Tech12volts door and/or dash speaker group buy. 2020 version
Discussion in 'Deals & Group Buys' started by james@tech12volts, Jan 13, 2020.
Thread Status:
Not open for further replies.
  1. Jan 31, 2020 at 1:39 PM
    #91
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Thanks for the heads up. I haven’t received another tracking number so I just emailed him.
    LogCabins[QUOTED] likes this.
  2. Feb 1, 2020 at 5:20 PM
    #92
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Here we go
    AZBoatHauler likes this.
  3. Feb 1, 2020 at 5:46 PM
    #93
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    Gonna want a sub after...I know I do...lost all low end, but the clear crisp sound these plus the dash replacements put out is awesome.
  4. Feb 1, 2020 at 8:23 PM
    #94
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Tackled one front and one rear door today. Got 3.5 sheets of kilmat inside the door on the outer skins along with hushmat behind the speakers. Waiting on some quiet tape and taps for the tweeters now.
    2chains, Hartc90 and LogCabins like this.
  5. Feb 2, 2020 at 11:38 AM
    #95
    2chains
    2chains New Member
    Southern Ablerta
    ^^Looking to order the Kilmat for mine. What size sheets are those?
    I'm going to do mine in stages as well.
  6. Feb 2, 2020 at 12:18 PM
    #96
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
  7. Feb 2, 2020 at 12:29 PM
    #97
    2chains
    2chains New Member
    Southern Ablerta
    Thanks for posting!
    Flyinryank likes this.
  8. Feb 2, 2020 at 12:32 PM
    #98
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    I only used about 7 sheets per door. Leaving me 6 sheets to apply to the wall behind the back seat.
    Waiting for some some quiet tape and positaps to finish install with tweeters
  9. Feb 2, 2020 at 12:34 PM
    #99
    2chains
    2chains New Member
    Southern Ablerta
    That's great info, think I'll order bit more.
  10. Feb 2, 2020 at 2:33 PM
    #100
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    I installed the front dash today.
    Cut the harness off old speakers and soldiered it to the new ones.
    Pretty easy.
  11. Feb 2, 2020 at 2:57 PM
    #101
    SouthWestGA
    SouthWestGA New Member
    James told me that on all the factory speaker Wiring that GREEN IS POSITIVE
    I cut and used my original harness as well for the dash. I have managed to get the drivers side speaker done and the rest will be done bit by bit.
  12. Feb 6, 2020 at 6:06 AM
    #102
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I just purchased the JL Audio dash tweeters and love them, now im going to start looking at different door speakers.
    I want to retain the mid bass that the factory speakers produce, kinda like the bass thang....
    My question is: who has replaced just the front doors and backs with the Hertz, but do not have or use front sail panel tweeters?
    From earlier posts, its been noted that with the hertz cross overs, some mid bass is lost.
  13. Feb 6, 2020 at 7:02 AM
    #103
    AZBoatHauler
    So.Arizona
    I don’t think it’s the crossover causing the loss of mid bass - the crossover should be set as a high pass filter for the tweet not a bass filter for the mid. I think the loss of mid bass comes from the decreased surface area of the replacement speaker. Up front, the stock speaker is a 6x9 and you’re replacing with a 6.5”. The upgrade in sound is worth it you’ll want to plan for subs and a box from James as well.
  14. Feb 6, 2020 at 7:40 AM
    #104
    purplenova
    Tom
    Ohio
    I have sub already and as i noted the new JL Audio dash speakers. Just trying to get a head start on some method of choosing a good set of door speakers that match up well to the tweeters in the dash.
    OR - am I over thinking the process?
  15. Feb 6, 2020 at 7:58 AM
    #105
    AZBoatHauler
    So.Arizona
    Probably. Call or email James, let him know your concerns and he will point you in the right direction. I used my amp settings (gains and filters) to make adjustments once everything was installed. For my setup, that ended up having the front channel gain set slightly lower than the rear channel (because of the extra dash speakers) which is set slightly lower than the sub channel. I also recommend setting up a remote bass control knob for the subs.
