Tech12volt / Hertz door speaker install
Discussion in 'Audio & Video' started by BlueBottle, Mar 2, 2019.
  1. Jun 15, 2020 at 6:26 PM
    #91
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    PWMDMD !!
    You were so right!! After my install, I would hear a weird poppy quality to the bass, almost like a driver was popping.... or bottoming out hard.
    I remembered your comment and last weekend I pulled the doors off and switched the front speaker positions further back, now directly aligned with the speaker grill. It made a TON of difference. Thank you!
    PWMDMD[QUOTED] likes this.
  2. Jun 21, 2020 at 12:29 PM
    #92
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    can someone show before and after? I can’t picture it for some reason.
  3. Jun 21, 2020 at 9:34 PM
    #93
    panicman
    Eric
    Hey BlueBottle,
    if you remove your door panels, remove the 4 screws from each adapter, and swap the right and left assemblies, you’ll align the speakers to the factory grills. The sound difference is pretty pronounced.
    if I have a minute, I’ll pull the door panel and take a pic.
  4. Jun 21, 2020 at 10:36 PM
    #94
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Ah so in other words my left adaptor should be on my right door. I guess I was too excited when I installed them lol. Are they labeled?
  5. Jun 21, 2020 at 11:45 PM
    #95
    panicman
    Eric
    They are not labeled. You could also dismount the speakers from the adapters, flip the adapters so that the speaker hole is positioned further back, and reinstall the speakers, but it makes more sense to just swap assemblies.
    BlueBottle[OP] likes this.
  6. Sep 20, 2020 at 9:32 AM
    #96
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    Cold air intake, LED upgraded lights, 295/70/18 Toyo Open Country M/T.
    Did the harness James provide to you fit the harness for the bigger door speaker, or fit the harness for where the tweeter plugs in? I know James is off this weekend to celebrate his wife’s birthday so I can’t get help that way. But his directions say the harness should plug into the mid range speaker.
  7. Sep 20, 2020 at 9:56 AM
    #97
    SteveCanyon
    SteveCanyon New Member
    I DA HO
    2020 TRD Sport
    It's for the bigger speaker. DO NOT using the wiring for the tweeter at all. I tried that and it didn't work well at all. The new tweeters which James sent me sounded horrible (weak). Tap the tweeter wiring into the larger speaker wiring, but then again I have crossovers (Hertz) for the rear doors. Maybe I did it incorrectly, but they sound great.
  8. Sep 20, 2020 at 10:05 AM
    #98
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    That’s where my confusion is. I only got two harnesses and trying to install hertz 165.3 components. The two harnesses will only plug into the truck harness that plugged into the tweeter. And am I not supposed to use the dx300 2-way box at all? Is that what you mean by not using the tweeter wires at all?
  9. Sep 20, 2020 at 10:16 AM
    #99
    SteveCanyon
    I DA HO
    2020 TRD Sport
    Phil, I have the CK 165L components, so I'm not sure if that's the same as 165.3? The harness(x2) James sent me could ONLY connect to the harness that goes to the bottom speaker harness. I have two crossovers for each door; one for the tweeter and one for the subwoofer. Maybe James accidently gave you the wrong harness? Sorry, I can't be more help.
  10. Sep 21, 2020 at 12:25 PM
    #100
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    Yea, it ended up being that he was out of the harnesses. But he helped me direct wire
  11. Sep 21, 2020 at 2:31 PM
    #101
    spittoon
    spittoon New Member
    South Jersey
    2020 Tundra TRD Pro MGM CM
    Toyo OC ATIIIs, AMP Powersteps, Diamondback SE, Line-X, Tech12 JBL package, SPS Graphene coating, Front Runner Load racks w/rod carriers.
    @Flipmode I’ve got all my doors off and realized i didn’t get any speaker harnesses, front or back. Can you relay what you did to direct wire? I’m kinda dead in the water...
  12. Sep 21, 2020 at 2:39 PM
    #102
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    On mine...the plug that goes to the mid range speaker has two wires, I cut them and the one closest to the little lever to release the harness is the positive. Ran that to the positive of the inlet to the crossover and the negative as well. Then from the crossover one side goes to the Tweeter and one to the midrange. And the plug from the truck to the tweeter is not used
  13. Sep 21, 2020 at 3:12 PM
    #103
    spittoon
    spittoon New Member
    South Jersey
    @Flipmode yea i dont have a crossover. I have the Hertz 170s. I was more concerned with which was + and -. So you ended up cutting out the connector and just direct to speaker. Solder or one of those slide on crimp jobs?
  14. Sep 21, 2020 at 6:20 PM
    #104
    Flipmode
    Flipmode New Member
    Phil
    Dayton, Texas
    2020 Tundra TRD Pro
    Yep. Just cut them and hardwire. Just make sure to remember which was closest to the release tab, as that’s positive
  15. Sep 21, 2020 at 6:25 PM
    #105
    SteveCanyon
    I DA HO
    2020 TRD Sport
    Just like every industry in the world it seems COVID is causing supply problems. Thanks china:mad:
    spittoon likes this.
