Tech12volts door and/or dash speaker group buy. 2020 version
Discussion in 'Deals & Group Buys' started by james@tech12volts, Jan 13, 2020.
Thread Status:
Not open for further replies.
  1. Feb 14, 2020 at 5:45 PM
    #151
    dsimonl
    dsimonl New Member
    2017 Tundra DC Limited MGM
    Amp Research Powersteps and Bedstep, 2018 LED headlights, LineX Platinum, Baja Designs fog lights, Driver side grab handle, SwingCase
    :( Thanks for confirming. At least I didn't pop the covers on yet. Removing those without breaking a tab was the hardest part
  2. Feb 14, 2020 at 6:29 PM
    #152
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    He has the correct speakers installed, the other speakers did not have a grill and they were bigger making them not fit correctly....the “bigger” speakers without the grill and the ones he has installed have the exact same specifications just made to fit
    post 80 is the WRONG speakers
  3. Feb 15, 2020 at 1:54 AM
    #153
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
  4. Feb 15, 2020 at 3:52 AM
    #154
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    If they sound good and there are no issues, I say keep them.
    JMHO
  5. Feb 15, 2020 at 3:54 AM
    #155
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
  6. Feb 15, 2020 at 4:03 AM
    #156
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    These are what I was expecting to get and I received the smaller ones.
    Personally not satisfied with the smaller ones I was sent. Spoke with James and he suggested bypassing the crossover. I am going to try that and see what happens.
    Happy with everything else though.
  7. Feb 15, 2020 at 4:52 AM
    #157
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    Those do not fit right! I have them installed.
  8. Feb 15, 2020 at 6:10 AM
    #158
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    So...I'm not trying to be a pill...just want to understand what I'll be getting and what's going on. The 2.75's were substituted for the 3.5's because the 3.5's didn't fit. With Jame's suggestion to try bypassing the crossover...anyone care to explain how to do that?
  9. Feb 15, 2020 at 6:34 AM
    #159
    dsimonl
    dsimonl New Member
    The crossover is included in the package James sends. It is a little 'tube' that is wired in with the plug-n-play harness.
    The printed specs may seem the same, but there is a big difference in the area of a 2.75 disc and a 3.5 disc. The larger disc has ~50% more surface area to move air. The difference will be even more noticeable when the crossover is removed, as the 'same' specs don't apply any longer. The 800hz lower limit on both is most likely due to the high pass filter installed (crossover). I'm not sure I'll return mine - I'll keep them until I find something better - but I'm certainly disappointed with the substitution.
    mtucker likes this.
  10. Feb 15, 2020 at 6:45 AM
    #160
    dsimonl
    dsimonl New Member
    r8rs4lf, did you have to do some trimming to make them fit? The 3.5 Infinity's that were in last year's package mostly fit. 1 hole needed to be added for the mounting screws.
    What is really confusing to me is James stated in post #1
    "we are using kenwood excelon 3.5 that are made to go in the tundra dash. They are direct bolt in and i like them alot . They actually sound better than some speakers we have used that cost 4 times as much. and they have a 2 year warranty ."
    That statement implies to me that he listened to the speakers in a Tundra, and like how they sounded. How do they not fit?
  11. Feb 15, 2020 at 8:00 AM
    #161
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    I did have to trim some of the dash. On the driver side I was able to get both bolts in and the passenger side I could not get one bolt in. I ended up using a zip tie which I'm sure the sun will weaken eventually. Both sides did not fit well. They fit good enough to get the grill to sit flat, that's about it.
    As for the sound, everyone needs to realize that just replacing speakers and doing nothing else will net minimal results. I would say the highs in the dash sound better and crisper. That's about it! That's the reason why I have not jumped on the GB for the doors. I don't think it will make much of a difference without adding an aftermarket amp to power them and I don't want to get into all that work. I think I would benefit more by getting a better LOC for my JL sub and amp.
  12. Feb 15, 2020 at 8:30 AM
    #162
    dsimonl
    dsimonl New Member
    Thanks for the clarification. Did you install the capacitor? Your larger speakers would benefit by removing it. There are a lot of mids being filtered out below 800hz
  13. Feb 15, 2020 at 10:42 AM
    #163
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    I installed them the way they came. As for the mids being filtered out, I can't miss something I never heard.
  14. Feb 16, 2020 at 2:39 PM
    #164
    dsimonl
    dsimonl New Member
    I pulled the speakers and removed the capacitors. There is an improvement in the midrange frequencies. I think about as good as we can expect from a small full-range speaker.
  15. Feb 23, 2020 at 4:32 AM
    #165
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    I have everything installed except the Rt/Lt dash speakers - still waiting for the JBL harnesses. Also have Jame's single 10" sub all running off the stock amp/headunit. I will of course need an amp and I knew that going into this and I currently have an email into James looking at options.
