedtrdpro likes this.
  27. Feb 18, 2018 at 1:57 PM
    #57
    camel
    camel New Member
    So saadi996tt what did you do different to install V12.00.127, because I too kept getting that input the key which didn't work. I'm fustrated after trying several times. I know I must be doing something wrong. Thanks
  28. Feb 18, 2018 at 2:02 PM
    #58
    Rsnake69
    Rsnake69 New Member
    Larry
    Randleman, NC
    2007 tundra sr5 trd
    where did you find the key?
  29. Feb 18, 2018 at 2:17 PM
    #59
    camel
    camel New Member
    I copy it from the instruction sheet
  30. Feb 18, 2018 at 2:22 PM
    #60
    boostedtrdpro
    Jeremy
    You likely aren't copying the mainmenu.exe file over. Copy it and paste it into the install folder.