  16. Sep 22, 2020 at 4:15 AM
    #106
    spittoon
    spittoon New Member
    South Jersey
    Thanks man, JRT actually responded last night, food poisoning and all. He's gonna send me out the harnesses today, should have them tomorrow. Customer service doesn't get much better than that. Appreciate the response tho. Guess I'll just cruise around without 3 door panels and a back seat for a couple days. My neighbor was like "hey man, sweet truck, let me check it out." I open the door and he's like WTF?!, get a good price or what? Fun times..
    TXTundra2722 and SteveCanyon like this.
  17. Oct 21, 2020 at 6:45 PM
    #107
    jaflynn738
    jaflynn738 New Member
    So is the correct way the opposite of the picture posted on the 1st page or the correct way on the 1st page?
  18. Feb 3, 2021 at 7:08 PM
    #108
    fstbusa
    fstbusa New Member
    Travis
    2017 Tundra Limited
    wheels, tires, leveled, grille, audio upgrades, etc.
    I’m a bit confused. I have the parallel harness that plugs into the mid and I assume you run the split to the tweeter. Then I have another harness that plugs in to the tweeter location but not sure where to connect it.
    any advice is appreciated.
  19. Feb 4, 2021 at 7:59 AM
    #109
    irishpride114
    irishpride114 New Member
    Travis
    2015 SR5 TRD Double Cab
    I have the non jbl system. I added the sail panel tweeters. Mine came with the same. I called Tech12volts and mine (sail panel tweeters) have to be spliced in the door speaker. I had to use the the harness in your second picture. I assume your first picture is if you don’t want to use tweeters.
  20. Feb 4, 2021 at 8:02 AM
    #110
    fstbusa
    fstbusa New Member
    Travis
    2017 Tundra Limited
    The first picture harness plugs into the tweeter location and the second picture plugs into the mid-bass speaker location. I was under the impression I had to run the tweeter from the mid-bass harness split.
  21. Feb 4, 2021 at 8:20 AM
    #111
    War Machine
    War Machine SSEM # 5 3MW
    Just did this last week. One harness is for the front doors, one is for the rears. One of them wires the tweeters to the mids, ignoring the tweeter plug. The other has the tweeters going directly back into the original plug.
    Problem is I’m not a 100% which is which, but I’m almost positive the harness in the first pic is for the rear doors. I used @dspilot thread for guidance, so maybe he can tell you for sure.
    https://www.tundras.com/threads/new-tech12volts-complete-system-install.69245/
    dspilot likes this.
  22. Feb 4, 2021 at 8:21 AM
    #112
    War Machine
    One of them does (front vs rear), one doesn’t.
  23. Feb 4, 2021 at 9:07 AM
    #113
    fstbusa
    fstbusa New Member
    Travis
    2017 Tundra Limited
    I have 4 harnesses of each. The first one plugs into the tweeter in the back and the second plugs into the mid.... I haven't taken apart the front doors yet to see what they plug into.
  24. Feb 4, 2021 at 10:17 AM
    #114
    War Machine
    I only got two of each. I looked in my instructions and I was correct, the rear ones plug back into the oem tweeter harness. The fronts get wired to the mids.
  25. Feb 4, 2021 at 1:26 PM
    #115
    fstbusa
    fstbusa New Member
    Travis
    2017 Tundra Limited
    so the front door you use the wye on the mid-bass harness to power the tweeter?
  26. Feb 4, 2021 at 2:15 PM
    #116
    War Machine
    Yes sir.
  27. Feb 4, 2021 at 2:22 PM
    #117
    fstbusa
    fstbusa New Member
    Travis
    2017 Tundra Limited
    Is there a reason I can't use the tweeter harness on the front? I have 4 of each harness.
  28. Feb 4, 2021 at 2:23 PM
    #118
    War Machine
    No clue on that one. I just followed the instructions to the letter.
    rockmup likes this.
  29. Feb 8, 2021 at 3:53 AM
    #119
    dspilot
    dspilot Professional Nomad
    North Mississippi
    2019 SR5 4X4 Silver Sky Metallic
    I'm trying to remember how it all worked out. its been a while since I did this install. I only had 4 harnesses in my install kit and they were all the same. I had to splice the tweeter wires into the harness. If I remember correctly, on the back doors where you already have tweeters, you just leave the factory tweeter wiring hanging unplugged after you're done. Good luck. James is super helpful if you can't get it figured out.
    War Machine[QUOTED] likes this.
  30. Feb 8, 2021 at 7:16 AM
    #120
    fstbusa
    fstbusa New Member
    Travis
    2017 Tundra Limited
    I got it done... I ended up just plugging in each of the harnesses and temporarily attaching each speaker and testing it out.... Ended up just wiring each speaker to its own factory plug.
    dspilot[QUOTED] likes this.
