Tech 12 volts JBL replacement sub/box
Discussion in 'Audio & Video' started by zookaroo, Jul 9, 2019.
  1. Jul 9, 2019 at 6:45 AM
    zookaroo
    zookaroo [OP] New Member
    Shawn
    2019 Tundra 1794
    so i ordered the $199 sub and box and got it installed definitely adds more bass and overall more fullness. My question is instead of a JBL sub. It was a infinity 10” sub that was sent. Anyone else get the infinity sub?
  2. Jul 9, 2019 at 7:17 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  3. Jul 9, 2019 at 9:46 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    James also did a group buy on his website for infinity stuff (sub, amp, speakers and box). I assume he had some infinity subs mounted in boxes left from that and sent you one. If I recall correctly the infinity sub is a little better than the JBL and costs a bit more normally so you may have lucked out.
    The one upside to the JBL sub is the switch on the back to run it at 2 ohms or 4 ohms. Not sure if the infinity has that switch or if youd have to rewire the connections to the voice coils to change ohm level.
  4. Jul 9, 2019 at 10:24 AM
    zookaroo
    Shawn
    2019 Tundra 1794
    The infinity had the selectable switch as well.
    Pudge likes this.