    I thought I'd share my review of this system using the stock amp. Some songs sound awesome, big and bright highs, lots of sound being produced including bass and midrange frequencies, a big improvement! Other songs sound tiny and a million miles away. This effect is independent of source. Example, I was listening to Sirius and Beastie Boys Sabotage came on and I thought this should sound good - it sounded horrible - small, tiny, no bass, no mid-bass, as if only the tweeters were playing (I confirmed there was sound coming from all speakers). The next song was Alanis Morrsette - Ironic and it sounded awesome - tons of volume, tons of sound, I could feel the bass (to what is essentially a bass-less song). Tool universally sounds horrible with no bass/mids. Dr. Dre sounds great and the bass shakes the rearview mirror. I have a song "Bassgasm" that sounds absolutely rocking from a bass/mids POV.
    My guess is the stock JBL amp is under powering everything and that's leading to lots of inconsistencies in sound? Highs always sound great but it's the bass and mid-range frequencies that seem to randomly show up or dropout depending on song.
  16. Feb 23, 2020 at 4:38 AM
    #166
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    Just so I know this is normal. I also notices the front door woofers and rear door woofers behave very differently as far as the frequencies they play. The front door woofers only play low frequencies and often they seem like they are barely on and barely making any noise and the noise they do make is very muddled. I assume this is because they work with the dash speakers which are supposed to play the mids. The rear door woofers plays both low and mid-frequencies with things like guitar and voices being played through this speaker which again I assume is setup this way because the rear only has an additional tweeter? Seems like the front would sound better is the front door woofer behaved more like the rear door woofer?
  17. Feb 23, 2020 at 4:33 PM
    #167
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Correct dash speaker setup.
    Wire management and rattle prevention with some quiet tape. Might be a little overboard but whatevs. I only wanna do it once lol
    LogCabins likes this.
  18. Feb 24, 2020 at 6:38 PM
    #168
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Painted the adapters black and got the driver door done :thumbsup:
    I only have one door left lol!!!
  19. Feb 26, 2020 at 1:23 PM
    #169
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    got my dash kennys in over the weekend, got them in the truck in less than an hour and rewired also sounds good!
    Flyinryank likes this.
  20. May 6, 2020 at 2:48 PM
    #170
    Kybosh_ag
    Kybosh_ag New Member
    Adrian
    2008 SR5 DC
    Not enough
    Ordered Saturday evening, arrived today (Wednesday). Hopefully I can get them installed today or tomorrow, but I didn't plan ahead and haven't ordered any sound deadener. Oh well, I won't have time to install speakers and cover the doors anyway, guess the panels will be coming off again.
  21. Mar 8, 2021 at 6:25 AM
    #171
    Wellensky
    Wellensky New Member
    Lereazoah
    2016 Toyota Tundra crewmax Limited
    None
    I am interested. I want to order, but do not want to do it my self, I want the complete audio sound upgrade package for my 2016 Limited.
    How can you make this happen for me?
    I live in Texas.
  22. Mar 8, 2021 at 6:41 AM
    #172
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    Drive to GA? There's nothing magical about the what he sells or does. I've seen installers baulk at installing customer-supplied equipment or they jack up the installation fee.
  23. Mar 8, 2021 at 8:01 AM
    #173
    Wellensky
    Lereazoah
    None
    So, could you kindly recommend someone or a shop somewhere within Texas?
  24. Apr 30, 2021 at 9:22 PM
    #174
    TucsonTundra1794
    Anthony
    Tucson, AZ
    2023 1794 Edition TRD Package
    Any chance for another group buy?
  25. May 1, 2021 at 9:41 PM
    #175
    Highsierraguy
    Highsierraguy New Member
    Nor Cal
    If so, count me in.
  26. May 6, 2021 at 9:45 AM
    #176
    rjsimz
    rjsimz New Member
    Rob
    2015 SR5 CrewMax 4x4
    Need this to happen
  27. May 6, 2021 at 9:56 PM
    #177
    CampRig
    CampRig New Member
    Big Pine, Ca
    2016 SR5
    Kings w Adjusters Etc
    I got in the last group buy and would like this one to happen quick! Just had my drivers side dash speaker blow out. Siri sounds like hell right now
  28. Aug 20, 2021 at 5:56 AM
    #178
    Shaff777
    Shaff777 Rocking the Tundra since 2010
    Justin
    Boise
    2020 cement SR5
    Boss 2.5 Aluma kit. SPC UCA’s Color matched front surround Scs Ray 10 wheels. Cooper AT3 XLT’s 295/70/18
    I’m in for a group buy when it happens
  29. Oct 29, 2023 at 7:08 AM
    #179
    Ricksta13
    Ricksta13 New Member
    Rick
    2020 tundra trd sport
    6” lift n after market rims
  30. Oct 29, 2023 at 7:09 AM
    #180
    Ricksta13
    Rick
Thread Status:
