Tech12volt / Hertz door speaker install
Discussion in 'Audio & Video' started by BlueBottle, Mar 2, 2019.
  1. Jan 17, 2020 at 8:30 AM
    #61
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    The JL sub is what supplies most of the bass. The components are just for mids/highs. If you like bass you should get a sub/amp.
  2. Jan 17, 2020 at 8:31 AM
    #62
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    You can do it. Like any project just make sure you have the right tools. Or run it to your local audio shop and have them throw the amp and sub in.
  3. Jan 17, 2020 at 8:44 AM
    #63
    2chains
    2chains New Member
    Southern Ablerta
    Thanks! Really looking for more bass and volume. I have Canadian TRD Offroad non JBL. Maybe I'll pickup his amp/sub kit first and see how I like it.
    Thanks for the encouragement!
  4. Jan 17, 2020 at 8:52 AM
    #64
    ToyoMafia
    Magic carpet.
    Really when you get down to it no one part is harder then another it just takes time and a little homework. When I started car audio we didn’t have YouTube or James at tech12 so your already light years ahead. This forum will get you real far and James in the man if you buy from him. He even helped me with something that did not come from him. That’s the kinda guy he is. I ordered the infinity group buy and plan on installing myself once I receive and install I am more then willing to help you out with pics tools or advice.
    2chains and LogCabins like this.
  5. Jan 17, 2020 at 9:31 AM
    #65
    2chains
    2chains New Member
    Southern Ablerta
    ^^Thanks for letting me know. Didn't know about that other GB. I checked out that other GB and might got that route if shipping is reasonable to Canada. Sounds like this might be more of the route I should take!
  6. Jan 17, 2020 at 9:50 AM
    #66
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    Also if you email him directly...and explain what you are looking for, also letting him know what you currently have (You want to keep Stock Non-JBL Entune HU in a 2019 CrewMax) he will piece a kit together for you, and believe me all his pricing is "group buy" pricing.
    2chains[QUOTED] likes this.
  7. Feb 1, 2020 at 5:17 PM
    #67
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    Broke a tab off on one of the mids trying to plug in the harness. :mad:
    What taps did you use for the tweeters in the sail panels?
  8. Feb 1, 2020 at 5:47 PM
    #68
    LogCabins
    'Merica
    2017 TRD Pro
    I used T-taps
  9. Feb 1, 2020 at 9:40 PM
    #69
    Flyinryank
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    What gauge range do i need to get
  10. Feb 2, 2020 at 7:03 AM
    #70
    LogCabins
    'Merica
    2017 TRD Pro
    IIRC it’s 18
  11. Feb 2, 2020 at 7:47 AM
    #71
    LogCabins
    'Merica
    2017 TRD Pro
    Man that sucks about the tab....yeah those were hard as hell to get the connectors on those tabs, I had to put my thumb under the tab and push the connector on as hard as I could...was a PITA!
  12. Feb 2, 2020 at 8:16 AM
    #72
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    Pillar Tape, Bullet Liner, 20% Tint, Tyger Star Armor Kenwood amp & AudioControl LC7i Tech12volts JL Tweeters
    Friend, you can do it, it's not hard. I did my amp and line out converter myself with help from folks here. Here's mine for reference.
    Stainlesst and 2chains[QUOTED] like this.
  13. Feb 2, 2020 at 7:36 PM
    #73
    2chains
    2chains New Member
    Southern Ablerta
    Is the LOC necessary for non JBL factory head unit?
  14. Feb 2, 2020 at 7:50 PM
    #74
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    yes if you are using your factory head unit then a DSP/LOC is necessary.
  15. Feb 2, 2020 at 8:26 PM
    #75
    2chains
    2chains New Member
    Southern Ablerta
    I ordered the Infinity Kappa 5 package from the group buy and also ordered LOC w/entune harness as it was recommended. Wasn't really sure what it was for.