  16. Feb 6, 2020 at 8:26 AM
    #106
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    We are in the same camp as I have a (JL) sub and amp and have only replaced the dash speakers with the JL tweeters and the Kenwood sides.
    From my POV, the upgrade in the dash is good enough as it seems I hear most of the sound coming from there. I'm not sure how replacing the door speakers can make it sound that much better without adding an amp. It may make it a bit clearer (crisper), but without hearing them, I'm not sure if I will upgrade the doors. If I do, I will be adding a 5 channel amp to power everything, a better LOC along with any PnP harnesses needed not to cut factory wiring. That's where it becomes a bit more involved than I want to get in to. It sounds great already for my taste.
  17. Feb 6, 2020 at 9:37 AM
    #107
    purplenova
    Tom
    Ohio
    Guess i didnt add all my upgrades - all i have now that is factory is the H/U and the 4 doors, plus the tweets in the rear doors.
    I have a kenwood 5 channel amp and the audio control LC7i installed under the front seat.
    I will definitely buy my remaining items from James, just wanted to see what others were experiencing that have similar setup to mine.
    Cant really go to audio store and listen to their setups, just not the same.
  18. Feb 6, 2020 at 9:57 AM
    #108
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    If I had your set up, I would do the doors. Doesn't seem like it would hurt anything.
  19. Feb 6, 2020 at 10:31 AM
    #109
    purplenova
    Tom
    Ohio
    I will do the doors in a couple months, just cant do it all at once or the wife will catch it...:fingerscrossed:
    LogCabins likes this.
  20. Feb 6, 2020 at 10:33 AM
    #110
    LogCabins
    'Merica
    2017 TRD Pro
    SAME :rofl:but I did doors first.....then dash....next and last is 5 channel amp and sub....that's gonna be hard to hide:spy:
  21. Feb 7, 2020 at 10:15 AM
    #111
    purplenova
    Tom
    Ohio
    Paypal Credit :bananadance: - no invoices in the mailbox, 6 months same as cash over $99.00
  22. Feb 7, 2020 at 10:30 AM
    #112
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    I'd be interested as soon as plug-n-play for JBL is an option.
  23. Feb 7, 2020 at 10:33 AM
    #113
    purplenova
    Tom
    Ohio
    Didnt James just post that he now has the JBL PNP harneses???
  24. Feb 7, 2020 at 10:41 AM
    #114
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    I missed that...thank you!!!
  25. Feb 7, 2020 at 10:53 AM
    #115
    purplenova
    Tom
    Ohio
    Check out post #68
  26. Feb 7, 2020 at 11:26 AM
    #116
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    Just jumped on this plus the 10" sub plug and play JBL option.
    purplenova likes this.
  27. Feb 7, 2020 at 11:42 AM
    #117
    purplenova
    Tom
    Ohio
    SWEET :headbang: :headbang:
  28. Feb 7, 2020 at 11:43 AM
    #118
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    Well...looking for an improvement and to do some tinkering but you know...it needs to be easy and plug-n-play :)
    purplenova[QUOTED] likes this.
  29. Feb 7, 2020 at 12:01 PM
    #119
    LogCabins
    'Merica
    2017 TRD Pro
    Money isn't the worry as much as trying to explain a huge box showing up to the house...wife works from home so can't get away from that one.....and the fact every vehicle I buy...shes in the background "Here we go again with the mods" :rofl:
  30. Feb 7, 2020 at 12:12 PM
    #120
    SandyTRD
    SandyTRD New Member
    ‘16 Pro
    Dented bumper
    Just let her listen to the stereo. My wife’s car has a decent system and when she used the truck she said its stereo sucks. And asked why I waited so long to upgrade.
    :spending:
Thread Status:
