Tech12volts door and/or dash speaker group buy. 2020 version
Discussion in 'Deals & Group Buys' started by james@tech12volts, Jan 13, 2020.
Thread Status:
Not open for further replies.
  1. Jan 13, 2020 at 8:48 PM
    james@tech12volts
    james@tech12volts [OP] tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    So after having tons of people ask us to do another K170 group buy here it is .
    We are doing this again. I had to go up on the speakers a little as the tariffs have everything costing more right now in my industry but not by a lot. and the sides we are using kenwood excelon 3.5 that are made to go in the tundra dash. They are direct bolt in and i like them alot . They actually sound better than some speakers we have used that cost 4 times as much. and they have a 2 year warranty . the center is still JL audio c1 twetters . The plug n play option is for NON JBL only . my harness guy is trying to make some for JBL but hasn't as of yet . still very easy to wire them in as you can take the factory speaker out of the truck and wire it back into the factory plug while out of the truck . The sail panels are factory toyota parts and the tweeters just pop right in them. Here is the new listing .
    so you get
    1 set of hertz k170 components front with brackets and harness
    1 set of hertz k170 compoents rear with brackets and harness
    all screws and bolts for mounting them for 229.99
    options are center channel jl c1 tweeters with our custom bracket
    side speakers for dash are kenwood excelon 3.5 that are made to be direct replacements .
    for non jbl guys you can get the sail panels to place the tweeter up high in the front doors and i highly recommend these . You can cut your also but if you are off on where you cut them the tweeter will not sit flush. so be forewarned if you decide just to cut yours.
    also fo non jbl we have plug n play harnesses for center and side speakers that prewire for you so they just plug into the factory plug on the dash . Sorry jbl guys i am working on some for you guys also but they are still very easy . Shipping is free in the lower 48 states
    https://www.shop.tech12volts.com/product.sc?productId=579&categoryId=137
  2. Jan 14, 2020 at 4:15 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Hell gyeah!
    Will the stock head unit power these replacements sufficiently?
    If so I’ll be placing an order for everything payday friday
  3. Jan 14, 2020 at 6:25 AM
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    Ordered mine yesterday....at least the hertz K170s for the doors....and already have the "out for delivery" notification this morning!!! Will be placing an order for the dash speakers next week....James has literally the best customer service!!!
    satosan and TXTundra2722 like this.
  4. Jan 14, 2020 at 8:50 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Questions: 1.) Plug and Play - is the entire speaker kit fronts/rears, tweets and dash all plug and play, no cutting required?
    2.) Since I have an SR5, no front sail panel tweets, just rear. Can I run corner dash speakers and sail panel tweeters and remain plug and play?
    satosan likes this.
  5. Jan 14, 2020 at 9:41 AM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    They have premade sail panels for sale as well
    purplenova[QUOTED] likes this.
  6. Jan 14, 2020 at 9:43 AM
    james@tech12volts
    james
    yes you will run a wire down to the mid from the tweeter but we send you every thing prewired so all you do is plug it in . there is zero cutting on non jbl if you buy the harnesses for plug n play . its literally bolt in and plug up
  7. Jan 14, 2020 at 9:44 AM
    james@tech12volts
    james
    thanks brother if you need help with the install hit me up
  8. Jan 14, 2020 at 9:55 AM
    SouthWestGA
    SouthWestGA New Member
    Any tips from Those of us with JBL that are just doing door/dash speaker replacement?
  9. Jan 14, 2020 at 9:59 AM
    purplenova
    Tom
    Ohio
    Thank You
  10. Jan 14, 2020 at 10:02 AM
    purplenova
    Tom
    Ohio
    I dont think the sail panels are pre-loaded with the tweeters are they?
  11. Jan 14, 2020 at 10:05 AM
    james@tech12volts
    james
    no they are not but they just snap in
  12. Jan 14, 2020 at 10:07 AM
    james@tech12volts
    james
    its also easy just connect the wires up on the tweeter . The rears have to be jumped at the tweeters also but we send you instructions on how to do that
    AZBoatHauler likes this.
  13. Jan 14, 2020 at 10:46 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    @james@tech12volts Would it be possible for you share the install instructions for the K170 sets so I can get an idea if this is something I want to tackle? Thanks.
  14. Jan 14, 2020 at 11:50 AM
    AZBoatHauler
    So.Arizona
    LogCabins likes this.
  15. Jan 14, 2020 at 11:54 AM
    PKFan
  16. Jan 14, 2020 at 1:48 PM
    james@tech12volts
    james
    dd headphones.jpg just a little something i want to do . Everyone who purchases this group buy of speakers will be entered into a drawing to win a free set of DD AUDIO WIRELESS BLUETOOTH HEADPHONES !we will do the drawing at the end of the group buy and someone will win a pair of these headphones for free. I own a pair personally and they are amazing!! you do not have to do anything to enter . When you order that is your entry
    http://ddaudio.com/products/lifesty...05-wireless-active-noise-canceling-headphones
    Borador, AKJ78, vegas4x4 and 4 others like this.
  17. Jan 15, 2020 at 1:30 AM
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Order placed! Couldn’t miss your group buy again. Thanks James
  18. Jan 15, 2020 at 1:56 AM
    Jmad1997
    Jmad1997 New Member
  19. Jan 15, 2020 at 2:08 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    Does this come with the speaker adapters as well? - yeah it does! Would help if I read the whole post first
  20. Jan 15, 2020 at 5:02 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    Order placed, I'm loving your sub. Thanks for the great products!
    I bought MP 25.3 tweeters last week. Are they better than the tweeters from this GB?
    I have not installed them yet and will wait for these if they are better.
    Thank you!
  21. Jan 15, 2020 at 6:11 AM
    LogCabins
    'Merica
    2017 TRD Pro
    For every one in here, wanted to share this very helpful write up, just in case you needed it:
    Tech12volt / Hertz door speaker install
    Edit: I see @AZBoatHauler already posted link above...Thank you!
    Also make sure to have some T-taps or butt connectors on hand prior to install, for the tweeter wire installation. You will see in the post i Linked where to tap your tweeter wires. hope this helps and it is a very easy and straight forward install. Oh 1 more thing look on the back of the Hertz speaker box to see how you put the mounting ring onto the tweeter.
  22. Jan 16, 2020 at 7:28 AM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    Would it be possible for you to build the speaker brackets out of plastic like HDPE or maybe blown PVC? Not a huge fan of MDF in the doors. Would be willing to pay extra if this is a possibility.
  23. Jan 16, 2020 at 7:29 AM
    kameleon
    kameleon New Member
    Jackson, MS
    2015 Crewmax Limited 5.7 MGM
    @james@tech12volts I'm not going to miss out on this again! Just sent you a few questions before I order.
  24. Jan 16, 2020 at 9:44 AM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
  25. Jan 16, 2020 at 10:14 AM
    tennisfreak
    tennisfreak New Member
    Forgive me for asking stupid questions but I really suck at this.
    I drive a 2019 double cab non-jbl
    I just purchased a Kenwood DMX906S and all the gear/harnesses/accessories to install it from Crutchfield.
    I have not bought any speakers or anything to even bypass the factory amp.
    This group buy looks great but I have a couple of questions.
    The "side speakers for dash are kenwood excelon 3.5 that are made to be direct replacements ." - is this the existing tweeters on the right and left of the dash?
    If I get those is there no need for the sail panels and tweeters? Is it either/or?
    @james@tech12volts Do you sell any kind of plug and play or easy to install amp for an amateur like myself?
  26. Jan 16, 2020 at 10:27 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Just email him again. He prob didn't get it
  27. Jan 16, 2020 at 10:33 AM
    james@tech12volts
    james
    They are not MDF . They are treated HDF . Big difference . I have them in vehicles for 15 years and I live in a very hight humidity climate . zero swelling .They look like MDF but they are not
    kameleon likes this.
  28. Jan 16, 2020 at 10:34 AM
    james@tech12volts
    james
    shoot me an email we have all that for you and can make it easy tech12volt@gmail.com
  29. Jan 16, 2020 at 11:19 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    I emailed him again and he immediately got back to me.
    Thanks...
  30. Jan 16, 2020 at 1:36 PM
    kameleon
    kameleon New Member
    Jackson, MS
    @james@tech12volts did you get my email this morning? I just replied to our previous conversation so you might have missed it.
Thread Status:
