TECH12VOLTS TUNDRA REMOTE START GROUP BUY
Discussion in 'Deals & Group Buys' started by james@tech12volts, Oct 12, 2019.
Thread Status:
Not open for further replies.
  1. Oct 28, 2019 at 2:50 PM
    #121
    YsoSeRiouS!
    YsoSeRiouS! A good day...for a good day
    NorCaL
    2019 White Platinum CM
    What was the hiccup if you don’t mind me asking
  2. Oct 28, 2019 at 2:55 PM
    #122
    6XC
    6XC OPS4
    '18 MGM Tundra SR5 TSS Crewmax 4x4
    I'm a dummy and didn't look at the PDF attachment for the carlink instructions. Only read what he wrote in the email so I wasn't watching for the flashing red light before hitting the brake pedal.
    YsoSeRiouS![QUOTED] likes this.
  3. Oct 28, 2019 at 3:33 PM
    #123
    spyshot
    spyshot 1Cor 15:55-57
    Ohio
    2019 Tundra Platinum
    Platinum pretending to be Pro
    Just got mine today and I am reviewing the videos and instructions before I start. I just bought the basic $199 remote start. I’m guessing this little guy is not going to be used?
    jewsNbrews likes this.
  4. Oct 28, 2019 at 3:34 PM
    #124
    6XC
    6XC OPS4
    Nope.
    Durania and Deuxlatch like this.
  5. Oct 28, 2019 at 3:37 PM
    #125
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Correct. Keep it though, incase you upgrade though. This is what @james@tech12volts told me.
    Deuxlatch likes this.
  6. Oct 28, 2019 at 5:04 PM
    #126
    Bushwacked989
    Bushwacked989 New Member
    2020 Tundra SR5 - Cav Blue
    Anything yet?
  7. Oct 29, 2019 at 10:44 AM
    #127
    Papagriff
    Papagriff New Member
    2010 crewmax Sr5
    Mine will be here tomorrow! Super stoked!
    Bama and jewsNbrews like this.
  8. Oct 29, 2019 at 11:55 AM
    #128
    Bama
    Bama Member
    2016 MGM Tundra 2015 MGM Sequoia 2014 LX
    How long since you ordered?
  9. Oct 29, 2019 at 12:47 PM
    #129
    Papagriff
    2010 crewmax Sr5
    I ordered on the 13th.
    Bama likes this.
  10. Oct 29, 2019 at 1:10 PM
    #130
    spyshot
    Ohio
    Ordered on the 15th. Received on the 28th.
  11. Oct 29, 2019 at 1:18 PM
    #131
    Bama
    Bama Member
    Cool. Thanks. Anxiously awaiting my shipping notice! I just ordered last week. Never had remote start on a vehicle... can't wait.
  12. Oct 29, 2019 at 3:49 PM
    #132
    19TundraPlatinum
    19TundraPlatinum New Member
    Maryland
    2019 Tundra Platinum Magnetic Gray Metallic
    5% Window tint Ceramic coating Weather tech mats Color matched mirror caps and door handles Oem black exhaust tip Blacked out 4x4 badge and added black tundra tailgate insert
    Got mine installed today with the Carlink app. Install went smooth and had zero issues with the door lock others mentioned. I needed some help with the Carlink but that was my own fault as I couldn’t find the directions he had sent me. Anyways he resent directions but instead he also just walked me through programming the Carlink module while on the phone. Awesome guy and I’m glad I was able to take advantage of this offer. Thanks for putting it together for us, much appreciated !
    GODZILLA, classiccat and jewsNbrews like this.
  13. Oct 29, 2019 at 5:57 PM
    #133
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    Easy install on the Tundra, will tackle the Sequoia this week.
    Only issue for my setup is that I have an aftermarket stereo with the Maestro Module that plugs into the OBD2 port. The remote start feeds voltage back into the OBD2 harness which is read by the Maestro.
    What does this mean? It means that when you turn the ignition off, the stereo stays on. The fix for now is to unplug the Maestro. I need to figure out a diode or something so I can get my Maestro features back.
  14. Oct 30, 2019 at 12:17 PM
    #134
    19TundraPlatinum
    Maryland
    Update: I experienced a problem with the module going offline, when you would look at the app it was no longer green indicating that it had a connection, I popped the panel back off to check everything and notice one pin on the blue connector had started coming out. I simply pushed it back in until it clipped and all is well again. Just wanted to post in case anyone experienced the same problem check that first.
  15. Oct 30, 2019 at 1:18 PM
    #135
    GlobalGuy
    GlobalGuy GlobalGuy
    Buffalo, NY
    2018 Silver TRD Double cab
    Will the Toyota dealership give me any hassle about cutting a wire on a 2018 to install this if I have any other electrical problems down the road??