  16. Feb 2, 2020 at 8:29 PM
    #76
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    If you are talking about the harness-it allows you to just unplug the factory amp and then plug the harness into the amp plugs that taps into the factory wiring and you don’t have to cut the factory harness to wire up your DSP and amp.
  17. Feb 2, 2020 at 8:37 PM
    #77
    2chains
    2chains New Member
    Southern Ablerta
    thanks for the details, sounds like that harness will stream line my install time
  18. Feb 3, 2020 at 4:20 AM
    #78
    ToyoMafia
    Magic carpet.
    It will. It turns the wiring around to rca’s for the amplifier.
    2chains likes this.
  19. Feb 3, 2020 at 6:45 AM
    #79
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    Link for these harnesses?
    Are the harnesses only for certain amps?
  20. Feb 3, 2020 at 7:03 AM
    #80
    2chains
    2chains New Member
    Southern Ablerta
  21. Feb 3, 2020 at 7:42 AM
    #81
    LogCabins
    'Merica
    2017 TRD Pro
    I believe it works for any amp that you want to run your door speakers and sub if you add one....it, like stated above plugs into your stock harness which allows your amp to receive the signal from your stock HU.
  22. Feb 3, 2020 at 8:03 AM
    #82
    purplenova
    Tom
    Ohio
    Just an FYI - on my install, this is the harness I used that plugs into the 2 factory plugs from you NON-JBL amp under the front seat.
    https://www.autoharnesshouse.com/41112.html
    r8rs4lf and 2chains like this.
  23. Feb 3, 2020 at 9:43 AM
    #83
    r8rs4lf
    r8rs4lf New Member
    Al
    Tree Juan Hoe
    2015 MGM SR5
    Can anyone comment on these LOC's? Is there a major difference between these two? I know with the one @purplenova has, it can be used with multiple amps. Other than that, is there a difference in the processing and overall sound?
  24. Feb 3, 2020 at 10:20 AM
    #84
    LogCabins
    'Merica
    2017 TRD Pro
    A LOC or line out converter converts a high level signal (speaker) to a low level signal (RCA).. so not sure it would make much of a difference in processing.
    A DSP or digital signal processor contains hardware/software that allow you to electrically manipulate the signal by adding things such as delay to certain channels, parametric equalization and active crossovers..
    Two different devices for two different purposes..
    Sorry didn't really answer your question in the differences between the 2 LOCs, but trying to help.
  25. Feb 3, 2020 at 10:24 AM
    #85
    Danman34
    Danman34 New Member
    Danny
    2018 White Tundra TRD Sport
    Major difference. The audio control is an LOC on steroids. The other is as bare bones as it gets. The AC lc7 Allows for far more fine tuning and cleaner signal. It allows provides a high preamp voltage which is essential in noise reduction. The audiocontrol unit also will take front and rear channels and will sum them to produce a dedicated subwoofer channel.
    Two totally different pieces of equipment here. I’m running an lc7i myself and it sounds great even with stock headunit.
  26. Feb 27, 2020 at 11:18 PM
    #86
    Just4u
    Just4u New Member
    2014 grey tundra
    Where did you mount the crossover for the rear speakers? I want to install JL c5-650 on the rear but idk where to mount crossover. Any inputs?
  27. Feb 28, 2020 at 7:22 AM
    #87
    LogCabins
    'Merica
    2017 TRD Pro
  28. Feb 28, 2020 at 1:44 PM
    #88
    Just4u
    Just4u New Member
    2014 grey tundra
    LogCabins[QUOTED] likes this.
  29. Mar 28, 2020 at 3:25 PM
    #89
    PWMDMD
    PWMDMD New Member
    Worcester, MA
    2020 Tundra Platinum
    FWIW...in the very first post of the K170 in the front door you can flip the speaker adapters around so the K170 is further rearward which positions it centered in the hole in the door panel. As it’s pictured, ⅓ of the speaker is covered up because it’s positioned too far forward in the door panel hole.
    fstbusa likes this.
  30. May 2, 2020 at 1:31 AM
    #90
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Why would we need to break the back off the factory tweeter and plug it into the factory harness?
