Techstream - Programming Key Fob (2011) - Version 12.20.024
Discussion in 'General Tundra Discussion' started by FredB32, Jan 18, 2022.
  1. Jan 18, 2022 at 3:49 PM
    FredB32
    FredB32 [OP] New Member
    2011 TRD RW
    I'm not exactly sure which forum this would belong under, hopefully it helps someone. I've searched the internet high and low and it seems like everyone has had issues programming new key fobs with the newer versions of Techstream. I played around with what I have and found what I was looking for buried in the program (Version 12.20.024).
    I'm going off memory, but it wasn't too difficult and I'm sure I could find it again, no need to roll back the version (unless there are other issues I'm not aware of):
    Put in your vehicle model and year (Tundra, duh)
    Once you get to the menu, select Main Body
    Click on the Utility button on the left hand side
    Select the Wireless Registration option in the menu
    Apaprently, Wireless is what they use in Techstream in regards to the keyless entry, so this is where you can program a new key fob. The program has instructions that walks you through the process, and even tells you what you need to do in the screen prior to clicking next.
    Here's what I had to do (Techstream tells you the below step by step):
    -Ensure that the ignition is turned to on (not started) for at least 30 seconds prior to starting this
    -Ensure the driver's door is unlocked and opened (all other doors closed)
    -Click through the screens on Techstream to where it starts a 30-second countdown, and now
    -Click the lock/unlock buttons for 1 second and release
    -Click either lock OR unlock for 1 second
    -Techstream should recognize that you completed this sequence
    Your new key fob is programmed!
    Hopefully this helps someone...everything I found about this version online literally said they removed the functionality, which seemed rather silly, so digging around in the program solved the issue. Next step is when my new key arrives and I can get that cut and programmed, then I'll have a backup to use, so if I ever lose the one I have, I won't be stuck!
    bulldog93 and boostedtrdpro like this.
  2. Jan 18, 2022 at 6:16 PM
    baraynavab
    baraynavab Toyo Junkie
    Atlanta
    Good post.. if you in the Atl area and need key programming.. hit me up.
  3. Jan 18, 2022 at 6:29 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    I am also willing and able to program keys using Techstream if anyone in my area of Colorado needs it. Just hit me up.
  4. Jan 18, 2022 at 7:51 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    What cable do you guys recommend?
  5. Jan 18, 2022 at 8:06 PM
    boostedtrdpro
    Jeremy
  6. Jan 18, 2022 at 10:09 PM
    FredB32
    2011 TRD RW
  7. Jan 19, 2022 at 5:13 AM
    baraynavab
    Atlanta
    @bfunke So the 2 Diagnostic Cable Mini VCI J2534 OBD Scanner cables that are linked above are similar but for the version of firmware (and likely some minor hardware) that runs on them. The 2.0.4 version that @boosterdtrdpro has is the latest version and works with the latest Toyo/Lex Cars. If you plan to do techstream with the latest version and have newer Toyo models I would get that.
    I use the older version of the cable (1.4.0 i think) that I can do most things like program the keys, change customized functions and such. But I do not have a 2010+ Toyota so it works for me. Decide on what you want to do and buy appropriately.
    bfunke likes this.
  8. Jan 19, 2022 at 6:25 AM
    FredB32
    2011 TRD RW
    How/where do you tell which is the "newer" and "older" version of these cables? Are there hardware differences or just the firmware for the cable?
    My RW is a 2011, and as far as I can tell, the cable/software does everything I need it to do. Are you thinking it might not work on newer versions of the software and/or newer vehicles?
  9. Jan 19, 2022 at 6:43 AM
    baraynavab
    Atlanta
    Yes as I mentioned you have to look for the cable firmware version. The old one is 1.4.X the newer ver is 2.0.4. Dont go with the software version.
  10. Jan 19, 2022 at 6:51 AM
    FredB32
    2011 TRD RW
    Ah, found it! For some reason I skipped the actual description on Amazon where it had the technical info. My main concern was if it would be plug-and-play with the computer and Techstream version I already had, and it 100% was.
    Is there a resource somewhere (I know it's not exactly fully legit software we're talking here) that would tell you what the differences in all the software and firmware options would be? I'm guessing with my truck being a 2011, there wouldn't really be much in the way of added functionality in the older cable/TS vs. getting a newer setup for both? Although I could be completely wrong...maybe the mythical "increase mpg" option is buried in the new software somewhere and you can only access it with a newer cable :D
  11. Jan 19, 2022 at 6:54 AM
    baraynavab
    Atlanta
    I think all the 2011 functions can be used via the old and new cables. But if you are getting one then get the new one.. and be done with it. BTW there are drivers to this that you have to get as well.. just search the internet for those. Its sometimes finicky if you dont have the drivers to your correct OS.
    ALSO make sure you run virus scanner on that software..
  12. Jan 19, 2022 at 7:08 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I have an Amazon cable but am running the virtual PC with techstream as found in the ih8mud directions.
    Didnt want to troubleshoot my pc to run the software directly off those mini cds.
  13. Jan 19, 2022 at 11:02 AM
    WXman
    WXman New Member
    Kentucky
    2016 Tundra SR5 Crew Max 4x4 5.7L
    I bought a $25 version of the Techstream software from eBay. But then I started reading lots of horror stories in Amazon reviews on the mini VCI cables about viruses and laptops being ruined and needing an IT degree to get it up and running. So I chickened out. I guess I'm out $25 bucks but that's better than taking a chance on ruining a $900 laptop. Sigh....
  14. Jan 19, 2022 at 11:31 AM
    FredB32
    2011 TRD RW
    Typically I've seen the software come with the cable itself. I've also read all the posts in various places about the software kicking off anti-virus warning, but I think they're mostly false or due to something in the TechStream software itself that the AV software picks up in error as a potential virus. I could be wrong, but I don't recall ever reading about the included software actually having a virus in it...
    FWIW - get yourself an old/cheap laptop and run it...the one I use I bought from a buddy for $80. No need for a nice laptop :D
  15. Jan 19, 2022 at 1:38 PM
    baraynavab
    Atlanta
  16. May 23, 2022 at 11:24 AM
    David1
    David1 New Member
    David
    08 tundra crewmax sr5 non jbl
    Head unit, rickford t1650, Jl audio 4/400, Jl audio 1000/1, 2 sundown sld 12's, big 4 1/0 awg, dynamat, sonic barrier 3 in 1 deadening, tow mirrors, akebono brake pads, raybestos s cut rotors,
    Does anyone in north florida have the ability to program keys or fobs. If yes how much for the service?
  17. May 23, 2022 at 8:01 PM
    baraynavab
    Atlanta
    If you have a laptop...download techstream..then get a cable for like $30-40 bucks and program the key yourself....its not that hard
    bulldog93 likes this.
  18. May 24, 2022 at 8:39 AM
    FredB32
    2011 TRD RW
    I've seen several people have issues. I got a super-cheap $75 laptop from a friend with an older Windows OS and the $40 cable from Amazon and have had great results with it so far. It's much nicer to be able to just go out to the truck and do these things on my own as needed. There's several good options listed above...and older laptops are a dime a dozen nowadays, you don't need anything fancy.
  19. May 24, 2022 at 8:41 PM
    baraynavab
    Atlanta
    If you getting issues it's because the laptops were not setup correctly or something similar. Any laptop should be able run Techstream now. As long as you can follow instructions you can get it working. Most that run now run on virtual machines. Its not hard but just follow the instructions give on the first page to get up and running.
  20. Sep 25, 2024 at 6:25 PM
    pblais
    pblais New Member
    Pierre
    The problem with that idea and that site is I have a real Windows 7 running on an old laptop and not the virtual box version. I downloaded the version of Techsteam he shows there. It requires that virtual box etc be installed on my laptop. I am looking for a version that will open and run on my laptop running native Windows 7, 32 bit
  21. Sep 25, 2024 at 6:46 PM
    baraynavab
    Atlanta
    @pblai
    I'm sorry no clue here buddy.. I am sure the is a way to skin this cat.. doing some rain dance but I am sure it can be done..
  22. Sep 29, 2024 at 7:40 PM
    ToyMan13
    ToyMan13 New Member
    Greg
    2013 Tundra Limited FFV Barcelona Red
    Lift, Wheels, Tires, Head Unit
    I'm running the virtual box from the https://forum.ih8mud.com/threads/how-to-techstream-in-5-minutes.1034923/ thread and hainvg some successes, but can't read data. I get an error that mentions a problem and retry / abort, hit F12. I have a cable that is 1.4.3 firmware. I'm reading and reading and trying to find a way to get it to work, but haven't found the answer yet. I've programmed some keyfobs! I turned the beep off when I use my remote to lock and unlock the doors! Still can't read data. I have a flex fuel Tundra and really want to know what the Alcohol % is auto-tuned at. If anyone has extra things to point me to I'd appreciate it.
  23. Nov 27, 2024 at 10:06 AM
    tanstaafl
    tanstaafl New Member
    FredB32: I signed up to this forum just to thank you. I was stuck trying to use Techstream 12.20.024 to program a new key for my 2012 Lexus ES350. Your instructions helped me to find the way through the maze of menu options to the sub-sub-utility that worked. Thanks a lot!!!
  24. Dec 2, 2024 at 6:57 PM
    Proven
    Proven New Member
    I don't know if this will help, but I had to ensure to extend the data cable to the virtual machine in the virtual machine settings. At first it didn't act like the cable was connected at first.