  16. Oct 30, 2019 at 4:31 PM
    #136
    nvrgvup444
    nvrgvup444 New Member
    KCMO
    2015 Dbl Cab Limited - Blue Ribbon
    Bilstein 5100 all corners, Toytech Shackles, Nitto Ridge Grapplers, Completely new sound system that sounds great but didn't cost an arm and leg, front camera, front receiver hitch
    I had asked this question the gentleman at tech12volts replied to me:
    "doesn't matter you can plug into the one for the remote start . But if your maestro is one of the older ones you will need to cut out a resistor in the harness of it or your radio will stay on . we can send you pics of it if this is the case.
    here is our group buy price https://www.shop.tech12volts.com/product.sc?productId=537&categoryId=59"
    Hope this helps you out. He seems very smart and knows the product inside and out.
    19TundraPlatinum and jewsNbrews like this.
  17. Oct 30, 2019 at 4:42 PM
    #137
    nvrgvup444
    KCMO
    Just placed my order. This is a good deal and I'm stoked to put this in!!!
  18. Oct 30, 2019 at 4:55 PM
    #138
    Randoo254
    Randoo254 Addicted to Upgrades
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    I got mine hooked up today. James helped me through it
  19. Oct 30, 2019 at 5:26 PM
    #139
    Bushwacked989
    How do y'all get responses? Hasn't responded to me in days ... A for sale thread and no support ..gonna pass on this one
  20. Oct 30, 2019 at 5:30 PM
    #140
    Dakar650
    Dakar650 New Member
    Shawn
    2019 Cement Limited
    Arrived today!
  21. Oct 30, 2019 at 5:31 PM
    #141
    Randoo254
    Randy
    2020 TSS 4x4 SR5
    3 in leveling Kit
    He doesn’t respond a whole lot on here but email and text he’s right away
  22. Oct 30, 2019 at 5:31 PM
    #142
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Email him...he isnt in this thread other than to announce the sale. Once you buy he gives you his personal number to call with questions and tips.
    Bushwacked989[QUOTED] likes this.
  23. Oct 31, 2019 at 4:37 AM
    #143
    spyshot
    Ohio
    he responded to a PM for me very quickly.
  24. Oct 31, 2019 at 4:50 AM
    #144
    6XC
    6XC OPS4
    I had an almost instant response to all my emails and he gave me his phone number also.
    jewsNbrews and 19TundraPlatinum like this.
  25. Oct 31, 2019 at 4:53 AM
    #145
    6XC
    6XC OPS4
    One thing I noticed after install that I don't like. After remote starting and using the fob to unlock now all my doors unlock with a single press instead of just my driver side door.
  26. Oct 31, 2019 at 5:25 AM
    #146
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    Ok. Thats good info. I was really looking at the remote start and a new HU but had the same questions. How do you use to ODBII connections and does it cause issues? Let me know if you figure this out. You can't be the only one with a remote start and aftermarket HU. :)
  27. Oct 31, 2019 at 3:10 PM
    #147
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    You mean it fixed it. :) I prefer all my doors to unlock with a click. I hate having to double click for all the doors. I know its probably a safety thing so someone doesn't enter your truck from the other side or something. I live where that is not a problem.
  28. Oct 31, 2019 at 3:56 PM
    #148
    MyFj08
    MyFj08 New Member
    Mark
    2012 crewmax 4wd.
    I'm working on it
    Ok.. Ok..
    I have a complaint. about this remote start thing
    Recived mine 2 days ago got home from work early today so I figured what the hey give it a shot
    This thing was Seriously to Easy To Install
    I'm almost disappointed
    It took me longer to take the trim panels off
    Than to actually plug it in and activate it
    I mean . Gezzz. Was it easy
    Thanks for the group buy . It was seriously the easiest remote start i have ever installed
  29. Nov 1, 2019 at 7:53 AM
    #149
    Captainjohn
    Captainjohn New Member
    2019 Tundra Dbl cab
    Rock sliders, topper, sliding bed
    Complete install last night, just need to put dash back together.
    Anyone have any thoughts or ideas on where to mount controller and antenna ?
    Dose antenna work best kept up high under dash ?
    Thank in advance, need to finish tonight, but wanted to ask first ....
  30. Nov 1, 2019 at 8:16 AM
    #150
    STE4DY
    STE4DY New Member
    Anthony
    2017 Limited TRD Off Road
    got the car link installed and running. funny thing when i started testing it was i was having problems connecting to the unit from my phone and after looking around at the app and saw in the service status that they were having connectivity issues so i just waited til the next day for them to fix it and ever since it’s been perfect.
Thread Status:
